Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Icemaker problem on Sears Side-by-side #106.56546400
Through-the-door icemaker quit working recently; immed. suspected water valve, bought, and replaced that item, still not working (water dispenser is fine). Have read your comments to Tammieroe (03/22/07) and tried the V and L test points - no water (inlet tube NOT frozen). Also read your comments to WillN2Try (09/17-19/07). Both water valve solenoids work with one of the elect. connectors, but not the other one, which I'm assuming would point to the module. There is NO noise coming from the module (not even trying to turn. (Now I did notice that the retaining clip that holds the white wheel onto the motor gear is broken, but shouldn't the motor itself still try to turn? I can replace the module if necesaary (or components thereof) but I have already "wasted" money on the valve, and don't really want to waste more if the module is not the problem. (If you think it is the module, should I just replace the motor and gear assembly or the WHOLE thing? Thanks in advance for your advice!!
  • 5 more comments
  • waterboy1234 Nov 12, 2007
    I seem to be having a similar problem. There is water going to the door. The machine does not turn on. I have a new cartridge. I went through the manual and all the trouble shooting and still nothing. The Ice maker is making no noise. There is a red lite flashing but it does turn of when the door is closed. If anyone has any Ideas that would be great. Thank You. Jeff
  • Anonymous Apr 03, 2008
    Replaced the valve. water is ok on the drink dispenser but still no activity with the icemaker.
  • kiser4 Jul 12, 2008
    Its funny, in a sick sort of way... two days after Sears called to ask if I wanted to renew the service contract on our side by side (106.56546400), which I declined, the ice maker just stopped producing ice. Does anyone know what the little red flashing LED is trying to tell me ? I tried replacing the filter which was pretty old. I thought that once the pressure improved it would start working again (longshot), but it didn't. I haven't really dug into it yet, but plan to today or tomorrow. I was hoping that the LED would lead me to the root of the problem. Does it flash a code?
  • clement2234 Feb 12, 2009
    Regarding the gear assembly, it appears the clip that holds the plastic gear in place has broken... not sure how to fix this. Is there a part I can buy to replace just this piece?
  • ti009 Mar 01, 2009
    anyone knows what the blinking red LED means? is it just a generic "ice maker issue" light? What was the resolution? replace the whole module?
  • darnell57 Mar 19, 2009
    I have the same problem water leaking the freezer.
  • teresaev Mar 28, 2009
    I have the same problem. The light is blinking and no ice has been made. Of course my extended warrenty also just ran out. If anyone knows a home remedy it would be great!
I have a kitchenaid referigator. The icemaker just stop working. The little red light blinks, when the door is open only. What do I do?
Thanks,
Bubba
Posted on Aug 24, 2008
  • 290 Answers
If the retainer in the gear is broken you will have to replace the module. The switch connections are on the back side of that gear and the motor will not run if the gear gets slightly out of place. I will bet the gear has red lettering on it. The module you get to replace it will have blue lettering. Very common problem on these icemakers for a couple of years. They put high torque motors in those modules without beefing up the plastic that holds everything together. The new module should solve your problem.
Posted on Sep 26, 2007
  • Anonymous Oct 08, 2007
    Just wanted to follow up on your icemaker problem and see what you found wrong.
    Thanks/Mike
SOURCE:
Ice maker quit water line works intermittingly
icemaker quite? hire a new icemaker. industry joke sorry.
First things first, is it cooling ok? if yes then proceed.
im assuming it stopped making ice altogether, and not a matter of making ice but not dispensing.
If your ice bucket is located in the door itself, you have an electric eye icemaker system, which electronically determines if the bucket is full or not. this electric eye system, located on both side walls of freezer, consist of a transmitter board and a receiver board. you could have a problem with these boards, the icemaker itself, a bad water valve, or depending on the model year, a icemaker fill line that can get clogged with ice, but due to a faulty design, a fill tube heater must be installed.
if your bucket is not in the door, but located directly beneath the icemaker, then disregard the electric eye system info and the fill tube heater info as well.
Mar 01, 2010 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Jul 14, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Icemaker doesn't work
chack water valve and make sure it is getting water if so and there is ice in ice maker then your heater is bad and not releaseing ice
Jul 08, 2009 | Whirlpool GS6NBEXR Side by Side...
ED25PQ quit making ice. Water dispenser still working
Pour about 1/2 cup of water into icemaker . If it harvests(dumps) then problem is the water valve.....if not , then icemaker is the problem .
Jun 26, 2009 | Whirlpool 25.2 cu. ft. Side-by-Side...
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker does not make ice after first harvest.
theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 106.53342300-side by side-icemaker not working..at all
IT COULD BE 2 PROBLEMS
1 .YOUR DEFROST TIMER IS BAD.
2. YOUR WATER INLET VALVE IN THE BACK COULD BE BAD.
BOTH PARTS ARE VERY INEXSPENSIVE(USUALLY UNDER 20 BUCKS AND YOU CAN GET FROM YOUR LOCAL SEARS OR ANY WHERE ON LINE. GLAD TO BE OF SERVICE
Jan 09, 2009 | Kenmore 52632 / 52634 / 52639 Side by Side...
The icemaker stop working on my Whirlpool side by side frig
If there are ice cubes setting in the icemake waiting to be dumped then the icemaker is bad. If the icemake is dry then the water valve is bad. You have one water valve with two solenoids. One works water in the door and the other sends water to the icemaker.
Dec 15, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
2,520 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
