Question about Sokkia OM5 Optical Micrometer, metric for B20,
OM5 Operator manuql - Sokkia OM5 Optical Micrometer, metric for B20,
What is the watt on model number 811ss professional series microwave
Its must have the manuql and alsoon its body there must be one notice on it or open it and check inside the transformer also there is asmall paper
Sep 14, 2014 | Microwave Ovens
ServicCROWN 35RRTT FORKLIFT SERVICE MANUAL e manual manuals
Crown sp3500 Stockpicker Operator Manual
Crown c5-Internal Forklift Operator Manual
Crown pc4500 Rider Pallet Truck Operator Manual
Crown pw3000 Walkie Pallet Truck Operator Manual
Crown pth50 Hand Pallet Truck Operator Manual
Crown
Dec 29, 2013 | Office Equipment & Supplies
F 56-2 ERROR CODE
Key Operator Mode
To the Key Operator
The key operator is trained to handle all special key operator functions that are not
accessible to the general user, such as monitoring overall copier activity, machine
performance, and service information; modifying machine settings; and controlling user
activity, for billing purposes.
A unique 4-digit key operator password is normally set by service at installation. If the
unique code is not set by service, the copier will not display Key Operator Password
Entry Screen when the Key Operator mode is being accessed, and a key operator
password will not be required. A service-set 8-digit ECM master key code must be
entered by the key operator to access the Electronic Copy Monitor functions, and a
service-set 4-digit Weekly timer master key code must be entered by the key operator to
access the Weekly timer functions.
To ensure the security of Key Operator mode, it is recommended that you establish a
unique key operator password, along with the key operator ECM master key code and
Weekly timer master key code, and keep them in a confidential file.
r HELP is unavailable in the Key Operator Mode
Key Operator Mode Screen 2
NOTE: The function number [12] Call remote service center and [13] Save ECM data to memory card on the
Key Operator Mode Screen will be dimmed and cannot be selected on the copier without the remote
diagnostics activated.
Key Operator Password Entry Screen Key Operator Mode Screen 1
Key Operator Mode 13-3
Key Operator Mode
To the Key Operator (continued)
How to Access the Key Operator Mode
1 First, be sure the copier power switch is OFF.
2 Then, turn power back ON while pressing the [HELP].
The Key Operator Password Entry Screen displays when the 4-digit key operator
password is set by service.
Otherwise, the Key Operator Mode Screen displays without the password
requirement.
3 If the Key Operator Password Entry Screen is displayed, use the keypad on the
touch screen to enter your 4-digit key operator password; then touch OK, to display
the Key Operator Mode Screen. (See note.)
If the key operator password is not valid, check with your service representative.
4 To display menus [11] to [13] of the Key Operator Mode Screen, touch the lower
arrow key. To return the menu [1] to [10] of the Key Operator Mode Screen, touch
the upper arrow key.
5 Make setting changes from the Key Operator Mode Screen, as described on the
following pages.
NOTE: If an invalid Key operator password is entered, continue by entering the valid 4-digit password.
13-4 Key Operator Mode
Key Operator Mode
Function Menu Map
FUNCTION MENU SUB FUNCTION MENU AND SETTING OPTIONS
[1] Initial setting [1] Copy mode: [RADF; 1-1; 1-2; 2-2; 2-1]
[2] Copy density: [AES; manual]
[3] Lens mode: [AMS; ratio 0.33~4.00]
[4] Paper tray: [APS; trays 1, 2, 3, 4, 5, or Multi-sheet bypass tray]
[5] Output: [sort; group; staple-sort]
[6] Staple: [Normal 1 position left; Normal 1 position right;
Normal 2 positions left; Normal 2 positions right; Upsidedown
1 position left; Upsidedown 1 position right; Upsidedown 2
positions left; Upsidedown 2 positions right]
[7] Image scan: [Normal mode; High mode; Very High mode]
[2] Lens mode ratio [User Set ratio]
[3] ECM [1] ECM Password and User name setting
[2] ECM Count limit setting
[3] ECM Count Reset
[4] ECM On/Off Setting
[5] Copy-Limit-reached effect
[4] Lock/delete [1] Lock Job memory
job memory [2] Delete Job memory
[5] Paper type [Recycled; Colored; Letterhead; Special; Labels; Invoice; Legal;
Ledger; Blank]
[6] Control panel [Dimmer; Brighter]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[1] Weekly timer On/Off setting
[2] Summer time setting
[3] Date & Time setting
[4] Timer setting
[5] Timer action On/Off setting
Feb 22, 2013 | Konica Minolta Copier Toner 7055/7065...
Cannot connect to pocket data and i cannot open my gprs in 5200 nokia!! tnx
hi! nothing to worry ! these are the simple steps to solve ur issue! there are two kinds of possibilities first from ur side and other from operator side! u need to activate gprs facility for ur num from the operator! activate gprs in ur num with ur phone with ur operator! ask the details to activate gprs in ur operator side! it will take maximum 48 hours to clear problem in operator side! that enables from the operator side to access gprs ! then coming to ur side problem! first clear all ur internet settings that u already received! then ask ur operator for gprs settings ( each operator has some msg code's to get gprs settings) then after received the settings set as default setting's by change in phone's browser setting's. then activate gprs plan based on ur requirement ! after the confirmation msg that after the activation of gprs! then switch off and ON ur phone! that's it! open ur phone's browser and start browsing! still hav problem try to call customer car number for ur operator! that's it! Rate me if u like!
Jul 17, 2011 | Nokia 5200 Cellular Phone
I need operator code to continue voiceslink on mobile.plz.
i want to operator code to continue voiceslink on mobil plz
Apr 28, 2011 | Computers & Internet
B6300n Printer: Hello i have oki B6300 printer and its showing e...
Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Action: Please reference this photo as a reference for the up, down, left, andright keys, when performing the following procedure. Step#1: Turn on power, press the left and right arrow buttonssimultaneously,, release both buttons then press the online button to get intothe DIAG. Menu Step#2: Press the down arrow button twice the operator panel willdisplay Diag.Menu Adjustment Step#3: Press the right arrow button the operator panel will displayAdjustment DC131 NVM R/W Step#4: Press the down arrow button the operator panel will readAdjustment DC132 Set Serial Step#5: Press the right button the operator panel will read SerialNumber XXX Record this serial number SYS1: XXXXXX Step#6: Press the Down Button 24 times. The operator panel should readDC132 Set Serial Target PWA SYS1 Step#7: Press the Select button Operator display Enter Serial No. 000000 Enter the serial number thatyou recorded in step#5 Step #8: Press the select button operator display Re- Enter Serialnumber XXXXXX enter the serial number from step #5 again. Press Select Step #9: The operator panel will displa Note: The Operator will now display "DC132 Set Serial NumberCompleted". Step #10: Press the left and right arrow button, release both buttonsthen press on-line button to get into the Diag MODE Step #11: The operator panel will display Exit Diagnostics Incomplete Exit Step#12: Press the down arrow button the operator panel will read ExitDiagnostics Complete Exit Step #13: Press the select button the operator panel reads Complete Exit If OK Press SEL Step #14: Press the select button the operator will read Please Reboot Printer (103-208) --Power the unit OFF Wait three seconds then power the unit back ON.Operation is now complete.--
May 17, 2010 | OKI B6300n Printer
Need ecm code for konica 7055 or a reset code is there an override code?????
Key Operator Mode
To the Key Operator
Key Operator Mode
requirement.
following pages.
Key Operator Mode
Function Menu Map
[3] ECM Count Reset
Ledger; Blank]
contrast
[7] Key operator
[5-digit number]
Tel. No.
[8] Weekly timer
[4] Timer setting
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 23, 2009 | Konica Minolta Office Equipment & Supplies
Print test
Step Press Displayed Result Notes
1. Install the ribbon, load paper, and power on the printer.
2. NOT READY Printer must be in NOT
READY mode to access
the tests.
3. OPERATOR MENU
UNLOCKED
Unlocking ENTER key
allows you to test the
printer.
4. OPERATOR MENU
PRINTER CONTROL
First of series of
configuration menus.
5. OPERATOR MENU
OPERATOR PRINT TESTS
Advances to the Operator
Printer Tests menu.
6. OPERATOR PRINT TESTS
PRINTER DEMONSTRATION*
Advances to first option in
Operator Printer Tests
menu.
7. OPERATOR PRINT TESTS
[TEST NAME]
Cycles through list of
tests. Stop when your test
displays.
8. OPERATOR PRINT TESTS
[TEST NAME]
The test you selected
starts printing.
9. NOT READY The printer test stops
printing.
Stop
Scroll­ + Scroll¯
Menu
Scroll­ UNTIL
Enter
Scroll­ UNTIL
Enter
Stop
Let me know if you need any other help with this. I carry all parts and refurbished units and offer free techincal support as long as the parts ordered thru us.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
rcardenas@mrp.to
Jun 24, 2009 | IBM 6400-I2S Matrix Printer
Sharp SF 2030 Copier ,need reset operator key code
First you need to know the key operator code, you can display it by pressing [C][INTERUPT] [0/ZERO][INTERUPT][22][START][13][START] then the display will shows you the 5 digits key operator. After you know the key operator code, you can go to User program, this is done by pressing [C][INTERUPT] [C] then input the key operator code, when entry is complete "P" will appear in the quantity display. Input 19 then START, input the new code and press START. To exit user program press CA
Jun 04, 2009 | Sharp SF 2020 Copier
Craftsman chain drive opener won't stay down
Check the down limit:
If the light bulb(s) on your operator are on the front and/or back, the limit adjustment screw is on the left side of the operator (looking from the back of the operator and facing the garage door).. If the lights are on the sides of the operator then the limit adjustment screw is on the left side (looking from the back of the operator and facing the garage door).
Check the up and down force:
On your operator (the box that hangs from the ceiling). If the light bulb(s) on your operator are on the front and/or back, the force adjustment screw is on the back of the operator. If the lights are on the sides of the operator then the force adjustment screw is on the right side (looking from the back of the operator and facing the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Jan 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sokkia OM5 Optical Micrometer, metric for B20, Logo
Top Sokkia Measuring Tools & Sensors Experts
Vuk B
Carlo Birocco
Carlo Birocco
Level 1 Expert
Are you a Sokkia Measuring Tool and Sensor Expert? Answer questions, earn points and help others
