Question about Amana ALW480DA Top Load Washer
How to remove pulley from pump?
I removed the three hex bolts from the motor should that not be adequate to remove the pulley? It will not budge. Model LwD70AW Seril R9801056158 i just clicked something on the bottom because I can't find my model
  • 114 Answers
Your question suggests you are trying to remove the pump pulley. This pulley is not removable. The motor pulley should have a set allen screw in it to release.
Posted on Sep 27, 2007
SOURCE:
Changing power steering motor
Remove the serp belt. Use a power steering pump pulley remover to remove the pulley. Remove the three bolts that hold the pump to the bracket. Rmove the high pressure line and the return line.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Jul 29, 2012 | 1994 Ford Aerostar Extended
How do I get the pulley off that is in the way of ONE of the water pump bolts. The pulley has a allen wrench fastener in the center. I tried turning it left and right and it will not budge. There are...
I've gone as far as loosening the motor mounts and raising the engine with a jack. You still have to shoot through the wheel well with a long extension and socket for some bolts on that side.
Dec 05, 2010 | 1995 Oldsmobile 88
How do you remove the timing belt cover on a 1995 VW Golf.
What is needed Tools: 6mm and 8mm allen wrench socket, 5mm allen wrench. 8mm, 13mm, 19mm socket and ratchet. 10mm combination wrench. Long ratchet extensions (at least one 6in, more are helpful). 5inch Wheel puller (for main shaft pulley). (Some models may need a special spanner tool to adjust the timing belt tensioner) Parts: 2 gal of anti-freeze mixed with distilled water. All three V-belts. (Alt, A/C, P/S) $32.95 New water pump top. $91.91 New gasket for WP. $9.13 New timing belt. $26.13.
Procedure:
Remove battery cable (either power (+) or ground (-)) remove alternator remove A/C remove power steering pump .Remove water pump pulleys remove main shaft pulleys remove timing belt covers remove A/C mounting hardware remove timing belt (don't turn any of the wheels its connected to) replace timing belt adjust belt tension remove water pump face put on new gasket and new part.
Leave pulleys off. replace bottom timing belt cover, replace crank shaft pulley, replace steering pump, replace A/C, put small belt on A/C (hang loose) put large belt around A/C, Main and water pump pulley. put middle size belt on Main water pump and power steering pump reattach bolts for the steering pump pulleys put alternator back on adjust all belts. connect battery
Problem areas:
Main pulley: There are 4 6mm hex head bolts. These must be removed. The main 19mm hex head can be used to turn the engine it the timing belt slips and you have to readjust the timing.
Putting on new belts: This can be a real pain if you get VW belts. The adjustments won't give enough to put the belts over the edge so the easy way is to remove the pulley on the water pump. Then its real easy.
Timing: If you turn the wheels that the timing belt goes on you will have to reset the timing. Mark the timing points with something like whiteout so its easy to see. The timing mark on the toothed gears are small dots. The timing mark for the crankshaft is a small cut on the outer pulley. When its aligned with the intermediate wheel timing mark (there is an arrow on the cover as a hint) should intersect as viewed from the right wheel well. The camshaft timing mark should line up with the top of the engine near the front.
Power steering pump: It is held on with lots of bolts. One is in a channel that is hard to see but can be found with a 6" extension. If you look at the pump you will see three bolts that go into the housing. This should give you an idea where the forth is.
May 01, 2010 | 1995 Volkswagen Golf
Haier HLP21E belt broke. My machine was overloaded. How do I replace it?
put new belt on big pulley first then roll in over on smaller one
Mar 29, 2010 | Haier HLP21E Top Load Washer
I need directions for changing the power steering pump
  1. Disconnect battery ground cable, then remove exhaust manifold heat shield.
  2. Disengage power steering pump reservoir hose from pump bracket and engine lifting bracket, then disconnect return hose and reservoir pump hose from pump.
  3. Allow fluid to drain into a suitable container, then raise and support vehicle.
    1. Remove lower belt guard, then rotate drive belt tensioner clockwise as viewed from direction shown, and remove accessory drive belt.
    2. Lower vehicle, then remove traction assist module bolts and position module aside.
    3. Rotate power steering pump pulley to gain access to each pump front mounting bolt, then remove three front bolts and one rear bolt and lift pump from vehicle.
    4. If it is necessary to separate pulley from power steering pump, proceed as follows:
      1. install power steering pump pulley remover T69L-10300-B, or equivalent, on pulley hub.
      2. Clamp hex head of tool in a suitable vise, then hold power steering pump in place while turning tool nut counterclockwise. Do not apply inward or outward force on power steering pump shaft, internal pump damage may result.
      3. Slide pulley from power steering pump shaft.
    1. Reverse procedure to install, noting following:
      1. If pulley and power steering pump were separated, install pulley on pump shaft using power steering pump pulley replacer T91P-3A733-A, or equivalent. Ensure threads on end of tool are fully engaged in power steering pump shaft; after pulley installation, ensure end of shaft is within 0.010 inch of being flush with pulley surface.
      2. When placing pump in vehicle, install rear mounting bolt first, but do not tighten until three front bolts are in position.
        1. Rotate drive belt tensioner clockwise as viewed from direction shown to install accessory drive belt.
        2. Refill power steering fluid reservoir and bleed system.
Oct 08, 2009 | 1996 Ford Contour
Cant remove power steering pump.
Check for any hidden mounting bolts. There may be a rear mounting bolt. Make sure you have removed all mounting bolts. Recommend buying a Chilton's manual from Autozone.
May 24, 2009 | 1999 GMC Suburban
95 cadillac devill water pump replacement
Per Chilton's Repair Manual: You're dealing with aluminum so pay careful attention not to exceed recommended torque.
4.5L And 4.9L Engines
  1. Disconnect the negative battery cable.
  2. Drain and recycle the engine coolant.
  3. Remove the air filter assembly. Disconnect and remove the coolant recovery tank.
  4. Disconnect and remove the cross brace.
  5. Remove the water pump pulley bolts.
  6. Remove the serpentine drive belt and the water pump pulley.
  7. Remove the water pump-to-engine bolts and the pump.
84203050.gif Water pump assembly—4.5L and 4.9L engines
To install:
  1. Clean the gasket mounting surfaces.
  2. Place a new gasket over the water pump studs.
  3. Install the water pump. Tighten the water pump bolts as follows:
    1. Water pump-to-engine Torx® bolts to 30 ft. lbs. (40 Nm)
    2. Water pump-to-engine stud nuts to 5 ft. lbs. (7 Nm)
    3. Hex head bolts to 30 ft. lbs. (40 Nm)
    4. Remaining hex head bolts to 5 ft. lbs. (7 Nm).
  4. Install the water pump pulley. Install the water pump pulley bolts finger-tight.
  5. Install the serpentine drive belt.
  6. Tighten the water pump pulley bolts to 22 ft. lbs. (30 Nm).
  7. Install the cross brace.
  8. Install and connect the coolant recovery tank. Install the air filter assembly.
  9. Connect the negative battery cable.
  10. Fill cooling system and check for leaks. Start the engine and allow it to come to normal operating temperature. Recheck for leaks. Top-up the coolant.
May 06, 2009 | 1995 Cadillac DeVille
99 gmc suburban
Fan clutch screws on to the water pump. You can loosen it with a big adjustable wrench (it is about 1 1/2" or 1 9/16" hex). Leave the bolts for the pulley in so you could wedge a screwdriver under a bolt head to keep the pulley from turning. Give the wrench a hard **** to loosen and it should turn off by hand. Right hand threads so you will be turning it counter clockwise to remove.
Aug 08, 2008 | 1999 GMC Suburban
SAV205DAWW Maytag Washer Belt Replacement Instructions
This is specifically for a Maytag Legacy SAV515DAWW, but may apply to the whole Legacy line.
There is only one drive belt on this washer and it is not accessible directly from the bottom as a pan forms the bottom of the case. All work can be performed through the bottom front panel, once it is removed.
Before one starts, an overview is helpful. The motor for the washer is bounted just behind the access panel. Attached to the shaft at the motor bottom is the drive pully for the drum belt, along with the belt tensioning pully and spring. Below that is the pump assembly attached by three screws in the shafts, which are accessible only from the bottom. What you must do, is remove the pump by unfastening four hex-head bolts, then rotate the motor and pump assembly bottom upwards to the front, so the bottom of the shafts containing the torx head screws fastening the pump are accessible.
While everything is all together it is helpful to notice that the far support for the pump is in almost a direct line with the motor shaft and the tum pully shaft. When you reassemble the components, this vertical pump support must go between the belt. As you face the washer, the tensioning pully will ride on the outside of the right side of the belt.
1. Unplug the washer.
2. Pull it out from the wall, so it may be tilted back at about a 45 degree angle and will not fall foreward.
3 Remove the two hex head screws on the right and left bottom front of the washer. The panel should lift out from the bottom, Two pins hold the top of the panel in.
4. Examine the mechanism as described above.
5. Detach (Unhook) the tensioning pulley spring from the front of the bracket above the pump..
It is not necessary to remove any of the hoses. There is adequate flexibility and slack for replacing the belt.
6. Remove the four hex bolts attaching the galvanized motor bracket to the frame.
7. Rotate the motor back, so the pump bottom faces the front.
8. Remove the three torx head screws in the pump support arms.
9. Detach the pump from the motor. Gently pry it off or gently strike the body of the pump away from the motor with a soft faced mallet.
10. Place the new belt on the motor pully and reinstall the pump, so the leg closes to the tub pulley is inside the two sides of the belt. Reinstall the pump screws in the plastic shafts.
11. Reinstall the motor and fasten the bolts.
12. Make sure the tensioning pulley is to your right of the belt and then side your hands to the rear and slip the belt under the drum pulley and completely around it.
13 Feed the belt onto the drum pulley. I did this by reaching back with my left hand and feeding the belt, coming from the motor pulley, into the drum pulley, then slowly rotating the right side of the drum to me with my right hand.
14 Check to ensure the tensioning pulley is to the right of the belts, then reattach the spring, so the pulley forces the righthand belt to the left.
15. Set the washer upright, open the lid and rotate the drum around twice using your hands. This will help seat the belt on the pulleys and ensure the drum is not stuck.
16. Make sure the cycle switch is pulled out (set to off) and plug the power in.
17. Set on a wash cycle and looking in the bottom , check for proper operation. If the motor appears to be stalling, immediately turn the unit off. Rotate to tub some more by hand and test for operation. If it still doesn't work, see help, your problem is more than just a belt!
18. If everything seems to work, toss in a test load of laundry and pat yourself on the back for being able to save some money!
Mar 24, 2008 | Maytag Legacy Series Top Load Washer
Amana washer belt replacement
Steps for Replacing the Belt
Tools needed:
Nut driver or socket set.
Torex screw driver.
1. Unplug the power cord from the
electric socket and remove the
front panel.
2. Disconnect the power coupling
from the motor.
3. Disconnect the 2 hoses from the
pump. Be aware that the pump
still contains between 1 and
2 cups of water, and it WILL
all come out.
4. Remove the belt from the idler
arm, pushing the belt UNDER the
idler arm. Yes, your hands will
now be quite greasy.
5. Remove the belt from the main
transmission by pushing the belt
under the transmission pulley.
6. Remove the 4 bolts that hold the
motor assembly to the washing
machine body. Remove the motor
assembly with belt from the
washing machine.
7. Turn the motor upside-down. With
the torex screwdriver, remove the
3 bolts that hold the pump to the
motor. Remove the pump from the
motor (in my case, the motor shaft
fit into a slot in the pump; while
it was snug, it was not melted or
rusted, and did just come out).
8. Clean pump and motor as desired.
9. Install new belt and reverse the
steps to re-install.
Nov 07, 2007 | Amana ALW480DA Top Load Washer
Amana ALW480DA Top Load Washer Logo
148 people viewed this question
Top Amana Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Virgil Watts
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
