Hitachi 1080 ultravision tv.its run for half a second and then shuts down and has blue flashers for 3 times.
  • 102 Answers
This sounds like a capacitor failure. Something that is all too common in the last 10 or so years. A good repair shop can probably fix this for $100 to $150. It's up to you if you think it's worth it or not.
Posted on Oct 16, 2013
4 Suggested Answers
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
yankeegurl
  • 121 Answers
SOURCE: PROJECTION TV HITACHI ULTRAVISION COLOR CONVERGENCE PROBLEM
it sounds like your blue convergence ic is getting weak you need to replace the ic's STK392-110 and you should replace both because when 1 is bad the other will go real soon. They are inexspensive at the sight I posted and you will also get free tech online support if you purchase them there.
http://servicemanuals.vstore.ca/
Posted on Apr 13, 2008
Slinteriors
  • 8617 Answers
SOURCE: Panasonic cinema vision 1080 hd projection tv shut off and red
thats the error code for the convergence ICs. Replace both STK392-110 Convergence Ics and the 2.2 ohm resistors. You can get the Panasonic rear projection Convergence repair kit #1 at the following link which contains the two ICs and all six resistors plus step by step instructions with pictures so you can do the repair yourself.
Posted on Feb 15, 2009
Tv is not coming on.It run for half a second and shuts down and then it has blue flashers for 3 times .
These flashes are fault indications, and are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. This will make troubleshooting easy. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 16, 2013 | Hitachi P50H401 50 in. Plasma HDTV
Hitachi Ultravision tv model number: P50S602 When I turn it on the blue power button comes on and the sound comes on for about 2 seconds then the sound turns off and the blue light flashes three times...
Lights flashing is code talk .So call a TV repair guy and ask him good one will tell u what the light code means over phone cause he'll wanna sell u parts or get your business for service .
Jul 12, 2012 | Hitachi P50H401 50 in. Plasma HDTV
My hitachi p50s601 turns on for 1 second and then goes completely blank and the blue light flashes 3 times repeatedly.what do i do?
3 Blinks means one of the buffer boards is bad. The way to test it is to unhooking one SDR board at a time, and see if half of your screen comes on properly. If the SDR-D board is bad the bottom half of the screen won't come on when you remove the board. Send it out for repair (less expensive then buying a replacement board) or search for a refurbished board. If your non technical provide this info to a service tech and ask for an estimate. Cost will be moderate. Hope this helps you. Jon
Oct 25, 2011 | Hitachi Ultravision P50S601 50 in. Plasma...
Tv turns on for a few seconds then shuts off and the blue power light blinks.
Mine never turned on but the blue power light would blink.I disconnected the upper y buffer and got light on the bottom half of screen and the blinking stopped.I have the upper board on order and I think this will fix my problem.There is a blink code somewhere,just count how many blinks.Start pulling connectors from power supply and when it quits blinking you've found the one,could also be the power supply with bad cap.
Jul 14, 2011 | Hitachi Ultravision P50S601 50 in. Plasma...
50 inch Hitachi Ultravision LCD Rear Projection Television
Hitachi has had problems with their light engines. Very expensive. Contact Hitachi as they may give you consideration even if this is out of warranty.
Apr 15, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Blue tint on half the screen
Sounds like the lamp is not far from going out.... I would get that replaced before you have no tv at all. It will go from semi blue to burned out lamp pretty quick.
Dec 10, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision has blue streak on right side of screen.
convergent systems.. I callled Hitachi....
it cost $600 to relpace the part... all 3 colors red yellow blue,.... tech took the part out and will replace it in about 3 or 4 days.
I was told by technician that it was a very very good tV in fact he said he would buy it from me for $300 and take it away.. I am considering that ... but a new one with Picture in picuture will be 2000 or more
Apr 06, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Projection tv - Hitachi
sounds like you need to do convergence.
Feb 21, 2008 | Televison & Video
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
