Question about Hitachi P50H401 50 in. Plasma HDTV
Tv is not coming on.It run for half a second and shuts down and then it has blue flashers for 3 times .
    Top Expert:
  • Hitachi Master
  • 74,211 Answers
These flashes are fault indications, and are called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. This will make troubleshooting easy. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Posted on Oct 16, 2013
Hitachi 1080 ultravision tv.its run for half a second and then shuts down and has blue flashers for 3 times.
This sounds like a capacitor failure. Something that is all too common in the last 10 or so years. A good repair shop can probably fix this for $100 to $150. It's up to you if you think it's worth it or not.
Oct 16, 2013 | Televison & Video
My KP-51HW40 clicks off after running for a period. The red power light blinks when it goes off but screen stays dark. When TV is shut off for a while it restarts and runs fine. The "On"...
KP-51HW40 shuts off due to incorrect white balance and blue arch lines is an evidence of that incorrect white balance. I hope tv standby red light would flashing 5 times then 3 seconds pause and again 5 times when tv shuts down.
This is rear projection tv that has three picture tubes (red-green-blue) inside to generate picture that projected at front screen. These three picture tubes must be drive with correct drive voltage to produce good picture of each color.
Solution for your tv problem is Screen Voltage adjustment that can be done easily if you are handy with electronics stuff repair.
Let me know your expertise level to guide you more and if you feel unconformable by tv repair then local tv repairman will help you to adjust white balance in tv.
Hope these info will help you.
Let me know if you have additional questions.
Thanks.
Nov 05, 2010 | Sony KP-51HW40 51" Rear Projection...
Samsung 56 in dlp shuts off
You need to eliminate the lamp door (blue) switch from the equation. Wrap the wire (blue/white) around in for the moment to lock it in an up position. Also, have a look at your lamp ballast (see picture). Look to see if the capacitor is swollen on top. If it is, change the ballast and power supply.
Apr 27, 2010 | Samsung HL-T5076S 50 in. TV
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Sony 2002, kpws500
Minium is the green picture tube need to be replaced, if you can take the front cover and access panel off there is a control with 3 focus and screen controls.
you can adjust the 3 screen controls to possibly get a little more time out of it before the crt's need to be replaced. careful if you turn them down too much there will be no picture, and if you turn them too high the tv will go bright and shut off
Apr 13, 2008 | Sony KP-57WS500 57" Rear Projection...
JVC Projection TV shuts down by itself.
47" JVC TV TURN THE POWER ON THERE ARE SOME BLUE LIGHTS THAT COME ON BUT NOT THE TV. THEN AFTER A FEW SECONDS THE BLUE LIGHTS FADE AWAY.
Dec 15, 2007 | Toshiba 50H81 50" Rear Projection...
Shuts down
it is due to problem in red cideo section. solution 1 supply to red video output& output itself 2 crt base loose 3 connector loose 4 red video sigal line from chroma ic to red cathode of crt. 2 red
Nov 13, 2006 | RCA 27V520T 27" TV
Blue screen
It sounds like the high voltage distribution block but that is not the cause of your problems,the tuners you talk about are the picture tubes ,one for each color,the blue picture tube was arking and you got lucky and got 6 more months of use, it and might have corrected when you drop it but now is the red doing it and you need to do the same but it might not work this time,dont be surprise.Be carefull while trying things in the back,there are high voltages there and is not safe unless you are familiar with tv service.
Sep 19, 2006 | Sony KP-61V45 61" Rear Projection...
Hitachi P50H401 50 in. Plasma HDTV Logo
20 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
