Question about Music
Roland fp 8 problems
Sound level is low
5 Suggested Answers
  • 101 Answers
SOURCE: I have a Roland FP-8 that I used for performances.
you have some internal components bad audio output IC, capacitors, driver transistors etc. your doing nothing wrong.
maybe just don't leave it on if your not playing it. Heat kills Electronics.
Posted on Jan 01, 2011
SOURCE: Very low output
hi,chdavis14 on Mar 15, 2009.the problem comes from the two electrolytic capacitors at the signal exit of the mainboard, or soundboard if you like. Go and have them changed at an experienced technician because they are in a difficult spot.
Posted on Jan 02, 2011
sonicboomele
  • 1557 Answers
your sound process digitaliser has burned out the crackling should have warned you as to the fault and had it replaced (fixed) right away this is a simple repair but does need to be done by an electronics tech
AlexMcG
  • 27 Answers
SOURCE: hi where can i get a service manual for an fp-8
Here's a link to the Owner's Manual
for a service manual, you're probably going to have to contact Roland directly, since they don't even list the fp-8 on their website. Service manuals for their other products only run about five bucks for a hard copy, i believe. I'm sure you can get to the right place through here: http://www.rolandus.com/corporate/contact_us/
Posted on Mar 21, 2011
In my gr 33 the volume is very low. mistakenly i did a factory reset after that the volume is becomes very very low. Any solution for this problem?
There is probably both a global volume and individual program violume as well. One or both may have reset to a lower level and need to be turned up. It's also possible that the general output has a setting for line level or instrument level, which may be software controlled. Take a look through your manual to find these settings and adjust to suit.If all else fails, contact Roland Customer Service at this link for help.
Roland Company Contact Us Contact Us
Sep 15, 2016 | Roland Gr33 Guitar Synthesizer
How do I fix a Roland Digital Piano FP-8 that has refused to play sounds despite the fact that it displays lights?
If everything lights up and responds to button pushes like normal, and you've done a hard reset as described in the manual, check to see if you have sound out of the headphone jack. It's most likely not a user serviceable problem and will need to go to the shop, but it will probably be the output amp rather than the main board.
Mar 07, 2015 | Roland Fp-8 Digital Piano Email Us For A...
Roland FP-8 replacement hammers do not match the original hammers
buy some strips of velcro with the tape on one side..cut out your pieces and mount them to the hammer..
Jan 08, 2014 | Music
Hi where can i get a service manual for an fp-8 roland digital piano?
Mar 19, 2011 | Roland Digital Piano FP4 Black With Stand...
I have a Roland FP 1 digital piano, serial #AL21141N. It has gradually quit putting out sound through the speakers. At the onset of the problem, I could fit it by jiggling the 1/4" speaker plugs,...
I first would suspect the switches on the eadphone jack. Normally these cut off the speakers when headphones are plugged in. These jacks and the switches are really weak, poorly made, and easily broken, especially if headphone cord gets yanked.
Jan 14, 2011 | Roland Digital Piano FP4 Black With Stand...
I have a Roland FP-8 that I used for performances. I have noticed some static in the past couple of weeks in the sound. Now it doesn't play at all. The display lights up normal, and the buttons work and...
Jan 02, 2011 | Roland Digital Piano FP4 Black With Stand...
Key won't come back up on Roland digital piano
Roland FP is a nice keyboard but has a known problem on cracking key weights. There is a counter weight under each key to push the key upward. There are two sizes of weight beams, longer one for white keys and shorter one for black keys. Roland did not make the original weight beams strong enough to last. They will crack and eventually break. When it happens, the key will stay down. Fortunately, they can be easily replaced.
Roland FP-8 has 4 black screws at the bottom on each side end. Remove the screws, flip the ends up and expose the interior. Near the hinge of the problematic key, carefully ply open the hinge tabs and remove the key from the hinge. You will find a weight beam under the key. Remove and inspect the weight. There should be a metal wrapped in a plastic beam. If the metal part is missing, find the missing part and replace with a new beam. You can order weight beams from Roland. It costs about $10 each plus shipping. Put everything back in the reversed order.
Oct 01, 2009 | Music
I need a replacement music rest for a Roland HP-5000s. Where can I find one?
Start by calling support at one of the numbers at this site:
http://www.rolandus.com/support/?tab=contact
They can steer you to to where you can order the part.
Sep 12, 2009 | Roland Music
Very low output
Mar 15, 2009 | Music
Music Logo
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
