Question about Garden
My Gravely ZT1640 mower will not start. This morning it did turn over but not in the normal way. It seemed like it wanted to start so I thought the battery needed charging. After charging the battery I couldn't get the engine to turn over at all. Help!
brainyass
  • 242 Answers
SOURCE: john deere zero turn mower
Check spark plug and ensure choke is set correctly. Choke all the way out to start, then push back in. Make sure gear selector is in neutral and blade not engaged too.
Posted on Oct 24, 2008
trippssmengi
  • 76 Answers
SOURCE: new battery won't take charge
Hello, and how are you. It could possibly be the charger itself If everything else seems fine. If all wire connections at the starter and the battery are tight, clean and no cuts any where on the wires them selves.I would try a new charger. Another thing is you could see if someone could check the wires with a meter to see if there are any unnoticeable breaks in the wires.
Posted on Jan 11, 2009
  • 6 Answers
SOURCE: Mower won't turn over
Keep it in the kitchen over night. Or anywhere that is environmentally controlled for that matter. Should start right up as soon as you get it outside.
Posted on Jan 31, 2009
  • 21 Answers
SOURCE: Swisher will not start with key.
try changing the soloniod
Posted on Jul 28, 2009
  • 202 Answers
SOURCE: need the diagram so to replace missing wires on
Should be able to get your info here, with model and serial number. Go for the service manual.
http://apache.ariens.com/cgibin/ctrg0005?SESSIONID=gsw0uz210g3q1n45lcz3mtig&site=gravelys
Posted on Dec 13, 2009
I have taken the lug nuts off back tire of my mower and it won't move to slip off and it is in the air off ground.
Get a good size rubber mallet and hit it on the back side, or you can use a two pound hammer and a block if wood. Don't hit directly in the metal rim with a metal hammer
Sep 19, 2014 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
How do I put a replacement belt on a gravely promaster 200?
Any Gravely or Ariens dealer can help you with this... If you have your model number and serial number you can order it online
Sep 11, 2014 | Garden
Gravely only clicks wont start but hour meter works
Sounds like a low battery, enough juice for the hour meter but not for the starter
Aug 14, 2014 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Gravely zero turn lawn mower
are you sure you have the wire from the battery to the ignition key on?
Did you accidently knock the wire from the ignition key to the Starter relay off?
Aug 23, 2013 | Garden
Engine dies when Blade is engaged
It sounds like the seat safety switch is the problem. Tilt up the seat and make sure the plug to the seat switch isn't loose or off completely, and that the switch is firmly mounted. If everything seems ok, remove the switch and test it with a multimeter. The circuit between the switch terminals should close when you press in the button. If not, replace it. Good luck!
Jun 04, 2010 | kawasaki 2010 Gravely Zt 42 Xl Zero Turn...
Jan 31, 2009 | Toro Lawn Mower With Toro Power Tools
Mower
If it sat for some time without running aslittle as 30 day the fuel is probly stale and needs to be drained and the carb cleaned and possibly a new spark plug
Jan 31, 2009 | Toro Blowers Rake and Vac - Electric...
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
