Question about RCA Vh126n Antenna Auto-rotator With Remote vh126r -
Just purchased a new antenna & also purchased an RCA VH126R Antenna rotator, it is all installed on the roof. The remote control box works with the remote controller, but it iwll not make the antenna on the roof move at all. Everything is done proper, as I said the box works fine with the remote control but will not move the antenna at all. Would appreciate your assistance on what is wrong. These are both new, the antenna, and the antenna Rotator VH126R. Thank you
2 Suggested Answers
jerry_kramer
  • 3904 Answers
SOURCE: rca vh126r rotator has stopped working
This should have a reset to it. If not then it got thrown off in the gearing and my have to be manually reset by taking it apart.
Posted on Apr 14, 2014
Why will my digital antenna not rotate using either the remote or manual button?
If the motor has not been turned for a long time the grease on the gears may dry out and freeze the motor.
Mar 19, 2015 | Lava HD-2605 Ultra with G3 Control Box...
My 9537 lights up and goes thru the numbers 0-360 but the antenna does not movmove
Has this installation previously worked or is this a new installation?
Sounds like it may be in the rotator itself.
Dec 28, 2014 | Channel Master CM 9537 Antenna Rotator...
My antenna won't rotate and I now receive only local channels
There could be a problem with the wires going from the control box to the rotator, or the remote itself
Good luck,
Marty
Apr 22, 2014 | Digiwave ANT-3045 Remote Control Outdoor...
Rca vh126r rotator has stopped working
Apr 14, 2014 | RCA VH126N Programmable Antenna Rotator...
Rca vh126r troubleshooting
Replace remote batteries.
check wire connections to motor.
There may be a fuse that has blown on the control box?
Growing up our antenna rotator gears stripped themselves and the antenna just spun freely. For many years we just tied a light rope to one end of the antenna and basically went outside and turned it from the ground by pulling the rope and tying the other end to a garden steak. We didn't have much money till after us kids grew up and moved out, my dad got satellite TV. Good luck!
No channels found with automatic channel search
You may need a new antenna.  Go to www.antenna.com for info and help.
May 30, 2009 | RCA Analog (RCA) to Digital (VGA)...
Rotor not turning antenna
Most rotors have a brake, if yours has one, you have to hold the brake down then rotate.
Jan 31, 2009 | Channel Master 9521A Remote Control
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Jul 16, 2008 | RCA Universal Remote Control
2006 RCA TV Digetal Receiver
NBC newsperson said I should check nbc.com to learn
what to do for the change in February. Where is it ??
You want my solution ? Improve your web site.
Feb 23, 2008 | Televison & Video
RCA Vh126n Antenna Auto-rotator With Remote vh126r - Logo
37 people viewed this question
Top RCA Electronics - Others Experts
ray gallant
L Pfaff
L Pfaff
Robert A. Watson
Robert A. Watson
Are you a RCA Electronics - Other Expert? Answer questions, earn points and help others
