Question about Locks & Locksmithing
My onity th24 lock flashes green red when card is in lock
2 Suggested Answers
wcilocktek
  • 7 Answers
SOURCE: I have a Onity Advance
I am going to guess that this lock is a common door.
The flashing green and staying unlocked indicates that this lock is in "Office Mode"
If a master key has office mode capability, and the lock program has office mode capability, the lock can be permantly unlocked by "double dipping the key". It can be put back in to regular mode by "double dipping the key" again. This will only work if the master has the "office mode" capability.
Thanks,
Ken Croston
407 814 4974
www.ElectronicLocksmith.com
Posted on Jul 26, 2011
My Guest key cards are still working after check out, how do I disengage previous guests key?
Hello, Kristin -
I assume you own or manage the hotel where the key card problem exists. If so, contact the manufacturer of the key card system
This is the link to the Onity Contact Us web page:
http://en.onity.com/Pages/ContactUs.aspx
Best wishes.
Feb 15, 2018 | Computers & Internet
I hear click , but can not lock the door
Need more information. Try lifting up on the handle when you card the lock. A worn or broken clutch assembly is a common issue with older TESA/Onity HT24 locks.
Mar 09, 2015 | Locks & Locksmithing
I have onity lock after using guest key card i am getting green light but handle is not opening door
Listen if you hear a click sound when you get the green light. Try to turn the handle up. If you hear a click, and you can open the door when you turn the handle up, you have a bad clutch kit. If you do not hear a click, then your circuit board needs replaced.
Call if you have any more questions or need to order the parts.
Thanks,
Ken Croston Jr.
407-814-4974
Feb 28, 2014 | Cars & Trucks
Forgot the combination to the lock. Is there a way to retrieve the combination or return it to its factory default combination 1, 2, 3, 4, 5
The instructions below are copied from the programming instructions (page 11):
ERASE ALL PROGRAMMING
(The "out of box" factory default will be restored)
1. At the back of the lock, remove the screw at the bottom of
the lock housing and remove the cover.
2. Take out the battery pack and remove battery power by disconnecting
the battery pack.
3. Plug in the (provided) male shunt connector into the yellow
wire female connector.
4. With shunt connector connected, re-connect the battery
pack. The lock will immediately sound 3 short beeps (if
these 3 beeps are not heard, then restart at step 2).
5. The lock will then sound more slow beeps, 1 beep for every
second it takes to clear the memory.
6. After a few more seconds, the LED will slowly alternate between
flashing red and green--disconnect the yellow wire
shunt connector.
7. The LED will continue to slowly flash green and red for 25
seconds. To enroll Function Cards, proceed immediately
as follows:
• With the lock LED slowly alternating between flashing
red and green, present the Function Card #1
to the lock. The lock will sound 5 slow beeps.
• The lock LED will flash green rapidly. The lock is
ready to enroll the Function Cards.
• Re-present Function Card #1 to the lock. The
lock LED will flash green then red, with two beeps
(indicating the card was enrolled successfully).
• Present Function Card #2 to the lock. Again, the
lock LED will flash green then red, with two beeps.
• Continue to present, in order, Function Cards 3-
9. Each time a new Function Card is presented, the
After the 9th Function card is presented, the lock LED will flash
green twice, sound two beeps, and will then remain silent,
ready for use. Note: If the lock continues to beep after presenting
the 9th Function Card, check to verify that the yellow
wire shunt is disconnected.
Note: If you only wish to use the first 3 Function Cards, simply
allow the lock to "time out" after 30 seconds.
Here is the link to the complete instructions, in PDF form. You will need Adobe Acrobat or equivalent to view them:
http://napcosecurity.com/download/PL3000_WI1280A.04_PROG.pdf
Good luck-and please provide feedback if this helps!
Nov 04, 2011 | Trilogy ALARM LOCK PL3000 Series T3 Prox...
I have 5 brand new TESA Onity locks that will not work after I program the lock.Just blinks red when I insert the key in it.
This page is for Onity's Supplies and Services:
http://www.onity.com/support/supplies-and-services/
It is the only source of contact information that I could find toward solving your problem.
I suggest that you contact them through the phone number listed on this page. For your convenience,
By Phone: 1-800-749-2983
By Email: OnityBusinessServices@utc.com
Jul 27, 2011 | Locks & Locksmithing
I have a Onity Advance lock and the green light is flashing at a very rapid rate. The lock stays in the open position all the time and never goes to the secured position. So you can just press the handle...
Thanks,
Ken Croston
407 814 4974
Jul 13, 2011 | Locks & Locksmithing
Onity lock ht24--In the test mode, what does "FF" mean when keyboard test is run?
Chris, The HT 24 Lock does not have a keyboard so this test is not relevant to your lock. This test feature is for an Onity lock with a numbered keypad.
Hope this helps. If you have any more problems or questions you can call me or send an email through my web site.
Ken Croston 407 814 4974
Nov 03, 2010 | Locks & Locksmithing
Treo 680 charging light flashes red when disconnected from charger
Have you activated phone yet? When phone is activated and in service it flashes green. It's hard to believe it would flash green without a SIM card, as there is no service...unless AT&T is providing emergency service only and you're getting a flashing green which means you're in range of their towers.
Jun 14, 2008 | Palm Treo 650 Handheld
Locks & Locksmithing Logo
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
