Question about Dewalt DC011 AM/FM Radio
Brand new DeWalt Radio. I tried plugging the radio into my welding machine (120v DC) and into my normal wall outlet and the radio will not turn on at all or do anything. I can't set the clock, I can't switch modes. Nada.
SOURCE: Dewalt DW911 jobsite radio
Got mine open.
There was a fuse inside - Replaceable - fixed the problem.
There were no hidden screws, none under stickers or in the battery box like suggested by others, and the 2 magic release screws not so. There are several deep screws requiring a long philips, but the entire seam is glued (why?) so to open the radio I had to hit the body near the seam with a rubber hammer to crack the seam loose once all the screws were removed, comes right apart. Put it back together without glue, just the screws, it will be fine.
Sam. DesertSolutions.net
Posted on Nov 26, 2007
  • 60 Answers
SOURCE: how to connect an ipod to a dewalt radio?
Get a lead of Ebay! 3.5mm jack to 3.5mm jack. Very cheap.
Posted on Nov 28, 2009
SOURCE: Dewalt Radio won't hold presets or clock time
Replace the two AA batteries in the battery compartment.
Posted on Nov 30, 2009
  • 60 Answers
SOURCE: when I shut the radio off the clock and radio
Have you inserted 2 x AA batteries in the back where you charge the Dewalt batteries? there is a cover with a black phillips screw, this is where the AA batteries go for the memory clock & radio presets.
Posted on Dec 04, 2009
SOURCE: when i switch off dewalt dco11 radio the station
Does the clock lose time too? 2 AA batteries under a door inside the battery compartment. Change them, reset time and stations.
Posted on Feb 26, 2010
How do I charge my Motomaster Mobile Power Pack Model 11-1540-2?
It should have a small 120V to DC wall adapter charger with a DC wire / connector jack that plugs into the back of the power pack. Plug the wall adapter into 120V outlet and plug the DC connector jack into the back of the Power Pack. Leave on charge until the unit indicates it is charged fully (several Hours if it was fully discharged).
Nov 20, 2016 | Electronics - Others
I have a Dewalt charger/radio (DC012 type 1) that was plugged into a 240v US outlet. The radio will come on with a battery in and work just fine, but with it plugged in it will not charge or play.
You burned out the AC circuit. Congratz, at least your radio still works. Use it on battery or take it to a radio technician to diagnose if it can be repaired. Presume it's worth.
DEWALT DC012 Worksite Charger Radio
Jun 25, 2015 | Dewalt DC012 Worksite Charger/Radio
Can I power a small appliance with my dewalt
This is what dewalt is saying...The Dewalt 12V/20V MAX work-site charger/radio functions as an AM/FM radio and recharges your 12V/20V Dewalt batteries (batteries not included). The 3-stage charger can recharge your batteries in as little as 1 hour, and the radio can run off 12V/20V batteries for cordless operation
  • 2 AC power outlets offer more versatility for jobsite power
  • Auxillary & USB ports allows for connection to CD, MP3, portable satellite receivers, and other digital audio devices.
  • USB port allows device to be charged via USB when radio is plugged into a wall outlet
  • Class D amplifier, woofers and tweeters provide full range of high and low sound for optimum sound quality,( hope this helps)
Aug 06, 2014 | Dewalt DCR015 MP3 AUX USB 12V/20V MAX*...
Dewalt radio dc 010 will not charge
Check the voltage from the charger, check the socket which it plugs into for fractures and dry joints on the circuit board. Those are the most likely failure points. Have you tried moving the plug around to see if it's a bad connection?
May 12, 2014 | Audio Players & Recorders
My dewalt radio wont turn on
i have put 2 new batteries but cant get radio 2 work
Mar 28, 2011 | Dewalt DC011 AM/FM Radio
Will not turn on has power to it from wall plug
if you place a battery in it and it still doesnt work you have to have it repaired by dewalt because this means you have no connection to power. but if you place a battery in it and it does work you have a short in the cord mostly happens when being pulled or gets snagged. either you or dewalt can fix the cord you jus have to find where the short is cut the cord and splice it back together covering it with electrical tape.
Jan 24, 2011 | Dewalt DC011 AM/FM Radio
Want to change my 110v plug on my dewalt radio to 240v
Your radio must be a import from the U.S.A. Your radio will not work on 240v YOU WILL BLOW IT UP!!! You need a step down transformer 240v to 110v to goto your radio, you will have to do a search on Ebay in Power tools. You sould notice the lead on your 110v radio is not like normal flex as its only single insulated for 110 volts.... Don't put a normal plug on or you may have to call the fire brigade!!
Nov 01, 2009 | Dewalt DC011 AM/FM Radio
Dewalt radio accidently plgged into 240 volt outlet.... Help!!!
There's a good chance they fried it if it's designed to run on a 120v circuit. The main part that turns on the LED might have handled it, but the more sensitive areas were probably overloaded. Does it work with the battery in it?
May 04, 2009 | Dewalt DC011 AM/FM Radio
Emerson Smartset Clock Radio
For the Clock/Radios that are having problems with the clock display and settings. You will have to reset the Clock/Radio's microprocessor. To do this you must unplug the Clock/Radio from the wall outlet and remove the internal battery. You must let the Clock/Radio set with no power for at least 1 hour to discharge the microprocessor circuits. The microprocessor should then be able to reset itself. You can then reinsert the battery and plug the Clock/Radio into the a/c wall outlet. The functions should have reset and be working normally. If this does not solve the problem, try putting in a new battery (CR2430). Before putting in the new battery, unplug the clock radio and remove the old battery and let it set again for a few hours this time to try to reset the microprocessor. If this does not solve the problem (This includes the person with the complete Clock/Radio operation failure) you can call the Emerson customer support at this telephone number 1-800-898-9020. Give them the make and model number of the Clock/Radio. Tell them the problems you are having with the operation of the Clock/Radio and ask them for assistance. I hope this information helps you solve the problems your are having with your Clock/ Radios.
Dec 17, 2007 | Emerson Smartset Clock Radio
Dewalt DC011 AM/FM Radio Logo
43 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rani wadia
Rani wadia
Tom Chichester
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
