Question about Yard Machines 24a 452g729 5.5 Hp Chipper Shredder
Problem with Yard Machines 120312 0158 E1 5.5 Hp Chipper Shredder Briggs & stratton chipper wont start 3 wire from the magneto where should they be connected
3 Suggested Answers
KMusselmann
  • 247 Answers
SOURCE: Briggs & stratton chipper wont start
I believe it is part of the systen shut off. Should be connected to the motor (ground).
Hope this helps you
Kurt
Posted on Mar 18, 2009
vincob
  • 718 Answers
SOURCE: I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Posted on Oct 09, 2009
How to remove tire on Troy Bilt chipper shredder
there is either a clip or a cotter pin that needs removed , then slide the wheel off .
Nov 19, 2013 | Troy-Bilt® Briggs and Stratton Chipper
The gas tank on my Briggs&Stratton 850 chipper shredder started leaking gas while I was useing it. Looking at it closely I spotted a hole in the side of the gas tank next to the exhaust. So I thought...
Looking at a picture of this design, the corner of the gas tank comes close to the heat shield that houses the muffler which gets very hot. The heat shield is supposed to stay cooler than the muffler because it has ventilation slots, but perhaps it got clogged up with debris and dirt, which is always flying around a chipper unit. Take compressed air and blow out the heat shield area. This may reduce the risk of a recurrence, but I have to agree with your safety concerns about this equipment.
Aug 05, 2010 | Briggs & Stratton Chipper Shredder Patriot...
Need owners manual for 2001 yard machine chipper schredder model #24A464B131
I have a operator's manual for 24a 463b129 5.5 hp. I also have an operator's manual for the engine (Tecumseh). I purchased the chipper new from Home Depot back in 2002. I think you will be disappointed at the lack of information. If still interested, e-mail me your e-mail address, and I can send you a PDF copy of these manuals. (wchan@bushbros.com)
Mar 27, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Will not give spark. I cleaned the rust from the mag wheel and the machine has not run for five years.
if its a briggs and stratton engine your ignition coil might be faulty... you should be able to get a 2nd hand unit at your local mower shop... or.check that your throttle control lever is to run position as it has a stop switch on it earthing out the ignition
Aug 03, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
5hp b&s mtd chipper wont start
defiantly the carb but its not bad - clean / soak it with some seafoam and blow out all the holes. its just clogged and isnt getting the fuel/air mixture right.
Mar 30, 2009 | Heavy Machinery
Hope this helps you
Kurt
Mar 18, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
Yard Machines 24a 452g729 5.5 Hp Chipper Shredder Logo
89 people viewed this question
Top Yard Machines Heavy Machinery Experts
donald boissonneault
rjivaro
Phil Walker
Phil Walker
Are you a Yard Machines Heavy Machinery Expert? Answer questions, earn points and help others
