Alkris alk fta1 has lost prime tv - Audio Players & Recorders
How do I get amazon prime app on my smart TVs?
hi Sylvia.
this is all i could find out.
You can get the Prime Video app from the Samsung Smart Hub:
  1. Press the Smart Hub button on your TV remote.
  2. Select Samsung Apps from the menu.
  3. Select Prime Video.
Watch Prime Video on Samsung TVs - Prime Video: Help
or read up more at this link.
How do get amazon prime app on my smart TV Google Search
Dec 03, 2017 | Televison & Video
Can I get Amazon prIme on my new smart pros can tv?
If you are already a member of Amazon Prime, when you configure Amazon Video on your TV (which requires your Amazon login & password), it will recognize that you are a Prime member and provide you with Prime menus & content.
Jul 11, 2016 | Computers & Internet
What to do if too much alkaline in pool
if PH too low add soda ash or baking soda if PH too high add acid muriatic or powder if alkalinity too low add Alk up or soda ash if alk too high add muriatic acid but check PH after PH should br between 7.2 and 7.6 alk should be 80 to 120
May 25, 2014 | Intex Automatic Salt Water System for ...
WATER WELL WILL NOT PRIME OR PUMP WATER
replace the mechanical shaft seal. check impeller and diffuser for damage . prime pump after any repair
Dec 19, 2011 | Sta Rite Pool & Spa
Which salt water test kit(s) would you suggest for my 18'x52'' steel sided pool. i have a Krystal Clear system model CS8110 . what do you think of the salt strip readers?
Have the salt tested free where you purchase chemicals. While there, get a Taylor test kit to test for CL, pH, Alk, CA and Cyanuric Acid.
Salt is persistent in the water - translation - once in the water, it stays there, it doesn't go away except through splash out or back wash. Your salt should be around 3200 ppm. Get rid of the metals in the water before you do anything ... get the Alk around 100 then adjust the pH and introduce your CL. Cyanuric Acid protests the CL you are making. Some places call this 'stabilizer' and the reading should be around 60 to 100 ppm. Calcium is like salt ... persistent in the water ... lost under the same circumstances.
I hope this information helps you.
Thanks for your interest in FixYa.com. If this was helpful ... plese remember to vote and leave a comment.
Thanks
Aug 02, 2010 | Intex Pool & Spa
The pool is still cloudy even with all chemicals balanced and a clean filter? I tried the clarifier stuff too and its still like chalky. How can i get it crystal clean?
Follow these steps ... let the CL go to zero ... add a sequestering agent to get the metal out. Follow container instructions ... run the filter 24/7 (deferring to the instructions on the sequestering agent.) When the metal is out, get your calcium to 300 ppm, get your alk to 100, get your cyanuratic acid to 70 - 90 ppm, get your pH to 7.2/7.4 and introduce 2 to 4 ppm of CL. Do this in this order over the course of 2 days. Dont dump all this stuff in at once and expect good results.
If Cal is more than 300 ppm, dump some water and add new. What is the Cal level in your fill water? Be aware of that number as you adjust.
Use Sodium Bi Carb to increase your Alk
Use Sodium Carb to increase your pH
Use dry or liquid acid to reduce Alk and/or pH as necessary
Get the Alk set first before you try to adj the pH.
The Cyanuric acid will protect your CL from the sun.
You cannot run your filter too long! Backweash only when the pressure raises 10 lbs from the new fresh startup pressure. Doing so before is wasteful of chemical and defeats the filter process.
If you are using salt, get the water as I said before you turn on the salt cell. Add salt per instructions on the bag. Use pool/food grade salt only!
I hope you find these comments helpful.
Jul 31, 2010 | Intex 2500 Above Ground Swimming Pool...
High PH and ALK
Yes you can. You need to lower the Alkalinty by adding the Muriatic acid in colums in the deep end of the pool. Then address the ph. It will come down somewhat with the lowering of the Alkalinity.
Jul 20, 2009 | Intex Automatic Salt Water System for ...
How do I prime the STA-RITE DS3HF-01?
I have a sta-rite mkse-6 pump and it has lost its prime..... how do I prime it???
Feb 15, 2009 | Sta Rite Ds3hf 1.50 Hp Self Priming...
Flytv prime 30
try this
http://www.lifeview.com.tw/html/products/internal_tv/flytv_prime30.htm
Jul 06, 2008 | LifeView Fly Video 3000 (701013821560)...
Sansui dftv275 Remote Control
http://www.sansui.newremotecontrol.com/catalog_item.php?catnum=07640KL030 click here to visit the Sansui webite, this is the model you are looking for.
May 17, 2008 | Sansui D 27" TV275 TV
87 people viewed this question
 Grubhead
Grubhead
