Question about Maytag Washing Machines
Mvwc200xwo washer fills up agitates two times &quits
  • 14 Answers
SOURCE: Washer Not working please help
sounds like the motor is out or goin out.........or maybe the belt is stretched
Posted on Dec 30, 2007
  • 341 Answers
SOURCE: kenmore washer fills and agitates at same time
it sounds like the timer is going bad
Posted on Oct 22, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Washer agitates when I try to fill it up with water,wont fill
You have a bad water level switch or a clogged plastic hose that goes to the water level switch.
Use a putty knife to open the front panel. The clips are at the top right and left sides just below the top lid. Push in on the clips and pull out on the panel.
On the left side of the tub you will see the air dome with aplastic hose connected.
Remove the hose and insert a small wire into the air dome hole to clean it out ouf soap scum. Then, blow through the hose and listen for a faint click in the water level switch. Also check the hose for a hole or being pinched.
The set the timer for spin and run a spin cycle then retry the water level and wash cycle.
Posted on Apr 01, 2009
  • 1937 Answers
SOURCE: WASHER FILL, NO PROBLEMS AGITATING, WHEN TIME
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is an illustrated description of how to remove the cabinet on Kenmore / Whirlpool top load direct drive washers.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Since it won't drain, the problem points to the lid switch. You already have the cabinet off so replacing the switch isn't too difficult.
The Sears site has the Sears (and probably Whirlpool) part number.
Posted on Oct 08, 2009
  • 129 Answers
SOURCE: washer quit spinning,it will fill up and drain but
TIMER
Posted on Feb 04, 2010
Amana washer quit agitating and also drains and fills endlessly. Only 2 years old. What part is failing?
First check the drain hose isn't too far down the drain pipe it should only be about 6 inches down too much and it will siphon out
Jun 16, 2015 | Amana Washing Machines
Haier XQJ50-31 drum quit agitating or spinning
If the timer stopped advancing on one of my machines (laundromat owner) i'd assume it's the timer motor. Kind of like when a top loader has no final spin but otherwise runs okay i always suspect the timer mechanism. For me it's a simple check; exchange timers with a neighboring machine. You probably don't have that option. Unfortunately, I don't know the Haier Brand of machines so i could be wrong.
Dec 23, 2012 | Haier XQJ50-31 Top Load Washer
Maytag A9400 washer won't agitate
the motor, sorry! if left on wash cycle it humms for a bit quits and trys again? or not? the motor is about $130.00 part# 201805
Jun 30, 2009 | Maytag Washing Machines
Kenmore washer fills and agitates at same time
Oct 22, 2008 | Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Admiral Top load washer won't agitate and squeals
Sounds like the gearbox, unfortunatly this is sealed and is cheaper to replace the machine, presume the machine is quite old.
Jun 28, 2008 | Admiral AW22 Top Load Washer
Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
