Question about Haan SI-70 Steam Mop With Detachable Handheld Unit Swivel Head &
Haan leaking water from spout - Haan SI-70 Steam Mop With Detachable Handheld Unit Swivel Head &
Haan steam mop
The heating element may have failed.
Jul 25, 2016 | Haan SI-70 Steam Mop With Detachable...
Can you buy a water canister replacement?
Perhaps you can , but not thru this website .
Sep 05, 2015 | Haan Si-35w Slim&light Floor Steamer
Haan sI70 unit gets hot but no steam is generated, so not hot enough. Anything I can do?
It sounds like the internal temp thermostat is detecting that its hot enough when its not, and cutting the power as its supposed to, but too early. It may not be worth time/effort/money changing this part, in case its a problem with another part. Its a bit desperate but you could turn it off and half fill it with cold water then shake it vigorously to see if washing the internal surfaces impoves things.
Dec 15, 2013 | Haan SI70 Multi Sanitizing Floor Steam Mop...
How do i remove the hose from the haan gs 60
Look for a push-in button on the machine where the hose attaches to it. Also check that there may be a twist off connection with 2 pins on the machine that connect to the holes in the metal end of the hose...either is possible..Good luck!
Dec 28, 2012 | Haan GS-60 Steam Station Garment & Home...
Spot bot leaking when using manual hose
This is an old post but I thought it might help anyone having this problem now to post the solution.
The internal water pump feeds two water delivery hoses on the Bissell Spot Bot. One goes to the spout located in the center of the rotating brushes.
The other feeds the spout located on the underside of the brush at the end of the hose.
There is a water shut off valve that is actuated when you pull the plastic tube at the end of the hose out of the plastic tube it is fitted into during storage.
When you pull the end of the hose out of this plastic fitting a button inside is no longer depressed and a valve shuts of the water flow to the rotating brushes. If this valve is clogged with gunk it will not release when the hose end is pulled out and water will still come out of the rotating brushes even in manual mode.
This is a mechanical fault not an electronic fault.
To resolve the issue you can mix a solution of vinegar and hot water and fill the water tank with it.
Put the rotating brushes over the sink. Remove the hose and fit the scrub brush to the end.
Start the machine in manual mode. The sink will catch the water coming from the rotating brushes area.
Now point the hose end at the sink to catch the water and pull the water release trigger. While holding the trigger press and release the black button inside the tube that holds the hose end during storage. This moves the internal workings of the valve.
Do this till all the water is gone.
At some point during this procedure you will notice that when you release the black button the water will stop coming from the rotating brushes.
You problem is now solved.
If this does not work after two tanks of hot water and vinegar then the valve would need to be removed and soaked in a solution or replaced.
This is a much more complex procedure that requires disassembly.
Maybe a youtube video is in order.
If your lucky the procedure above will solve the problem.
Nov 05, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Haan SI-70 Steam Mop With Detachable Handheld Unit Swivel Head & Logo
42 people viewed this question
Top Haan Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Haan Vacuum Expert? Answer questions, earn points and help others
