Question about Delta 31 - 255X X5 18'' x 36'' Drum Sander
With belt drive motor removed, PN 911-611, motor still runs but I am able to hold shaft with two fingers! There must be linkage that is damaged or is the entire motor beyond help?
Replace belt genesis upright
Turn vacuum upside down on flat surface, remove the 6-7 screws from the bottom of the power nozzle, lay it on it's side and pry on the two accessible internal tabs to pop top cap of the nozzle off to access the pn motor assembly. Lay flat on it's back again and remove the screws that hold the roller brush in, remove the roller brush, remove old belt, install new belt on brush roll and pn motor geared spindle, push brush roll back in place, replace screws and pn top and VOILA!..you're back in bidness! Hop that helps!
Jun 25, 2014 | Electrolux Vacuums
Knocking noise when printing
Check the following:
1. DC motor assembly.
Make sure all the motor plate mounting screws are tight.
2. Idler pulley - DC motor assembly.
Make sure the idler pulley is not binding on the pulley shaft. Check the pulley for wear. Check the idler pulley shaft on the motor mounting plate for damage or contamination.
3. Drive pulley.
Check the drive pulley for wear, binds or damage to the pulley or pulley shaft. Make sure the pulley turns freely on the pulley shaft.
4. Motor drive belt - tray drive belt.
Check the DC motor drive belt for damage. Make sure the belt is tracking correctly on the drive pulley, idler pulley, and motor pulley. Check the tray drive belt for damage. Make sure the belt is tracking correctly on
Dec 11, 2012 | Lexmark X646e Laser Printer
My powerhead drive belt to the N137A electrolux model has broken. I have a new belt for replacement but do not know how to install.
Turn the PN bottom up. With a Phillips screwdriver, remove the six screws in the base. Turn PN over and lift back of cover, then gently manipulate it until it comes off.
Slide the belt off motor shaft, if necessary. Remove the screws on each end of the brush and lift the end of the brush so you can remove the belt, if necessary. Place new belt on brush and place brush into slot. Replace screws and tighten. Pull belt back to motor shaft and slip on. Check belt for tautness. There should be a little play, but not much. Make sure belt is placed correctly and rotate brush a few turns.
I recommend cleaning the inside of the PN while you have it apart. Use the dust brush to vacuum as much as possible out.
Make sure the light cover is in the correct position. Carefully place front lip of PN cover into slot in front.of the PN. Carefully settle cover in place. Check around the PN to ensure cover and base are correctly placed. Turn PN over and replace screws, short one in front.
I do recommend letting a trained Aerus Electrolux tech do this, especially since the belt will have a one year warranty if he/she does it. Of course the belt should last longer than that, anyway.
Mar 03, 2011 | Electrolux Epic 6500 Vacuum
How to replace windwiper motor bushing?
I'am not sure what you mean by the bushing, but I just repaced the wiper motor in my 95 Dakota.
1-remove wiper arms from the pivots.
2-open the hood
3- remove the crowl. there is a line of screws that need to taken out. set the crowl out of the way.
Don't try to remove the motor without removing the crowl. It just won't work.
4- remove the 3 nuts that hold the motor to the firewall.
5 carefully pull out the motor and wiper linkage.
6- remove the nut that hold the linkage onto the motor and remove the linkage. BE CAREFUL you don't want to drop and loose that nut. There is a flat spot on the shaft between the motor and the linkage where a 6" adjutable wrench etc can be put to hold the shaft when taking off the nut.
Follow the above steps in reverse to reinstall. I did use lock tite to make sure the nut doesn't come off the motor shaft.
Feb 06, 2011 | 1995 Dodge Dakota
97 jimmy wiper motor relay fuse problem hear motor running and wipers don't go. fuse or motor?
if u hear motor not elect problem -most likely linkage unbolted from motor with motor running try to move the wiper arms if move freely than need to remove cowl and check the linkage hook up to motor -if wipers dont move freely than possible motor damage/seized linkage damaged but still would have to look under cowl at connection at linkage
Jun 10, 2010 | 1997 GMC Jimmy
Eats belts immediately
HI There,
Usually when the belt breaks immediately, this indicates that your roller brush has gone bad and needs to be replaced. I have never seen the motor shaft being damaged and causing belts to break before. When the roller brush can't spin because it's bearings have worn out, the motor shaft continues to try and turn the belt, but since the belt can't spin the motor shaft at that point burns right through the belt.
To make sure that it's your roller brush, remove the brush from the vacuum cleaner, and hold it using just your two pointer finger tips, holding just the bearings caps at the end of the bar, and not the bar itself.
Try to spin the brush using your thumbs. Does the brush spin freely without resistance? It should spin completely around 3-4 times on each spin. If it doesn't spin, then your bar is bad.
If the brush doesn spin, and it continues to break belts, this means that the belt is being installed incorrectly, and is being pinched by the roller brush. Pull the belt forwards after installing to make sure the brush spins freely.
Hope this helped you,
Chris Jones
GoVacuum.com
May 01, 2010 | Dirt Devil M086355 Bagged Upright Vacuum
Belt fell off
HI, First remove mat from TT platter. Next hold it with upward pressure while striking centre pin with a sharp tap, (real light instrument) not blow. Next you will see the motor shaft (once TT is removed) note it's position, put belt back onto TT rim, that will be the underside flange, lift belt by one finger away from flange edge and place TT back over spindle while having finger with belt over motor shaft. allow belt to contact with motor. Now belt should be around under platter flange and around motor pulley. If this is correct, power up, if all works replace soft mat and enjoy the music. A word of warning, the belt and stylus/cartridge may need replacement!
Aug 25, 2009 | Sony PS-LX250H Turntable
McCulloch mt 700 weed wacker,the weed wacker will not spin to cut the weeds
If the motor is running another possible solution is you have a broken drive shaft spring PN-753-04280 To check this remove the screw which holds the **** pipe to the motor and loosen the clamp. The **** pipe should pull right off the motor exposing the end of the drive shaft spring. Pull the end of the spring, if it comes out it is broken.
Jul 06, 2009 | Garden
How to place belt on dryer drum
Take the hanging part of the bottom of the belt and place a finger through the bottom and pull it toward the belt tentioner , you may have to pull the tentioner with your other hand until you reach the motor shaft , loop the part of the belt your holding with your finger around the motor shaft , that should be it. Hold the drum straight and roll it clockwise a full turn to ensure it is correct.
Let me know how this goes.
Phil
Apr 10, 2009 | Dryers
Bissell Proheat 2x Series 8920 - Brush Belt Metal Shaft Sprocket won't turn
Most likely the brush motor is bad and not turning, part #2036757, would sell for around $23. To get to it, start taking out screws on the top cover, that motor is under the that top access cover.
Jan 22, 2008 | Bissell 8910 ProHeat Clear View Upright...
Delta 31 - 255X X5 18'' x 36'' Drum Sander Logo
41 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
