Question about Keystone 70 Pint Dehumidifier w/Electro Dehumidifiers
Need drain hose part for Keystone dehumidifier model kstad70B
Keystone dehumidifier kstad706pb pump operation. the rear pump drain line leaks around where it is attached to the unit.
The connection may be loose or the connector has been stripped or the drain line is leaking at the fitting.
Nov 13, 2016 | Dehumidifiers
What do i need to do with my unit to drain into a nearby drain in my basement?
Find the drain hose connection if there is one and attach a length of hose of sufficient length to reach the drain.
Aug 15, 2016 | Professional Series dehumidifier model...
Drains through hose and into bucket
this happens when the drain tube becomes blocked so unit overflows and water falls into bucket and not flows out tube , clean tube and drain port with compressed air (wear eye protection!!!)
Jul 17, 2015 | Keystone KSTAD70B 70 Pints Energy Star...
I have a keystone 70b dehumidifier. the hose is attached but won't continuous drain. The bucket keeps filling. When I take the hose off, water comes out so I know there isn't a plug that needs to be...
1st make sure the unit is level , sometimes we forget that it needs to be perfectly level to drain out
2nd this also might be a case where unit runs so long and for so long that it never rests, this might sound funny but its not most units need a cool down period where the internal parts cools off and the fluids run out only when the fan inside shuts off , the humidistat should be set at 70% Rh this should allow a bit of a rest period if not you unit is too small for the task you gave it
Oct 26, 2014 | Dehumidifiers
How can I purchase a replacement air filter for keystone kstad70b?
The filter in your Keystone KSTAD70B is meant to be washed. It is not listed as a replacement part in the owners manual. This is copied from the manual:
3. Clean the air filter
Remove the filter every two weeks based on normal
operating conditions.
Remove the filter from the top of the unit (See.Fig.11a),
or to remove the filter,remove Bucket then pull filter
downwards (See.Fig.11b).
Wash the filter with clean water then dry.
Re-install the filter,replace Bucket. CAUTION:
DO NOT operate the dehumidifier without a filter
because dirt and lint will clog it and reduce
performance.
If you have lost or destroyed the filter, go to Amazon and order the Duck Brand 1285234 Replacement Air Conditioner Foam Filter, 24-Inch by 15-Inch by 1/4-Inch, 1-Pack for 96 cents with free shipping as an add-on item to any order. It is also washable so you will be able to use it like the OEM filter material.
Jul 06, 2014 | Keystone Dehumidifiers
Continuous Drain
If the design is unique, Keystone may be the only source.
May 27, 2014 | Keystone KSTAD70B 70 Pints Energy Star...
I need a part(s) which allows the water from the dehumidifier to drain into a hose which goes to a basement drain. What are the names of the parts and where can I order them?
Not knowing which brand and model number dehumidifier you have, makes telling you what parts you need difficult at best. Most dehumidifiers only require a garden hose section, no longer than 5 feet, that connects to rear of the unit. The connection will be a threaded male connection. It is plastic, so don't over tighten it and crack it. It will have a screw off cap, which must be removed to connect the hose.
Keep in mind, most dehumidifiers rely solely on gravity to drain the water thru a hose. So, the hose should slope down from the unit and straight over to the floor drain.
If the above didn't help you, get back to me with the brand and model number of your dehumidifier.
Thanks for choosing FixYa
Aug 14, 2011 | Dehumidifiers
We have Danby Model DDR557HE-7 and cannot locate our Manual. We need to disconnect hose and have excess water go to bucket. How is this done?? If we had copy of Manual we wld be able to search same...
All Danby dehumidifiers, regardless of the model number operate the same way.
The link below to a 50 pint model should provide all the info you need.
http://www.danby.ca/cms/uploads/products/en_manual/DDR5009%2C_6009%2C_7009REE_EFOM.pdf
However, I think you'll find that draining into a bucket is not an option. As the hose drain relies entirely on gravity to drain. So, it will not drain down and then up into a bucket. The hose drainage method, is designed to drain into a floor drain or a sump.
Hope this helps you.
Jul 19, 2011 | Danby DDR557 Dehumidifier
Where do i find the model number for an older model goldstar dehumidifier and where can i buy a hose to connect it directly to the sump pump?
Any garden hose will fit the drain connection on your dehumidifier. However, the hose can not be longer than 5 feet. As the drainage relies entirely on gravity to drain. Connecting it directly to a sump pump is not a good solution. Allowing the hose to drain into the sump pump's water collection tank is your only option.
Hope this helped you.
Jun 24, 2011 | Goldstar Dehumidifiers
Keystone 70 Pint Dehumidifier w/Electro Dehumidifiers Logo
83 people viewed this question
Top Keystone Dehumidifiers Experts
J.D. Browning
J.D. Browning
AZBen
AZBen
Tom Chichester
Are you a Keystone Dehumidifier Expert? Answer questions, earn points and help others
