Question about Home
Fan runs doesn't get cold, what's wrong? - Home
Gas package unit
the bushing or the bearing in the motor may have already worn out. or may need some lubrication. the rotor is trying to turn but it's stiff and won't continue to turn. dont continue to turn on if it wont spin otherwise you'll damage the motor further. it might also be the busted capacitor "if it has"
Jun 04, 2013 | Amana Heating & Cooling
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Goodman ck30-1l, outside fan trun on doesn't speed up and stops, what is wrong any ideas?
Your most likely issue is a bad run capacitor. It a small silver can that is usually located in the controls area of your condenser. If the fan has been replaced it could be mounted somewhere around the fan. It helps motors run and when they fail they will run half speed,
Jul 08, 2012 | Goodman CKL49AR49 Air Conditioner
Refrigerator & frezzer no longer cooling. Compressor is still running , but condenser fan doesn't seem to be working correctly. Does the fan not working full time when the compressor is running...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 23, 2011 | Refrigerators
Hi, I have an amana ap125hd portable air conditioner and for some reason is doesn't produce cold air anymore. Then fan blows and the compressor kicks in, but to no avail, no cold air. I took the unit...
replace it,most likely the freon leaked out,if the compressor is running and the fan is blowing but not getting cold most likely you have a leak in the sealed system.
Jul 09, 2011 | Kitchen Ranges
Lg top freezer ltn1931# doesn"t
heatman101
Jul 02, 2011 | LG Refrigerators
I have a goodman air conditioner. When I turn it on air blows through the vents but it's not very powerful or cold. The unit outside makes a humming noise but the fan is not spinning. It's not...
You may have a bad condenser fan motor or a bad capacitor for that motor. If the compressor is running in the outside unit but the fan is not then it is most likely one of those two components that has failed. Consider calling a service tech to test it and see where the problem is.
Jun 16, 2011 | Heating & Cooling
Refrigerator doesn't seem to be getting cold. It was making a noise and now it doesn't seem like the fan or something is not working. everything in the soft freeze draw is thawed
heatman101
Jun 15, 2011 | Kitchen Ranges
Freezer works, it's cool nolt cold in the refrigerator, fan motor doesn;t seem to be working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Oct 19, 2010 | Roper RT14DKX Top Freezer Refrigerator
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
