Question about Miele H387-1B Electric Single Oven
Light panel has no choices on it. Can't turn oven on
Oven light stays on all the time even when oven off.
Does your oven have a switch on the front panel for "oven light" or "light" ? If so, pushing it may turn the light on and off. Also, there may be a pushbutton on the oven's front edge where the door fits. The button comes out when the door is open and turns the light on. If you have one of those, the switch could be broken or defective. If the button is missing or damaged, it could leave the light on all the time.
Mar 22, 2014 | GE Monogram® ZET1PLSS Dual Single Oven
Did you try the light switch on the control panel? If it's turned on, the door plunger will not turn the light off.
Oct 01, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Pilot light issue
you cannot light the pilot on that oven manually. that oven is eletronic ignition. take off the panel under the doors, turn on the oven, and turn the thermostat to 350.
if you see sparking on both the right and left burners, you and it doesnt light, you need to see if the gas solenoid on the right side of the burner is getting power. if it is and nothing lit relace it.
if it is not, replace the ignition board
Jun 30, 2013 | Ovens
Whirpool Accubake Control Panel
try turning power off and wait 10mins and see if it resets.
Sep 14, 2009 | Whirlpool RBD305PD Electric Double Oven
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
GBD RBD Whirlpool Oven Problems Causes and Solutions
Hello Edward!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
May 17, 2009 | GE JKP20 Electric Single Oven
OVEN LIGHTS DO NOT TURN OFF.
The oven has a small button on the left side on top of the control panel. Switch it on or off. Hopefully this will solve the problem.
Nov 09, 2008 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire single wall oven
We had a similar problem. When the repair person arrived he turned of the electicity to the oven then turned it back on. The control panel is a computer and he rebooted it.
Jan 06, 2008 | Ovens
Miele H387-1B Electric Single Oven Logo
18 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
