Question about Ingersoll Rand 2135Ti Air Impact Wrench
Trigger 2135 hammers orings replace - Ingersoll Rand 2135Ti Air Impact Wrench
    Habit-Forming:
  • 102 Answers
FOLLOW THIS LINK TO VIEW PARTS SCHEMATIC AND PRICING.
Part Listing Order Page
Posted on Nov 28, 2014
Dewalt D51238 not firing when trigger pulled but air does come out?
Remove the head and lube the headvalve with white grease. If gun still does not fire and makes air noise at the trigger valve then orings within the trigger valve are worn. Replace the trigger valve or if you have a source for small orings, just replace the two orings on the metal stem (2mm x 1.5mm). Dewalt uses vinyl orings on the stem that fail. Replace with buna. Good luck
Oct 13, 2014 | Air Tools & Compressors
I have a 602, with air connected I pull trigger and nothing happens. There is no sound of air release or the hammer trying to actuate. ????
Time for good relube of all the orings with white grease or silicone paste. If no air is leaking then no need to replace orings. This occurs when the orings in the headvalve are dry. Air does not leak out of the gun however does leak between the main air chamber and the upper headvalve. Make sure that the firing pin is fully depressed by the safety foot when firing the gun. Good luck
Aug 23, 2013 | Senco & Frame Pro 601 Framing Nailer
DeWalt D51823 nailer shoots continusously when plugged into air hoswe
Shooting continusously caused by worn orings in the trigger valve and in the gun.Dewalt framing nailers use some vinyl orings (gold or clear in color) that fail too soon in both the trigger and the cylinder spacer (white plastic). Air out the nose of gun indicates air is leaking past the cylinder spacer seals (If piston is pushed down with air leak then headvalve seal is leaking (remove nails for this test)). If piston is not pushed down with leak, remove head and pull out the cylinder with cylinder spacer (white plastic). Place the cylinder on workbench with bottom up. Push down on locking ring and remove retainer to release all the other parts. Take picture or take note of parts together and as you pull them off to aid in re-assembly. You will need to replace the two orings between the white cylinder spacer and the cylinder. Order oring kit from dewalt or just purchase one ( # 141 universal oring ) and one metric oring 74.4mm x 3.1mm from hydraulic parts store. If the piston was pushed down with air leak, replace headvalve orings in the head. The trigger valve also has vinyl orings on the trigger pin. You could try replacing the orings but hard to find . Pin uses 2mm x 1.5mm. The orings on the inner valve should fit snuggly on the outer contact surface. If the valve just falls out the the body, the orings are too loose or the body is worn. I would just replace the trigger valve to be safe, however repaired works ok if you can find the orings. Trigger orings do not come in the kit. I would also remove the nails after each use and only reinstall them after air is connected and gun seems to work as it should. The Good luck with your repair.
Dec 23, 2012 | Air Tools & Compressors
Will not nail anymore, what could it be ?
Dewalt nailers have some vinyl orings that fail. Usually found within the trigger valve, headvalve, and between the cylinder and cylinder spacer (white plastic piece). Oring kit sold by dewalt will contain most of the orings needed. The kit may not have orings for the trigger. You will at need two orings (2mm x 1.5mm) for the trigger valve stem or just replace the valve. Use white grease or silicone paste lube on all the orings. Good luck.
Aug 26, 2012 | Dewalt D51850 Heavy Duty 20 Degree Full...
D51850 framing nailer leaks air
Dewalt uses vinyl looking orings that begin to just melt, unlike the black rubber orings. I usually replace about four orings within the gun and two within the trigger. Remove the head and pull out the cylinder by gently prying up on the white cylinder seal. Place the cylinder on workbench with bottom side up. Take picture to the unit or draw diag. with placement of parts. Push down on the spring loaded retainer and remove the oring. The orings that you need to replace are under the white cylinder seal. Larger is 75mm x 3mm (or 74.4mm x 3.1) , smaller is universal oring # 141 (58.42mm x 2.62mm). There could be other failing orings in the head (vinyl orings will look streached out if bad, but do not need to replace of good) . The two orings in the trigger are also vinyl and fail often. Replace with 2mm x 1.5mm or measure because of many different trigger valves (or replace trigger valve, not expensive). Good luck
May 25, 2012 | Dewalt D51850 20° Full Round Head Framing...
Why does my roofing nail gun jamming, it would fire one nail and the hammer will remain out, so i toke a screw driver and push the hammer back in, and it still did the same thing
Simple test for piston jam. With nails removed and latch open, point nose of gun up then down. If the driver slides up and down in the cylinder as you move the gun, replace the piston oring (test gun for proper operation). If the piston stays in the upper most position as you move gun (push driver to top position), check lower bumper and bottom seal under the bumper (sheet). Replace as needed. If the lower parts are in good condition (good piston oring, lower bumper and sheet) , replace the 3 orings on the feeder piston. Good luck
Dec 03, 2011 | Hitachi NV45AB2S Coil Roofing Nailer
Air rushes out of trigger area as soon as air hose is connected.
Remove the trigger to expose the trigger valve then un-screw the valve. If you have access to orings, pull apart the valve and replace orings (5 orings in the valve and one external oring ((external oring usually ok)). If you would like to replace the valve complete, the part number is ( PB205ba1) and is available at www.toolpartsdirect.com. Good luck with the repair.
Sep 18, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
Air leaks around trigger when it is squeezed
If you do not have a parts list for your gun, look that the page below for reference:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/hitachi/nr83a2
Reference #66 is the trigger plunger and #67 is the oring seal.
Leak when you press trigger is most likely due to bad or missing oring on the trigger plunger (white plastic pin under trigger). Remove the roll pin (3mm) holding the trigger and remove the plunger. Replace the oring as needed. If you would like to use generic part. Lowes oring #60 sold in the plumbing department (small package of 10 orings about $2) works fine. Good luck
Sep 13, 2011 | Hitachi NR83A2 2" To 3 1/4" Full Head...
Leak air for the trigger
Could be leaking from trigger or in front of trigger at plunger. Spray soapy water on area and determing exact leak. If from trigger pin, remove pin holding metal trigger (3mm roll pin) and check white plastic plunger for oring on groove. If oring is in place then check vinyl ball inside trigger valve bushing. Replace as needed. If leak is in front of trigger at black boot, remove head and replace oring on outer part of cylinder plate (donut shaped plate at top). Good luck
Mar 01, 2011 | Hitachi NV45AB2 Roofing Coil Nailer
Jammed makita an923 nail gun
On most all nailguns when the trigger is activated air pressure is released from the headvalve causing the headvalve to open and fire the piston. If air leaks through the headvalve orings or through the headgasket port to headvalve, it will not fire. Try applying light grease to headvalve orings and make sure that headgasket is sealing around vent hole. If it fires then replace orings in headvalve for long term repair. Secondary problem is worn safety parts and trigger or trigger pin. If these parts are worn the trigger will not push the trigger valve pin all the way in when you bump fire the gun. With air supply disconnected, apply pressure to safety while depressing the trigger and check thet the pin is moving all the way into the trigger valve. Adjust or replace as necessary. Enjoy
Sep 13, 2008 | Air Tools & Compressors
Ingersoll Rand 2135Ti Air Impact Wrench Logo
226 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
