Question about Dell Computers & Internet
Dell 8100 dimension keeps freezing - Dell Computers & Internet
    Sergeant:
  • 293 Answers
I need more than that to tell you how to troubleshoot the problem you're having. Most freezing or locking up is caused by a program not functioning properly. Start your computer in safe mode. Go to your start button, type in the search RUN right click and run as Administrator, then when the box opens type in MSCONFIG and click run/yes/okay (which ever you see). This will bring up a new window. On the main tab you'll see three options. Normal start up, Safe Mode, and Selective Startup/Custom Startup. Click safe mode hit okay and it will restart the computer into Safe Mode. This will prevent all startup programs and services from starting. Let the computer run and if it still freezes then you know it's a hardware issue. If it doesn't, it's a program error. Take the time then to diagnose either the hardware or the software. If it's the hardware, check to make sure that everything is seated correctly, that the ram is firmly and fully in their sockets. Make sure your hard drives are connected correctly. Check the power supply make sure it isn't dying and causing you too lose power.
Look at the motherboard and check for heat damage, blown resistors and other components.
If it's software, go back into MSconfig, go into selective start up and choose one or two programs at a time and restart the computer until it freezes. If you get it to freeze with a specific program you know it's the culprit.
Also, freezing tends to be related to bad configurations. I dont' know if you've been trying to overclock the processor, the ram, or the video card (onboard or dedicated) could also cause these issues. Check your bios and make sure your settings are correct. Stop using any overclocking software.
Lastly check temperature. The normal operating temperature of a desktop PC is 130 degrees F with some of the more powerful processors and video cars. 90 degrees F while not under load. If your temperature is getting too hot it could be crashing. This could indicate a bad processor, a heatsink that isn't seated or in contact with the processor anymore, malfunctioning fans, poor circulation, or even dust/grime/dirt getting into the computer.
You could be experiencing this GUI lag or freezing if you have background processes that are taking priority over it while they run drawing more of the computers resources. Let it sit for a little big and see if it corrects itself.
Lastly, if you're getting blue screens of death because of windows, get the logs for them and post them so we can go over them and see if anything else is happening.
Posted on Oct 16, 2013
3 Suggested Answers
sparky1500
  • 1066 Answers
SOURCE: Hi! I'm need a Pci simple communications
download it from the dell website
Posted on Oct 09, 2009
skidzy
  • 65 Answers
SOURCE: Help to upgrade memory of Dell Dimension 8100
Im sure you mean 1GB of ram.
Upgrading ram is possibly the easiest upgrade to a pc.Firstly shut down the computer and remove the wall plug.
Remove the casing
Make sure you touch something metal away from the case before entering the chassis of the computer... anti static wristbands are good.
As soon as you open the case you will see the dimm slots where the ram goes.
You will find two plastic clips on each ram module, just pull these back to release the ram and insert the new ram.You may need to push firmly down to lock them in.The clips will auto lock.
Just be careful not to push to hard as to damage the mainboard.
Posted on Nov 11, 2009
Dell 8100 dimension keeps freezing running fedora 17
Check that all appropriate linux drivers are installed your hardware. Especially your hard drives, motherboard chipset, and peripherals.
I'd also need to see a general report of what is happening (the Fedora error reports) to help you beyond that. The logs are stored /var/log
Oct 16, 2013 | Dell Computers & Internet
I formatted a dimension 8100 and I install window 7 32 bits now I can't upgrade my Ethernet or sound drivers
I suspect you already tried the drivers. Dell site only has drivers from 2001. You may have to roll back or purchase new cards. It's the same reason I can't use Win8.
http://www.dell.com/support/troubleshooting/us/en/19/Index Choose drivers and downloads..
Aug 30, 2012 | Dell Dimension 8100 PC Desktop
Hi! My dell-dimension 8100 with 40GB was working ok till i up grade with 400GB. After the up grade,my desktop chould'n notice the new hard drive and chould'n instaul window xp. Please what should i do?
When you boot your computer, spam the F2 key to enter the BIOS setup. Select the Drives/Drive Configuration menu, make sure PATA-0 and PATA-1 are enabled. (or whatever is listed for your physical drive ports, the Dimension 8100 doesn't use SATA so those shouldn't be listed). Save settings and restart. XP should now be able to detect the new hard drive.
Sep 29, 2010 | Dell Dimension 8100 PC Desktop
I have a dell dimension 8100. I am wondering if the motherboard is bad or the video card. All monitors that I hook the computer up to are very dark and the blue hue seems to be very pronounced.
Hello
If this system has a video card its probably bad.
You may want to try a differnet monitor cable before spending alot of money.
If this motherboard has onboard video,take out the vid card and try the onboard video.
Aug 30, 2010 | Dell Dimension 8100 Motherboard (5E692)
How do i connect my Dell Dimension 8100 PC Desktop to my LCD Tv?
has it got a vga slot? if so then u need a vga male to vga female connector has yr graphics card 2 vga slots or dvi ? if so u need those conectors any more info plz ask
Jul 17, 2009 | Dell Dimension 8100 PC Desktop
Dell dimension 8100 diagnostic lights
please refer to the below link...being dell support technician myself this link would give you the best possible help
http://support.dell.com/support/edocs/systems/dsleest/codemess.htm#diagnostic_codes
Oct 18, 2008 | Dell Dimension 3000® Pentium® 4...
Accessing RAM sticks in a Dell dimension 8100 tower
hi,
The following link would give you product manual . This would help you to replace the memory.
You donot have to remove the otherside. You might need to remove the PCI cards, to gain access to the memory.
http://support.dell.com/support/edocs/systems/dsleest/rr.htm
Thanks
proton
Sep 30, 2008 | Dell Dimension 8100 PC Desktop
Upgrading Graphics Card
So your dell only has a AGP slot.
You need a AGP card
On nvidia side you can get
The geforce 6000 - series
Geforce 7000 series
On Ati side you can get
Radeon x1000 series
Radeon HD 2000 series
Radeon Hd 3000 series
Remember they have to be AGP
May 26, 2008 | Dell Dimension 8100 PC Desktop
Computers & Internet Logo
44 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
