Question about Stanton STR8-50 Turntable
I just purchased this used they had no history of the turntable. The power is on and the 33 record is spinning but the arm stays in the same spot on the turntable and no sound is coming through the speakers any ideas
  • Stanton Master
  • 5,158 Answers
The stylus could be as flat as a pancake. So will not fit into the grooves. If you unplug the wires to the cartridge and with the unit connected to your amp and that on power, touch with your finger each of the wires one at a time. You should hear a buzz one on the left and one on the right from two of the wires. If you do that shows that sound will get into your amp. If that's okay I would then buy a new stylus and cartridge. It doesn't have to be the same as the one you have. As long as it will fit on to the headshell.
Posted on Oct 19, 2013
My Philco 841205 Turntable spins normally, but
If this is a belt driven turntable then when the arm rests on the record the weight cause the belt to loose traction and slip around. The only cure is a new belt. Make a note of how the belt fits before removing as the biggest problem with belt turntables is knowing how the belt fits. When removed. Measure the diameter of the belt in MM and then the thickness. You won't need to be spot on with the diameter. Put the measurments into Google with the words turntable belt. Get the one that is nearest your measurements.
Sep 16, 2014 | Audio Players & Recorders
Platter not spinning
Some turntables only move when you move the arm to the record. If that doesn't work and you have read the set up instructions correctly, as it's new contact the maker or the place you purchased it from. I'm certain they will help.
Mar 22, 2014 | Califone International Audio Players &...
I have an old Curtis Mathis direct drive turntable that I bought in 1984. The arm needs to be adjusted so that it will line up with the 33 rpm record. It currently lines up about 1/2 inch outside of the...
hi,
power off and remove from mains. put the arm manually to the center of rotating plater(end of the record) it will stop. from there slightly push the arm to the center little ( do not use more pressure). the take back it to the arm rest. power it on and test it. watch the difference. need more do the same again.
ok
Dec 24, 2010 | Audio Players & Recorders
After sitting unused for many years, I just
Hi, Does the arm have a lever to lift the arm up, also called a cue. I had an arm where it did exactly the same thing and found it to be the lifting device. What turntable is it you have?
May 12, 2010 | Audio Players & Recorders
Cr79 tone arm stops too early
I have a 1956 stereophonic Motorola record player, and it turns off right when I press "on" I noticed that the record speed was 33 1/3 I used 33. Does this make a difference??
/uploads/images/cr79-tone-arm-stops-early-34896944-4-1.jpg
May 09, 2010 | Crosley 0187SST Turntable
The arm won't stay down, as soon as it sets down on the record it automatically stop and moves back to the resting spot.
If you have the automatic arm on you`res and you have to move the slidder control to make it work,don`t slide the control all the way.Just til you hear a click and then move the arm you`r self.Also make sure it is set to the size record you are trying to play.
Apr 22, 2010 | Pioneer PL-990 Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Tone arm cueing problem on Technics SL-BD27.
the auto stop mechanism needs adjusting
Apr 07, 2009 | Technics SL-BD22 Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Stanton STR8-50 Turntable Logo
48 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Electro Med Services...
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
