Question about Lexmark Optra T610 Laser Printer
Canon ir 3570 pegas fusor - Lexmark Optra T610 Laser Printer
Canon IR-3570 i have problem in pannel touch
Screens do become faulty over time, it could be a faulty connector/ribbon cable or the circuit board in the pannel
Oct 13, 2013 | Office Equipment & Supplies
Canon ir 3570/4570 reference guide
Hi
My self Rishi Dhiman
if u want to active ur optional copy tray in ir 4570/3570/2870 machine than first of all u have to enable it ,
Go to additional function/ common setting / tray desination/ here u can select tray which u want to use
If u not get the opiton of tray desination in common setting of additional function, than u have to active it from service mode
press * 28* for entering into service mode after that click on copier, now click on option >acc>out tray press here 1 and do it ok, now u have to restart u machine one time after that opition of tray desition is avilable in common setting, nd there u can set u output tray,
caution : this method is decrease the speed of machine paper output
Any Query about this u can post it again here on this website
Oct 11, 2012 | Canon IR 4570 COPIER FOR 220 VOLTS ONLY
Cual es el fusor de una copiadora Image Runner 1670f
Canon Ir 1670 doesn't use fusor; it uses fixing film; part number is FM5-0992-000 @ 120V this issue happens frequently in these machines.
Roger
Dec 06, 2011 | Canon ImageRUNNER 1670F Copier
MI COPIADORA CANON IR 3570 ME MARCA ERROR E002 ME PODRIAS DECIR POR FAVOR QUE ES ESE ERROR Y COMO LO SOLUCIONO GRACIAS
tengo una fotocopiadora canon ir 3570 y le cambie el cilindro y la cuchilla y ahora no me copia la imagen sale la hoja en blanco
Aug 22, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Canon IR3570 Factory reset
how to reset cannon ir 3570 photo copier
Apr 07, 2010 | Canon Office Equipment & Supplies
I can't get my Canon ImageRunner 3570 to print in color, how do I get to that setting?
The Canon IR-3570 is a black and white copier, printer only, it's is not a color printer. sorry
Dec 25, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Canon ir 3570 trouble code e-0024
E024 The developing assembly connector is disconnected.
0000 The connection detection signal is absent
continuously for 100 msec.
Replace the developing assembly toner
sensor. Connect the connector. Replace the
DC controller PCB.
Jun 09, 2009 | Canon ImageRUNNER 3570 Copier/Printer
E000007-0000
this code is for damaged fixing film, on the end you have home position sensor for good position of fixing film.
Feb 04, 2009 | Canon ImageRUNNER 3570 Copier/Printer
Lexmark Optra T610 Laser Printer Logo
15 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
