Question about Oster 5834 ExpressBake Bread Maker
Reset time my bread machine was at 2:26 when i accidentally pushed the "start/stop" button and it went back to 3:35. how do i get it back to the stage it was at?
How can I get the machine to start the bread making process from the beginning. It is currently stuck on knead.
Do you have your owners manual and have you baked bread in your machine before? Just want to be sure that you know the stages that the machine goes through. The first mixing and kneading stage in a tr444 will take up to 15 minutes before it stops on its own. It will then let the dough rest for about 1/2 hour before the 2nd knead begins. It takes almost 4 hours for your machine to go through all the stages before your baked bread is finished.
Jan 15, 2015 | Breadman TR444 Bread Maker
How to reset bread machine
push the start/stop button until it beep (takes a few seconds before you her the beep) then choose the program you want. If that doesn't work unplug your machine and start over.
Apr 19, 2013 | Black & Decker B2300 Bread Machine
When he bread box beeped after about 45mins, I pressed stop the #'s went away and then I took out the spinner. Closed he lid back and this is what happened. HELP PLEASE!!!!
That beep was just an alert to let you know that it was time to add fruit and nuts. Next time justnore unless you havgs to add in. Don't push the stop button next time. Just let the machine work.
Jan 13, 2013 | Kitchen Appliances - Others
Cuisinart bread oven menu will not change
Plug your machine in and push the menu button again and again are the numbers changing from program to program? If not push the start/stop button with no ingredients in it and if it starts kneading wait a few seconds then push the start/stop button again UNTIL IT BEEPS AND STOPS. Unplug the machine and plug it in again and the program 1 should show again, just push the Menu button until you see the number 9 program. Did that work?
Dec 21, 2012 | Cuisinart CBK-100 2-lb. Bread Maker with...
When the bread is finished baking, after I take the bread out, the machine starts to beep with HHH error, I pull the plug, then when I put the plug back in it shows the time, or menu. It won't shut...
Before you take the bread out push the "stop" button until it beeps in a couple of seconds. Then unplug the machine, then take the bread out last.
Apr 28, 2011 | Cuisinart CBK-200 Bread Maker
How do I cancel a program? I accidentally set it to delay start and now I can't figure out how to cancel the program and reset to what I really want.
push stop or clear button until you hear a beep or the display changes,,,,unplug ....plug back in and choose the program you want
Feb 20, 2011 | Black & Decker Bread Machine
When i push the start button the machine beeps and LLL shows in the display
That means the temperature in the oven is too low. The manual says you should push the start/stop button un plug it and put the bread machine in a warm room before restarting.
Jan 25, 2011 | Sunbeam 5891 Bread Maker
Timer is working but the motor (that spins the piece to make the dough) does not. Is there any security fuse ? Thanks Michel
Hi michel amor
If you are using the timer nothing will happen until the time you set for the breadmaking process to begin occurs. In other words if it 8 am and you want your bread several hours later then your bread machine will do nothing until several hours later. If you don't want to use the timer and you just want to be sure that your paddle turns and kneads the bread go ahead and push the stop button and hold it down until it beeps. Unplug your machine, then plug it back in. Then do this:
----push select
----choose your program ( for example choose #1 basic)
---choose your crust color
----choose your loaf size 1.0, 1.5, or 2.0 pounds
----push the start button
----your machine will start mixing with the paddle
----if your machine is cold it may warm up for about 15 -20 minutes but it will start mixing within 1/2 hour.........hope all this helps
Jan 10, 2011 | Black & Decker Bread Machine
Cant start the bread cooking process because control panel is freeze when l plug the machine. Tried to push and maintien the start button for 20 seconds but doesn't work.
Hold down the stop button for more than 3 seconds to reset the machine. Do you not need to unplug it for 15 minutes to reset, just hold down the stop button.
Sep 26, 2009 | Cuisinart CBK-200 Bread Maker
Oster 5834 ExpressBake Bread Maker Logo
43 people viewed this question
Top Oster Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Ben Eng
Level 1 Expert
Are you an Oster Kitchen Appliances - Other Expert? Answer questions, earn points and help others
