Question about Miele Vacuums
Miele s538 Monte Verde vacuum
Miele S538 Monte Verde Bag blew up inside. Motor stopped. Can it be saved? Control Board scorched where AC comes onto it from cord reel. Power good through cord reel to power plug. Control board looks slightly scorched at the surface. Motor turns freely, but not sure if problem is control board or motor itself. Suspect the control board. Can that be ordered, or repaired? Same goes for the motor? Michael Elk Grove, Ca
3 Suggested Answers
  • 120 Answers
SOURCE: I am looking for a contol board for a miele s143
you should check the cord and switch's for continuity, the boards are usually pretty reliable, you could check the board for any bad solder joints, at least that would be obvious.
Posted on Sep 14, 2009
alicantecoli
  • 22156 Answers
SOURCE: Miele vacuum cleaner S524.
just renew the cord but instead of a wind up thing i would just put a length of new cord on and just wrap it around the machine when you put it away ,or fit a hook on the side of the machine to wrap the wire around ,200 dollars is a lot of money here and for 35/40 euros i can buy a nice vacumn cleaner ,For 200 euros sort of money i can buy an industrial machine on wheels with a 3kw motor for cleaning the cars with and the mrs uses it around the house as well ,and its a wet and dry machine as well
Posted on Nov 22, 2010
How do i put the vacuum bag on my miele pisces vacuum?
Hello, this is Ava with Think Crucial.
You may check the instructions on how you can install your Miele bag inside your vacuum using the link provided below.
Miele 5281 Pisces Operating manual
You can purchase a wide variety of high quality Miele replacement parts for your Miele Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 26, 2014 | Miele Pisces S5280 Royal Blue Canister...
Tip
How To Maintain a Miele Canister Vacuum
Here's a short Video Presentation that we've put together showing how to replace the vacuum bag, motor filter, and HEPA filter on the Miele Series canister vacuum, as well as how to perform basic maintenance.
How To Maintain a Miele Canister Vacuum Cleaner
on Mar 22, 2010 | Miele Aquarius S5580 Bagged Canister...
My miele silver moon attachment brush stopped spinning. the belt looks good what could it be
It is most likely the hose. There are wires inside the hose that connect the speed and suction control on the handle, to the board inside the canister. After years of use, the wires can become damaged to the point that they wont complete the circuit anymore. Any vacuum store that sells miele will have the replacement hose. You can also get it from miele directly, or off ebay. Be careful going to the vacuum store if you dont have a trusted shop, as they make more money from the sale of a new vacuum, rather than a replacement hose.
Feb 20, 2011 | Miele s558 Silver Moon Vacuum
Our vacuum (a miele S718) has cut out.
Probably WAY too late to help you now, but may be of assistance to others (I repair appliances): Several times, I've had Miele Vacs which show the red light, but the motor never powers up. If the vac was working perfectly before, 98% it will be a bad solder joint on the Motor pcb. Although it varies per vac: Remove the bag & 4 screws around.
Unclip & remove lid (flex off pivots), then remove centre screw. Lift off control panel. Remove all other screws under the control panel area.
Lift out motor & unscrew motor pcb. Turn over & inspect for any black joints - repair as ness. Reassemble in reverse order - note: difficult to locate top cover back on if lid wasn't removed, as lid power connection can interfere. Hope this helps...
Jan 31, 2009 | Miele Red Star Bagged Canister Vacuum
Opening Miele S28i Vacuum cleaner
If it is similiar to the white star you may find the instructions here useful: http://www.sannerud.com/house/miele.html
hope so
Jan 10, 2009 | Miele S251i Plus Bagged Canister Vacuum
Miele vacuum loses power automatically
Could have a problem with the motor, there also is a speed control circuit board mounted by the motor that may be starting to go bad.
Apr 26, 2008 | Miele Blue Moon Bagged Canister Vacuum
Miele big blue
Could be a problem with the cord. There also is a circuit board by the motor that could be the problem. Did you drop something in the hose to see if it comes out the other end? Because you could have a clog. Or just unhook the hose and see if it runs that way.
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Stopped working - warning light on
There is an electronic circuit board on the motor that may have gone bad and will have to replaced, part # 06836740 and sells for around $75.00, for model S516. But if this a S316, then it could be the speed control mounted on the motor, Part # 04416342 and sells for around $83.00. Both of these models are Cat Naad Dog so you need the model number berfore you order a part.
Dec 05, 2007 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
62 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
