Question about Taylor 1541 Wireless Weather Forecaster With Barometer
How to change settings - Taylor 1541 Wireless Weather Forecaster With Barometer
Change default font
Outlook Express 4.0, 4.01
  1. In Outlook Express, click Stationery on the Tools menu.
  2. To change the font settings for e-mail messages, click the Mail tab, and then click Font Settings.
  3. Change the appropriate font settings, and then click OK.
  4. To change the font settings for newsgroup messages, click the News tab, and then click Font Settings.
  5. Change the appropriate font settings, click OK, and then click OK.
Outlook Express 5
  1. In Outlook Express, click Options on the Tools menu.
  2. On the Compose tab, click Font Settings.
OLEXP How to Change the Default Font in Outlook Express
Aug 05, 2014 | Dell Computers & Internet
I have bought a Canon MP510 printer/scanner. I cannot figure how to change the photo size settings in Memory card mode to 6x4. I change it then save settings but always reverts back to a factory setting 11...
All you need to do is to change the size in the software which you are using to edit the photos and do a save changes before you close the application,
Apr 20, 2008 | Office Equipment & Supplies
How do you set the clock for manual clock in?
From the manual:
Press the SELECT button and position the cursor at the "TIME". At that moment, the "Hour" flashes. (The flashing means it can be changed.)
Change the "Hour". Press the CHANGE button to set the desired hour. Press the SET button. At that moment, the flashing changes from "Hour" to "Minute"
Change the "Minute". Press the CHANGE button to set the minute. and then press the SET button. At that moment, the "Second" starts to run from "00".
After you finish setting the time, press the SET button once again. Now the time setting has been completed.
Setting the Date
Press the SELECT button and position the cursor mark at the "DATE". At that moment, the "Year" flashes. (The flashing means it can be changed.) Change the "Year". Press the CHANGE button to set the year. Press the "Set" button. At that moment, the flashing changes from "Year" to "Month". Change the "Month". Press the CHANGE button to set the month. Press the "Set" button. At that moment, the flashing changes from "Month" to "Date". Change the "Date". Press the CHANGE button to set the date, and then press the SET button. After you finish setting the date, press the SET button once again. Now the date setting has been completed. Replace the cover.
Feb 28, 2011 | Lathem Time 900E Electronic Recorder,...
Hi all the settings in the mms profile have disappeared and now i can't send or recieve pictures.hope you can help
hi..
Changing MMS settings:
  • To Change MMS settings:
    • Goto Multimedia messages Menu > Settings
    • Select Setting category and change the settings.
  • if you follow the steps you can easily got it..
  • thank you.
  • If it's useful for you means plz rate me the 4 Thumbs ....
Feb 08, 2011 | Samsung Cell Phones
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
How do I change the display settings for my hp mx 50 crt monitor 13 inch
for changing the display settings right click on desktop, then go to properties and then change all the settings that u want to change
May 19, 2010 | Computers & Internet
Flash options for sony camera
I recently had the same frustrating problem. The top of the camera has a little black button that can change from continuous mode or single picture mode. It has to be on single picture mode to change the flash setting. After this is changed you can press the flash setting onthe dial and change the setting. I hope it works for you.
Dec 28, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Cannot change my Mitsubishi WS-55615 to switch from 480 to 1080I
You cannot change the setting on the TV itself. you need to go through the settings on the equiptment you have plugged into the TV to change their settings to display a different resolution.
Sep 15, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Want to change default settings for scan
change the size, then utility/counter - > choose user settings - initial settings and use current settings.
should work,
May 27, 2008 | Konica Minolta bizhub C351 All-In-One...
Taylor 1541 Wireless Weather Forecaster With Barometer Logo
74 people viewed this question
Top Taylor Measuring Tools & Sensors Experts
deton8 von Splosion
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
