Question about Makita 651282-3 Switch For 9227 Polisher
Rewiring Makita 651282-3 switch - Makita 651282-3 Switch For 9227 Polisher
Can i bypass the switch on a makita skill saw
OMG, absolutely NOT!
I know a guy without 3 fingers due to one of those on a construction site. He said he never felt a thing.
Buy a new switch.
  • Makita Canada Inc. www.makita.ca Makita Canada: The best in class for cordless power tool technology. A leader in power tool technology for the professional.
  • Makita Saw Parts ' Great Selection ' Great Prices ... www.ereplacementparts.com/makita-saw-parts-c-97_98.html Fix your Makita Saw today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide shipping, no hassle returns.
  • images of makita saw parts bing.com/images th?id=oip.m79ac54922c7af758ce5909fe9cde9163o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m8226e4e7540d1403e6b34f0609fee8ado0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mc9c1b6c779ab4de644cda35842865ffbo0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mfb5ac75b7411568957f4d7028521f0b4o0&w=80&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdd935730eb9fe8614bf23952794b8ca9o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.md1140885e7ec8b5124cabfe71fdb3085o0&w=87&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of makita saw parts
  • Makita Power Tool Parts - Makita Parts - eReplacementParts www.ereplacementparts.com/makita-parts-c-97.html We have the genuine Makita parts and tool repair help you need to get your power tools running like new again.
  • Makita Parts - Tool Replacement Parts ' Tool Parts Direct www.toolpartsdirect.com > Brands Makita Tool Parts - Shop Makita parts online at Tool Parts Direct. Over 38,000 Makita replacement parts and schematics available.
  • Related searches for makita saw parts
  • Makita Tool Parts :: Makita Saws - Tool Parts Canada ... www.toolpartscanada.com/makita-tool-parts/makita-saws-page-3.html Please choose your tool from Makita Benchtop line below view parts breakdown
  • Makita Saw Parts ' Sears PartsDirect www.searspartsdirect.com > All Brands > Makita Parts Shop the best selection of Makita saws repair parts and accessories at Sears PartsDirect. Find replacement parts for any Makita saws repair project.
  • Makita - Authorized Factory Service Centers www.makitatools.com/en-us/Modules/Service/ServiceCenters.aspx Makita Authorized Service Centers meet our high-quality ... Genuine quality Makita replacement parts; Most tools repaired within 3 days; Maximum Repair Cost Program;
  • Makita Saw Parts ' eBay 9k= www.ebay.com/bhp/makita-saw-parts Find great deals on eBay for Makita Saw Parts in Corded Circular Saws. Shop with confidence.
  • PARTS - Makita UK https://www.makitauk.com/shop/parts Parts . Ask Makita ' Find a dealer. Part search Search for tool drawing: Filter: 1 - 2 - 3 - 4 ... Contact Makita! 01908 211678. Monday - Friday 8am to 5:30pm.
  • Makita Tool Parts - Tool Parts Canada - Parts that makes ... www.toolpartscanada.com/makita-tool-parts.html Please Choose Makita category Below Which Matches Your Tool
  • Jun 20, 2016 | Makita Saws
    Field coils burned, rewired how to connect to brushes and switch
    Makitatools.com is a company website, look under support,tablesaws, manuals.
    Good luck
    Dec 07, 2014 | Makita Saws
    Type your problem for a solution...no power
    Check the brushes: they should be over 1/4" long, the springs should be intact and pushing the brushes into the armature and they should slide easily in the brush holder. Using a volt meter, check that you are getting full power to the switch. Next check that power is getting through the switch when the swtich is held on. If all of these check out you may have shorted or burnt windnigs on the armature or field.
    Jul 19, 2012 | Makita 6013BR 63Amp 12Inch Drill with Top...
    I havebeen using a makita 9527 pb 4.5" angle grinder and all the sudden the grinder had troubles working all the time at first it took a little shaking to start up then hitting against a hard surface...
    There are various causes of failure but the checks should be carried out in this order, you will need a continuity meter or multimeter to trace continuity from the plug to the switch in the grinder:
    If plug is rewireable check for loose screws at plug pin terminals, loose fuses etc.
    Wires in power flex breaking, usually at plug or where flex enters machine.Check the continuity from each pin of the plug to the switch in the grinder
    Faulty on / off switch or loose spade terminals on switches.
    Worn out brushes.
    Armature or field coils of motor going open circuit.
    Mar 28, 2011 | Makita Garden
    I have ordered replacement switch for my 1/2" Makita model #DP4700. Switch #651314-6. I'm confused as to rewiring the switch wires. There are 2 wires in the housing, both back, one appears to connect...
    If the part is an exact replacement for what you have, what is the issue. U just replace it in the exact same way that the old switch is wired.
    Sep 19, 2017 | Drills
    Makita table saw switch wiring
    i need the owner/operator manual for a makita table saw model 12711 please tell me what steps to take to get one
    Mar 01, 2009 | Makita Saws
    Makita 14.4v wont work in forward
    I would suggest going to the Makita site and downloading a breakdown for this tool first. The switch replacement is not that difficult to do. If you are comfortable with taking the tool apart to look for debris (possibly pieces of fan) that would restrict movement. Sometimes if it breaks pieces get behing the trigger and won't allow it to shift, if it is broken you need a new motor. Pay close atttention to the wiring it is polarity sensitive and if nott rewired correctly will burn up a new switch. Hope this helps but like I said it is not that a major repair if you just take your time and watch how things come apart.
    Dave
    Dec 26, 2008 | Makita 3/8" Dr. 14.4V Cordless Drill Kit
    Makita 9227c stall
    Hi hope to help
    Have you tried this unplug the machine! then cut the cable about 6" from the machine then strip the machine and rewire the long length of cable back to the switch. The 6" that has been cut from the machine discard it.
    The problem i used to get is where the cable is clamped in the handle the wire inside the insulation cracks so that when the machine is in one position is ok but then when is moved it goes off again.
    It also could be the field coil (part of the motor) if it gets hot then cuts out the field could be braking down!!!
    hope this helps.
    Feb 29, 2008 | Makita 7" Electronic Sander - Polisher...
    Makita 651282-3 Switch For 9227 Polisher Logo
    16 people viewed this question
    Top Makita Tools & Hardware - Others Experts
    Jim Thurston
    John Porter
    Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
