Question about Trust SpaceCam 320 Webcam
Spaccam 320 problem
Ok i bought new pc desktop computer i launvched it got it running installed my cam and so on.den i had to do a reboot..did it installed my cam again and it said could not find driver even tho i have the cd really starnge...den a windows problem solution bar comes up and says my microsoft vista is not compatible with my cam even tho it worked fie b4 this reboot i did please can you help me
    Genius:
  • 1,139 Answers
Hello mid85, Welcome to Vista. The banner was correct. The fact that it worked at first was a fluke. Let me explain. The driver worked the first time because something messed up in Vista and the driver made all the proper connections with the OS and application to work, but this was a mistake kind of like falling off a moving motorcycle and finding one million dollars (It just does not happen every day). You can try to replicate the install, and this might work, for the most part you have to get all of the upgrade downloads from microsoft and somewhere in all of that will be a utility that will allow you to uae your camera.
Posted on Sep 26, 2007
SOURCE:
Gateway 2005 gx7022e pc was running fine and now out of no where when I turn it on it beeps three times and monitor says no signal and goes black. The tower itself is running very loudly
1)check weather the ram is properly installed on board or not
or reconnect it
2) or clean the ram with eraser n check it out
3) if still its not working den remove the ram from board n switch on the pc n check for beeps if u r getting beeps then motherboard is ok n ram has problem den replace the ram
Nov 17, 2015 | Gateway Computers & Internet
Hi there! i just bought a new acer aspire m5641 (the rep told me that the computer doesnt come with an OS but when i booted it, linpus is installed) on my CPU there is a sticker that states...
Stop: 0x0000007B error code refers to memory issues
You need make some changes in your computer before installing XP
1. On start up, press F2 to enter BIOS 2. Expand the "Drives" section 3. Go to "SATA Operation" 4. Change this from "RAID Auto/AHCI" to "RAID Auto/ATA"
You will be able to install XP now
Jun 30, 2011 | Acer Aspire M5641 PC Desktop
Blue screen problem
hello
Try this
To Select Last Good Known Configuration and manually install the new driver:
Approximate Troubleshooting time: 5-8 minutes
Reboot the PC and press F8 at startup
Select Last Known Good and let the PC boot
Browse to: C:\Drivers\System\UTLIntelMatrixStorageMgr3\
Run iata86enu.exe and follow the instructions (next, next…)
In the event you get pop-ups that the installer cannot find a particular file, hit the Browse button and point to the directory:
C:\Program Files\Intel\Intel Matrix Storage Manager\Drivers\
At the end of the install, accept the option to reboot.
Login to the PC and verify the new driver installed.
Open Device Manager and look for the Intel SATA controller (the name will vary between models)
Open the device.
Go to the Driver Tab (at the top). Click Driver Details.
Verify that iaStor.sys is now version 8.6.0.1007
Mar 17, 2010 | ASUS Eee PC 701 Notebook
Haw i reinstall my cam plz?
go to device manager(rightclick my computer ,properties-->device manager),, den select ur web cam and uninstall it. now unplug and den replug d web cam ---> install d drivers and den reconnect it again ...
Feb 09, 2010 | Genius Look 110 Webcam
The install shield doesn't finish working
Try copying the files on the disc to a folder and run them from there. Open the folder you saved the files in then double click the setup.exe icon and see if it completes the installation. If that does not work then try downloading the files from the radio shack web site.
Sep 08, 2009 | Radio Shack VGA PC Camera Webcam
Cannot get on line
Try to boot into safemode and den acess the internet...
else turn off the firewall and try to connect online....
Also scan the pc for any virus...
Mar 21, 2009 | Gateway 3250S PC Desktop
Acer Aspire M1100 no signal to monitor when starts
Got the same model. Had the same problem.
Play with the memory sticks.
Remove all but one.
Swap out memory for different memory.
Worked for me.
Jan 31, 2009 | Acer Aspire M1100-U1402A Refurbished AMD...
Printer not printing
Uninstall everything. Reboot. Unplug the printer. Install the software. Reboot. When everyting is up. Plug in the printer. Have the driver disc ready, install the printer. Reboot, go to settings, printers and see if the printer is listed. If it is, make it the default printer.Good luck
Dec 20, 2008 | Computers & Internet
I bought a new key board. put the cd in the drive. at the end it does not install. i did a system restore, had to hit f-12 and the keyboard worked until the computer booted up. i have tried 4 key...
New keyboard especially the UBS keyboard cannot be use in BIOS or doing boot selection.. you must have an SP2 keyboard to do so.. TY
HOPE I CAN HELP
Dec 04, 2008 | Computers & Internet
Error 80070450 cannot run preview graph
ok all u hv to do is just plug out ur cam and remove the driver from add remove programes then reboot ur pc and install ur drivers without plugging in ur cam after installing plug in the cam and click on found new hardware and click on no not this time make sure u r connected to internet and after that enjoy ur cam show ..bye
May 25, 2008 | Computers & Internet
Open Questions:
See all Trust SpaceCam 320 Webcam Questions
Trust SpaceCam 320 Webcam Logo
281 people viewed this question
Top Trust Computers & Internet Experts
B.Th. Pluijm
B.Th. Pluijm
Norman Al-Anbar
Argospete
Argospete
Are you a Trust Computer and Internet Expert? Answer questions, earn points and help others
