I just changed the black and the cyan inks. Now I have two stripes across the top horizontally and two across the bottom. The printing is not aligned properly. It is leaving some copy out. It was working perfectly before I changed the ink.
  • 526 Answers
Generally , 1-2 cleanings will solve the problem. However, if you waited too long when the printer said to replace the inks, you may have actually clogged up the nozzes.
so try some cleanings, if that does not work, it will most likely need to be sent in for repair.
Posted on Apr 24, 2009
THE PRINT IS NOT CLEAR
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
Apr 17, 2013 | Lexmark Office Equipment & Supplies
Can print the color I want. Only prints red.
Aug 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Lexmark x 3350 multifunction. USB connected, reinstalled latest software for device from lexmark. Print quality is terrible and does not start at top of page - maybe 10 lines down. Also, new ink...
Aug 24, 2009 | Office Equipment & Supplies
I put a new ink cartrige and printer prints low coulour tone.
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark Color JetPrinter 5700 InkJet
Can't print in color
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
How to clean Lexmark Z1320 printer.
hi..
You can clean the cartridge using the following steps:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
try out..
Apr 23, 2009 | Lexmark Z1320 InkJet Printer
Problem with canon pi 4000
I think you have to clean the print head.and if cleaning doesn't help you may have to get a new print head.
May 01, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Ink cartridges wont print
same problem!!!!! temping to get another printer - help!!!
Dec 19, 2007 | Canon BubbleJet i560 InkJet Printer
Horizontal stripes on images
may be the ink level in ur ink jet printer is low try and use genuine ink for ur printer . i also have the same problem . when i replaced with original ink it gets ok
Dec 03, 2007 | Canon BubbleJet i560 InkJet Printer
110 people viewed this question
k24674
jasbo
jasbo
