Question about Kenwood KAC-7202 Car Audio Amplifier
Red light on but sound comes out - Kenwood KAC-7202 Car Audio Amplifier
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
On my fender blues deluxe, there is a red light which is usually off. I get intermittent loss of sound, and when this happens, the red light comes on. Any ideas what's wrong? Many thanks Brian
Hi.
If the red light is coming from a tube and you notice a loss of sound when it lights up, try reseating the tubes. You have to make sure that the amplifier is cool and is not plugged in to any power source when you do this and you have to be very very careful with the glass tube as well.
If the red light comes from an LED, it may be an indication of a bad wiring. Check if all wires are in good condition and are soldered correctly.
I hope this helps. Thanks. :-)
Apr 28, 2011 | Fender Hot Rod Deluxe Guitar Combo...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
When DVD uses DTS Sound, doesn't use 5.1
The bitstream sent out by the BluRay player is selectable via menus on thedisk. And the player itself may have a menu that allows it. Would need to know more about the source.
Feb 21, 2010 | Technics SA-DX950 Receiver
Red light coming from the headphone output
Red light is digital signal intended for optical audio receiver. Change audio output to analog in control panel under sound.
Jul 20, 2009 | Computers & Internet
The audio light is red whether the sound is muted or not
1) Try updating your sound drivers, they probably control the light. It could be a hardware issue, and if the drivers don't work, there may not be any solution for you.
2) You should go into control panel and into your sound settings. There should be a number of devices listed. One of them is your HDMI output. You need to click on it and set it to the default sound output device. When you unplug your HDMI, you may need to do this again to get your regular computer speakers working.
Jun 22, 2009 | HP Pavilion dv7-1130us laptop
Will not come on
Sounds like a problem with the stand by votages. Possibly a low voltage regulator. Is the model number a 43H70?
May 03, 2008 | Toshiba 43H70 43" Rear Projection...
Kenwood KAC-7202 Car Audio Amplifier Logo
13 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
