Hi, my hotpoint wmf740 is showing error code F-02 and the drum wont spin.
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet-Error code F 02/wont spin and drain
Yes...the "F02" error code is a "Long Drain" error. The washer will not spin if it cannot drain the tub, first. The following link explains how to diagnose and correct the problem:
http://www.fixya.com/support/r615268-f02_error_code_whirlpool_duet_kenmore
In most cases this is nothing more than a clogged drain pump. Folow the steps outlined in teh link provided on how to check and clear the drain pump and drain lines. Now...it does not take much to damage these pumps. If anything has been left in the pump for a significant period of time it can cause irrepairable damage to the pump impeller and/or motor. The result: a drain pump that MAY run, but won't actually pump anything.
If this is the case, you will need to replace the pump. Replacements can be obtained at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Pump and Motor Parts" heading for item number 10. This next link will provide you with the steps necessary to replace the pump (if required):
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Nov 09, 2008
miket756
  • 2702 Answers
SOURCE: Hotpoint aquarius WMF740 (1 year old) - noisey spin
its the drum bearings there worn out try opening the door and lifting the top of the drum with your fingers if there is any life and the drum drops back when you let it go its them bearings,, then spin the drum by hand is should grumble or growl,,,if it dont do any of this, it could be the "spider" broken off, its an ally part that holds the drum bearings and the drum up,
Posted on Mar 07, 2010
  • 353 Answers
SOURCE: Washing machine showed error code F-02 (that cycle
check motor caRBONS
Posted on Jun 11, 2010
Testimonial: "Motor broke, have to get a new machine... Thanks!"
  • 353 Answers
SOURCE: I'v got a code error f-05 on my hotpoint washing
Clean filter and pump
SOURCE: I have a hotpoint aquarius wmf740 that is showing
Something wrong the pump would prevent the machine draining and generate an F5 code.
http://appliancejunk.com/ge/washer/31-9103.pdf
Service manual above.
Posted on Jun 25, 2010
Washing machine wont spin f-02
The Hotpoint F-02 error code is associated with a Motor Fault, now strange as this may sound, but it possibly wont mean the motor is faulty, it simply means the main PCB in the machine has sent a signal for the motor to start, but it's not receiving one back to say it is going.. Usually if you can turn the drum by hand, then the fault would generally be the Tacho of the motor, this is a small device on the back of the motor with two wires coming from it. Check to make sure the Tacho hasn't come loose or fallen off, then one by one remome and reattach the connectors going to the main PCB, vibration can cause these to become loose...Good Luck
Jun 26, 2014 | Hotpoint Washing Machines
Hotpoint aquarius wmf 740 has error code h20
Just had same problem with my hotpoint wmf740 showing h20 and found an easy fix was to clean out the detergent draw thoroughly and just behind it.to remove tray was easy and it does say to do this regulary in the manual
Jul 16, 2012 | Hotpoint Ultima WF860 Front Load Washer
Hi got hotpoint aquarious wmf740. all lights flashing f-05 ? wont spin or drain. please help
Hi
Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer.
Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps...
Daniel
Aug 30, 2010 | Washing Machines
I have a hotpoint aquarius wmf740 that is showing a fault f--5 and wont empty out the water
Jun 25, 2010 | Washing Machines
My washing machine is a hotpoint ultima and it is 4 years old . the drum is not spinning and an error msg f-02 is displayed
fo2 is a motor fault, possibly the motor tacho, brushes, broken wire to the motor or module board is faulty.
Apr 07, 2010 | Hotpoint Washing Machines
Mar 07, 2010 | Washing Machines
Hotpoint ultima wf840 drum jammed display saying error code f 02 can any 1 help
Error F-02 is a slow drain problem. Undo and remove the wide tapering pipe from the bottom of the drum to the pump. Inside you will find a non return ball valve, clean this and your problem should be solved
Jan 08, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
