Question about Seville Classics Dryers
Need tyj50-8a motor - Seville Classics Dryers
Have fitted new electric motor to 2001 ezgo golf cart. Supplier insists its the correct motor .hooked up the same as the old motor but it wont run any ideas
Did everything work before you replaced the motor( except the motor)? If you have a lever by your right leg then you need a series motor. If there is a rocker arm switch in the dash then you need a sepex motor.
Sep 13, 2017 | Golf
Ruud UPMA-036 - need info on condensor fan motor, in particular replacement part #, and rpm. Does the fan motor need oil, what oil weight ? Thanks
Your condenser fan motor has sealed bearings and does not need lubrication.
On the side of the motor is a data plate that has the make and model of the motor. Enter that information on google or another search engine. Motors are fairly easy to change if you are handy and are redly available.
Aug 14, 2016 | Ruud Heating & Cooling
I need the part number for the starter motor for my Pajero
You don't need the part number as it depends on the maker of the starter motor.
  • mitsubishi pajero starter motor ' Cars ... - Gumtree www.gumtree.com.au/s-automotive/mitsubishi+pajero+starter+motor/k0... Find mitsubishi pajero starter motor ads in our Cars & Vehicles category. Buy and sell almost anything on Gumtree classifieds.
  • MITSUBISHI PAJERO IO STARTER MOTOR ' Starter Motor ... www.startermotoralternator.com/.../mitsubishi/pajero-io/starter-motor MITSUBISHI PAJERO IO STARTER MOTOR - Extensive Starter Motor / Alternator catalogue searchable by make, model, year and engine size.
  • pajero starter motor ' eBay www.ebay.com.au > Search > pajero starter motor Find great deals on eBay for pajero starter motor pajero diesel starter motor. Shop with confidence.
  • mitsubishi pajero starter motor ' eBay www.ebay.co.uk > Search > mitsubishi pajero starter motor Find great deals on eBay for mitsubishi pajero starter motor mitsubishi pajero 2.8 starter motor. Shop with confidence.
  • Mitsubishi Starter Motors - Auto Electrics Direct - buy ...
  • www.autoelectricsdirect.com.au/index.php?_a=category&cat_id=15&... buy now online auto electrical parts, online shop,starter motors, alternators,smart solenoid, hid lighting, air- conditioning parts and accessories ,best quality ...
  • Pagination
  • MITSUBISHI COLT PAJERO CANTER L300 EXPRESS HYUNDAI SONATA LANTRA 12V 1 4...
    May 20, 2016 | 1994 Mitsubishi Pajero
    What size generator do I need to run a 10 hp motor
    on the plate attached to the motor you will find several important items
    one is the wattage of the motor
    this is the maximum wattage that the motor uses when under load
    the gen set will need to be at least 30% bigger than that figure
    next there will the number of phases that the motor is
    it will read as 1 ph or 3ph
    If it is 1ph that is a single phase motor and will ru from a single phase gen set
    however if it is 3ph you will need a 3ph gen set to run the motor
    As most single phase motors are limited to around 5hp I would be very sure that the motor is not 3ph
    specialist advice from an accredited electrician or electrical motor shop is recommended before buying a gen set. as if you need 3ph the gen sets become expensive.
    Aug 07, 2015 | Electrical Supplies
    Need a pool pump motor schmatic
    called the shaft seal, need to know what kind of pump ? take out old seal both parts, spring side and ceramic (white) part and bring to local pool supply, ask how it should be installed.
    May 29, 2012 | Smith 2hp Pool Pump Motor A O Electric...
    A/C tech tells me the replacement motor I am using is pull 2.3 amps and the unit wants 2.5 and so the motor shuts off. But the plate on the back of the condenser says it should be 1.6 amps. I would like to...
    The fan blade size, pitch, rpm, number of blades and diameter, determine the motor size and rpm.
    If your condenser says it should be 1.6 amps and you have 2.3 amp motor in the unit, you have a stronger motor than you need and the motor should not be getting hot and shutting off.
    You need to make sure somebody didn't change the blade or the rpm of the motor or the rotation or direction the motor turns. If those are correct then you need to make sure you have the right size capacitor, The size (microfarads and volts) is usually on the motor nameplate. If it's the right one then you need to have it checked and make sure it's good.
    Jun 10, 2010 | Heating & Cooling
    Intertherm blower motor is shot and i need a one thats compatable
    yes bring the motor to a a/c service dealer and they can match it up for you
    Jul 03, 2009 | Heating & Cooling
    Dryer not turning. belt is good
    Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
    • Remove the belt.
    • Check for obstructions in the blower fan housing.
    • Manually rotate the shaft of the motor.
    If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
    If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
    If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
    Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
    Dec 17, 2008 | Whirlpool Dryers
    The tub that holds the clothes does not spin. The water goes in and it takethe soap and softner but will not spin. The timer works and it seems to go through the cycles and fillls and emptys but the tub...
    I've only seen one of these belts break in my 7 years of fixing Neptune's. I have replaced dozens of motor/ motor control board kits. Maytag upgraded the washer motors about 5 years ago, if yours is older it's probably got the older style motor. If that's the case you need to verify that the motor control board is getting power from the main control board, if it is, then you need to replace both the motor and motor control board (it comes as a kit). If it isn't you need to put 120 volts to the motor control board and see if the motor spins at 50 rpm (normal agitate speed), if it does, you just need the main control board, if it still doesn't run you need the main board and the motor/ motor control kit. If it has the newer motor, you would also need to test and replace the motor and/ or the motor control board separetly.
    Jul 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Need to replace turntable motor
    hi,
    There are many different models that use the same motor for the turntable. If your unit is the model # JVM1842BD001 you need the motor # WB26X10038 if you have the JVM1460SJ you need the motor #WB26X10135. You should be ok using a motor from a different model as long as all the numbers and wires match to the original motor itself. BTW, these motors sell on auction sites for about $20-30
    Mar 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    Dryers Logo
    16 people viewed this question
    Top Seville Classics Dryers Experts
    Dan Webster
    Dan Webster
    Are you a Seville Classics Dryer Expert? Answer questions, earn points and help others
