Question about Lenovo IdeaCentre K210 Intel Desktop Computer - Intel Celeron Dual Core E1200 1.6GHz, 2GB DDR2, 320G
Corupt harddrive I dont have the disk to crash my p.c. Is there a why I can do it with out it. please help!!!
Many time I have experienced the same problem. I went to Microsoft Windows, or whichever version you are using and ask for a boot up cd . They are ususally okay with it, It cost me about 20.00
I hope this helps out.
deb
Posted on Apr 20, 2009
  • debrascross Apr 20, 2009
    Did I understand you correctly? you want a disk to crash your system? why?
  • 32 Answers
I am sorry if I don't understand, "the disk to crash my p.c."? Do you mean that you don't have the disk to get p.c. fixed that crashed? Your p.c. crash and you can't get going? 1) What kind of p.c. do you have?[Dell,IBM,Compaq, etc.] 2)How much memory?[RAM that turns on the p.c.] When the memory chip goes bad,or in moving the pc, the chip can be phycically disconnected from mother board.Will provent pc from turn on. Win 98, win_me, Win_xp:: What o/s[operating system] do you have? [email protected]
Posted on Sep 26, 2007
SOURCE:
Hp pavilion dv21015ee
Probably the connecting cable of hardrive is loose or the hard drive has crashed, or the power to the harddrive is not connected.please check.
See if that helps.
Dec 15, 2013 | Computers & Internet
Hi, i was using XP Sp2.....windows use to get
Sounds like its a harddrive problem. If you can, format and reset your laptop and see if the issue persists. If so I'd recommend taking it to your local pc store.
NOTE: resetting your laptop will delete all your data
Oct 06, 2013 | Acer TravelMate 4740
WhenEver i turn on my Inspiron 1525 it gives me the error "Intenal No bootable devices . Strike F1 To reboot .... " What can be the problem I dont have backup of my data . What should i do to...
it can mean 2 things, either the boot sector is gone, or your harddrive have been crashed.
if it is the first, the most easy thing to do is to put in the windows cd and start a repair of your system.
if windows tells U he cannot find a hard drive, them I am affraid that the disk has been crashed ...
Jun 16, 2011 | Computers & Internet
My xbox 360 halo stopped ripping my music cd`s and i still have alot of space on my harddrive
the disk is bad or the console cant transfere the music for sum odd reason try disconneting from live and try if that dont help you can serch for corupt data on the hard drive or format/clear all previous music thats been stored or try moving it over from a flash drive from a computer
Dec 08, 2010 | Video Game Consoles & Games
Why is it when i go to start my computer it doesnt wanna load windows, it says disk boot failure, insert system disk and press enter. My computer was working fine right before. can someone please tell me...
Hi, the computer is not detecting the hard drive or the hard drive is corrupt. At startup you are likely to hear a knocking sound if the hard drive is physically damaged. You can go to bios setup at startup ( could be F1 or Esc). Once there it should indicate if there is a harddrive or not. If it indicates none there the harddrive might have crashed and will need repalcing. I hope this helps.
Aug 12, 2010 | HP Pavilion a706n PC Desktop
When i switch my ps3 on it says hard disks file system corupted
http://www.ehow.com/how_5909868_fix-hard-drive-disk-corrupt.html
Right get yourself, 3.5 sata usb dongle. Remove the hard drive from the PS3. Connect, the hardrive into the closure and connect it to your computer. format the harddrive and put it back into the PS3, this works a lot of the time, if this doesn't work, you need a new HDD, just get an identical unit.
May 09, 2010 | Sony Playstation 3 (PS3) Console
Missing file or corupt disk
windows has crashed and needs to be reinstalled
May 08, 2010 | Computers & Internet
Iturn on it says cannot start the correct Hard disk was not found
Open up your ps3 on the right site with a small flat screw driver.
Turn out the blue screw with a small cross screw driver, slide the hard drive to the left and pull it to warts of you, note it is a 2'5 inch sata notebook harddrive.
Hook it up to a pc or mac to run a diagnostic check on it to see if it is crashed, by the way you're able to tell by the sound it makes if it crashed.
Aug 28, 2009 | Sony Playstation 3 (PS3) Console
FULL fantom external usb harddrive is not acknowleged after power outage running check disk.
ACS Data Recovery specializes in Fantom hard drives, and can perform successful recoveries on any model Fantom hard drive. If you have a crashed Fantom hard drive, please call us today to get a quote: 1-800-717-8974
unless you fancy trying to connect the drive inside the unit directly to a pc by taking the box a part.
Jul 18, 2008 | Fantom Titanium Hard Drive
SimpleTech 500GB Hi-Speed USB 2.0 causing Windows to crash
Blue screen means hardware problem, Try to defrag your hardware possible bad sector problem. Just follow the procedure as follow: Click Start> Programs>Accessories>Disk Deframenter.
After opening fragment's system select the drive by highlighted the available drive and click defragment button. Just wait until done. It will automatically fix the bad sector if not so critical.
If the problem persist during the defragment, there is a critical problem with your harddrive.
Please rate me SOLVED
Nov 21, 2007 | SimpleTech 250GB USB2.0 7200 RPM External...
Lenovo IdeaCentre K210 Intel Desktop Computer - Intel Celeron Dual Core E1200 1.6GHz, 2GB DDR2, 320G  Logo
144 people viewed this question
Top Lenovo Computers & Internet Experts
Alun Cox
Ekse
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
