Question about Epson Stylus NX400 InkJet Printer
My epson nx410 keeps spitting out balnk pages; it sounds like its printing but always comes out blank. I've tried everything from downloading from the epson website unplugging restarting the computer. i have a new laptop; is my printer too old for the new system? I just bought new ink cartridges too for this blasted thing :(
silly girl
  • 513 Answers
SOURCE: My Epson 680 Printer only gives me blank pages
First of all, there is the seller's liability here. If it's from eBay, there's some protection feature for you to use. The "prints blank pages" problem is believed to be caused by a clogged purge tube. Here is a guide I found that exlpains the problem, and how to solve it: Recently, after changing out the blank ink tank on my finacee's Epson CX5400 multifunction inkjet printer, the printer began printing nothing but blank pages. Even after doing multiple head cleanings and test prints, pages would emerge from the printer completely blank. After some research, a number of fellow CX5400 owners have reported having the same problems, to the extent that the term "design flaw" became a common theme. I've owned several Epson printers and have had, generally, good luck with them. I was always somewhat suspicious of Epson's philosophy of making the print heads a permanent part of the printer and having the only replaceable part be the ink tanks, but it produced good-looking prints so it didn't bother me. Now I know, unfortunately, that this system is both a blessing and a curse. Before we delve into how to fix your blank-page-printing problem, a quick explanation on how Epson's ink delivery system works (or, rather, how it appears Epson's ink delivery system works, because Epson isn't exactly willing to divulge its trade secrets) is in order. There are a few components to the delivery system. First, you have the ink tanks. Early Epson tanks were just that; plastic boxes with a sponge inside saturated with ink. Newer tanks have a small PCB with a flash chip on it, so the printer can tell if a tank is new or used, or if it's an Epson brand cartridge or a generic replacement. In either case, the basic functionality is that it's a holder for the ink. Next in the chain are the ink tubes and primer. I've heard conflicting reports on how Epson printers get the ink out of the tanks; some believe that the tanks are positively pressurized when first installed, so that ink shoots out of the tank when the printer needs it. Other reports say that the printer puts negative pressure on the cartridge to draw ink out of it. Once the printer has the ink out of the cartridge, there are two places it can go, to either the print heads or to the purge tube. The print heads are what makes the ink spray onto the paper; the purge tube is where the ink goes when the printer primes new cartridges and cleans dirty print heads. Many cases of the "prints blank pages" problem occur right after installing new ink tanks. People have literally removed empty tanks from printers that work perfectly, and installed new tanks to find that the printer delivers blank pages (this happened to me). Since it's highly unlikely that the print heads have become clogged during the 5 minutes it takes to swap out the cartridges, the problem has to be elsewhere in the ink delivery system. So here's what happens when you install a new ink tank: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The ink flows through the purge tube into the internal absorbent pad. 4. After a couple seconds, the printer stops the priming sequence and probably does a quick print head cleaning. Now, a few people have done some in-depth troubleshooting and found that the "prints blank pages" problem is actually caused by a clogged purge tube. While this may not immediately make sense (you may be thinking, "so what if the tube is clogged, the ink will just spill inside the printer elsewhere"), here's what my research suggests happens when the problem occurs: 1. The new tank is installed, the printer recognizes that it's a new tank, and begins the priming sequence. 2. The printer starts to prime the tank. Ink comes out of each tank and is directed to the purge tube. 3. The tube is blocked, so the ink has nowhere to go. 4. After a couple seconds, the printer stops the priming sequence. Epson's ink delivery system appears to be a sealed system, so when the ink has nowhere to go in step 3, little ink has actually escaped the new ink tanks. This means they're not primed correctly, and won't deliver ink as they need to when the printer goes to print. So unless the purge tube gets cleaned out, you can swap tanks and perform head cleanings until the cows come home and it won't do any good. Now that there's a basic understanding of what's going on, here's how to try to fix the problem. This guide is meant to be model-agnostic; I did this procedure to a Stylus CX5400 multifunction, but it should be similar for most Epson inkjets made in the past few years. It's unknown if new Epsons still have this problem, as it usually takes a year or more to surface. The first thing you need to do is prepare your work surface. You'll need a big table, preferably one you don't care too much about. If all you have is your good kitchen table, then it's a good idea to slice open a tall kitchen garbage bag to make one large sheet, and tape it to the table to protect it. Next, you'll need the following tools and supplies: (View attached picture)
Posted on Jun 27, 2006
Basti
  • 1447 Answers
SOURCE: printing blank pages
hi-
You might be having a clogged nozzles, if you want you can try to dismantle and check on the nozzles, heres the link on how to check it just click HERE
Pls rate as fixya if it helps. Thanks!!
Posted on Jun 17, 2008
acdr
  • 1913 Answers
SOURCE: Epson All-in-on inkjet printing blank pages only
refix your ink cartidge then try.
Posted on Jan 05, 2009
SOURCE: Please help me, my epson inkjet all in one printing just blank blank blank
I have the refillable cartridges and they work great. They come with the "chip" that resets every time you turn it off.
Posted on Jan 08, 2009
  • 159 Answers
SOURCE: epson cx8400 can`t recognise the ink cartridge!!!
If you mean you have a chip resetter and have reset the chip when you say you've "shock the ink cartridge" then it sounds like the chip on the cartridge is damaged and can no longer be reset. To fix the problem you either need to get a replacement chip or a new cartridge.
Posted on Mar 23, 2010
Cant get my Epson Workforce 633 to print. WILL NOT print black.
check if ink came out of the head or nozzles if not then first open the nozzles and head with warm water.
Feb 10, 2015 | Epson WorkForce 633 All-in-One Inkjet...
Hi, thanks in advance for any solution suggestion. My xerox pe 220 prints blank page. Cartridge is new. Th poblem should be with the driver, installed it several times, but it doesn't help. Can anybod
Does it sound like it's trying to print or does it just quickly spit out a blank page. If you print something three pages long, do three blank pages come out??
I know this may sound silly, but did you remove the piece of tape that covers the contacts on the new print cartridge?
Nov 25, 2013 | Xerox Computers & Internet
My HP F4280 says it's printing but the pages come out blank. How do I get them to really print??
uninstall the reinstall the driver for the printer from the HP web site for that printer and the win operating system you are using
Jan 01, 2018 | HP DeskJet F4280 All In One Printer InkJet
Printing blank pages with only website
which browser do you use check it by changing browser and with different web pages
Jan 27, 2013 | Epson NX215 All-In-One InkJet Printer
Invisible printing
Lost electricity to head micropiezzo (micro pump). Usually caused by ink leakage that flow to small board at head carriage. Better take to epson service centre. If you wish to repair yourself, find similar solution on aicaxz solution.
Feb 19, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus NX410 won't print in Adobe Illustrator CS
Try to print your file in jpeg or tiff format.Good luck!
Jan 12, 2010 | Epson Office Equipment & Supplies
We are trying to install an Epson NX410 on a HP dv6-1362 running Windows 7 Home addition but can not get it to install. The HP will only see the scanner. We could install the Epson NX410 on a white box...
hi there..
if you are downloading the combo package driver, and your having an issue. thats normal. combo package driver of epson usually have issues, so they suggest to download the driver separately. since you already download the scanner, download the driver and make sure that you select the right driver, because there are 2 types of windows 7, 32bit and 64 bit, if you are downloading 32 and you have 64, it wont work and vice versa, so double check.
download the driver from this link according to your os.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=128287&prodoid=63083741&BV_UseBVCookie=yes&infoType=Downloads&platform=Windows&x=26&y=10
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Dec 08, 2009 | Epson Stylus NX400 InkJet Printer
Prints extra blank page for every one page of printed material
hi,
try this
> unplug the usb cable from the computer
> click on "start--> control panel--> printers and faxes"
> select the printer icon associated with your printer and delete it.
> now plug the usb cable to the printer
> wait for few minutes while all the drivers are installed.
thats it... now try to print... it should be resolved
thanks and regards
agnel
Mar 17, 2008 | HP Photosmart 2710 All-In-One InkJet...
Epson Stylus NX400 InkJet Printer Logo
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
