Question about Onkyo TX-DS575 Receiver
Resoldering of Q710
I found that by unplugging and replugging the ribbon cable to the circuit board containing Q710 the amp worked perfectly for a while and stopped again. I tried that a few times and now there is no sound at all.
I have been informed that I should resolder the connections on Q710. On my circuit board Q710 seems to be a surface mounted micro chip with many minute legs. Am I looking at the right part? and how can this be resoldered without specialist micro soldering equipment? Should I be considering taking it somewhere for repair?
  • 20 Answers
Ask to switch that one out
Posted on May 11, 2017
  • Official Brand Answer
  • 333 Answers
Hello, I am sorry about your issue. I suggest having the receiver serviced. Thank you, Onkyo USA
2 Suggested Answers
simpleman40
SOURCE: Damaged Speaker Connection on Receiver
try swapping the speakers to see if your right speaker works on the left side.Is the jack where it plugs in loose?
Posted on Dec 05, 2007
It wont start. the hi temp and heavy button are the only buttons that come on
OK I am not an expert but I have spent the last two weeks learning about and fixing my dishwasher! Hopefully I can save you a headache. Try the following:
* Flip the switch off and on in your breaker/circuit box. May reset your washer.
* If that doesn't work, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If normal function still does not resume, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit/toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Hopefully some of that helps!
Jul 08, 2012 | Maytag 24 in. MDBH950AWS Built-in...
Washer will not start
There may be some additional instructions specific to your model hidden in an envelope behind the kickplate of your washer.
Jul 03, 2012 | Maytag Dishwasher
Wont turn on is thier a reset button
* Try turning off the switch for a longer period of time - 10-15 minutes. This may reset your washer.
* If any of your button lights come on but a regular cycle will not start, try running diagnostic/reset cycles by pressing heated dry -normal- heated dry or heated dry-sanitize-heated dry in sequence. If the cycles run fine, you will rule out a power, latch, motor/drying issue. It also may (hopefully) reset your system.
* If your buttons do not light up or normal function still does not resume after the reset, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit/toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is power getting into the machine and that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to the possibility of a control (button) panel issue and you may try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Jul 02, 2012 | Maytag Dishwasher
Dishwasher control panel unresponsive
* Flip the switch off and on in your breaker/circuit box for 10-15 minutes. May reset your washer.
* If normal function still does not resume after that, make sure your power (from the breaker box) is turned off and unscrew (with a star-shaped screwdriver bit - check your car emergency kit or toolbox, you may find you have it) and open the front button control panel and check all connections. Try carefully unplugging and replugging wires and look for any corrosion/moisture on the circuit board.
* If everything looks good but that does not work, test the circuit board by unplugging the green ribbon cable from the control panel, reassembling with the ribbon cable unplugged, flipping your circuit back on and then closing the dishwasher door. If the drain motor runs, it will show you that there is still some function with the circuit board. Although it doesn't rule out the circuit board completely, it will point to a most likely control (button) panel issue and try replacing that. If the drain test does NOT run, it may be the circuit board that needs to be replaced.
Apr 18, 2012 | Maytag MDB7609AWS Builtin Dishwasher
I have a Samsung household microwave oven model # SMH8165ST that when plugged in will beep a few times then blink "SE". None of the buttons will work.
Try calling Samsung....
Purchased samsung SMH8165ST in Oct 2009. have had the SE code problem for a few month now. Resetting worked at first. Then the light started flasing on & off along with the beeping...would not reset. Out of frustration I called Samsung. I was told they are aware of the problem & would repair in the "epidemic warranty". Repair man just left. It took him about 15 minutes to change out the keypad. No charge!!
Aug 30, 2011 | Samsung SMH8165STE Microwave Oven
Canon MP160 Error E42
Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Feb 19, 2011 | Canon PIXMA MP160 All-In-One InkJet...
No sound output
Known problem w/Onkyo. Resolder Q710 transistor on DSP board.
Onkyo is aware of this problem.
Apr 11, 2009 | Onkyo TX-DS575 Receiver
Help : Error 4
Check ribbon cable connecting scanner unit to base, it may have come unplugged from socket on circuit board. POWER OFF the unit before you do any work on it.
Once reset, you can power the unit back on and it should work..
Jul 19, 2008 | Canon PIXMA MP150 All-In-One InkJet...
DIM LIGHTS ON CONTOL PANEL
I had the same problem dim lights nothing happens when buttons pushed. I went through the trouble sheet that was in the drying and it pointed me to a bad control board. After replacing the control board it work. Awsome huh. Not it did the same thing a few hours later. I was able to unplug and replug and it worked for a bit and stopped again well after a few times of that it stopped all together. I was kinda upset after spending 135 bucks on that. I didnt want to put any more money into this machine. I took the machine apart and checked all the connections and wires. Removed the front panel and took all the ribbon cables off and made sure those were good too, (didnt short out) everthing checked out. For grins i replaced the 30 amp circuit breaker. The voltage was there but maybe its not getting the amps. I put the drying togeter enough to see what it dose. I didnt want to risk the chance of messing up the control board i bought while doing this so i used the OLD ONe. ( board was sitting on the dryer tub not bolted down). Well low and behold it works. I have been testing it for about 3 hours now. turning it off and on. change the setings on the dryer and so far it is still working. Before it would have messed up already.
Jun 30, 2008 | Whirlpool GEW9250 Electric Dryer
Onkyo receiver audio problem
Called Onkyo and here is the solution they gave me.
1. Turn on unit.
2. Press and hold VIDEO 1 button.
3. While pressing VIDEO 1 button, press Speaker A.
4. You should see "CLEAR" on the display for a second and the unit will go on stand-by mode.
5. Turn on the unit again and check if sound is back.
Hope this helps.
Mar 23, 2008 | Onkyo TX-DS575 Receiver
Onkyo TX-DS575 Receiver Logo
361 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
