Question about Irons
Rowenta dw9050 Water leaks from bottom
SOURCE: Water leaks from the bottom
Yes it is from the bottom of the boiler from a small opening, I guess a vent. Thank you for the help.
Posted on Jul 11, 2008
brnspncr
  • 67 Answers
SOURCE: rowenta dx8900 has a very leak in bottom on left
Sounds like the feed tube or tank is ruptured. It may be cheaper to buy a new one from wallmart or similar store.
Posted on Aug 04, 2009
maintenacemi
  • 95 Answers
SOURCE: water leaks
poly seal{white} perished where comes from tank to element plate
Posted on Nov 18, 2009
aquif1990
  • 190 Answers
SOURCE: I have a Rowenta Professional iron and it is
this is due to the rusting of steaming pipes inside your iron this is the reason for brown colour of water
Posted on Mar 30, 2010
SOURCE: I have a Rowenta Advancer 1800W and it leaks water
May I ask WHEN you bought it and WHERE??
I have the same problems too and I'm trying to figure out the same thing.
If it can't be fixed, than I am going to write to the manufacturer to explain our problem with this iron.
Thanks.
Posted on Aug 19, 2010
We have Rowenta DM 890 steam iron. It dumps water. Also Why not use distilled water?
The following web blog about Rowenta steam irons has some tips on maintaining the iron:
http://www.nasa1.org/iron%20rowenta.htm
The following web blog explains the issue of not using distilled water:
http://ths.gardenweb.com/forums/load/laundry/msg011421358265.html
I guess the bottom line is that it takes a higher temperature for distilled water to boil. It also explains that will cause the unit to spit, drip, and leak.
Try affordable spring water, and you should get better results.
Jan 27, 2011 | Rowenta Irons
Rowenta Iron leaking out of bottom and leaks on clothes
I have one of these and have been battling the leak problem for years. I'm a stubborn mechanical engineer and I'm bound and determined to fix this, when in fact I should just buy another, different, iron.
The problem is then 'handle'. Built into the handle is the water tank. The water tank is made from two pieces which are then glued and screwed together. Think of taking a coke bottle, cutting it in half, and then gluing it back together. Now you see where the problem comes in... the glue they use isn't up to the task, or the heat... or the pressure... is causing the tank to leak somewhere / everywhere.
I have disassembled this several times, meticulously scraped out the old silicone, and tried several different types of silicone to re-seal. So far it always fails. It's good for a while, but maybe a couple months, before it starts leaking again.
Conclusion... BAD DESIGN. Very disappointing, because in every other respect I like this iron better than any I've ever owned.
Jul 14, 2010 | Rowenta Power Duo Iron
I have a rowenta iron that leaks a lot of water
Here's a solution . . . Do NOT buy ROWENTA! I've had 3 Rowenta irons. All of them have eventually began to dump water out of the base. . . heck, the Titanic didn't leak as much as a Rowenta iron!
Dec 31, 2009 | Rowenta Perfect Iron
Water leaks from bottom as fast as you add it. It
Sounds like the tube ot tank is ruptured. It may be cheaper to buy a new one from wallmart or similar store.
Jul 30, 2009 | Rowenta Professional DM890 Iron with Auto...
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Iron leaks water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Mar 11, 2009 | Rowenta DZ9080 Iron with Auto Shut-off
Water leaks from the bottom of the iron. Rowenta expert GV2380M steam iron
Jul 06, 2008 | Rowenta DG-980 Iron
Irons Logo
55 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
