Question about Building Materials
Genie g5050 troubleshooting - Building Materials
Genie GDO, door will not open. One sensor is green the other is red. How do I get the red light green?
b0qewvyetwegaaaaaelftksuqmccaa==
You don't. The red/green is normal. Find your installation, user manual and follow troubleshooting,. Try and call Genie, they will walk you thru.
Jan 04, 2018 | Building Materials
How to program a remote for a genie garage opener model 209
When programming a genie remote press the learn button
Then you will have to press the genie remote at least three times before it stores the code older genie models 5 times genie i
Apr 05, 2015 | Building Materials
Genie 1024 remote programming
On model 1024 genie garage door the carriage trolley jumping out of the chain what should i do to fix it or replace parts...
Feb 19, 2014 | Genie Company Genie Intellicode GITR-3...
Genie home alarm system keeps beeping
Find your user manuel. If you do not have it type in the system you have into Google and put "user manuel" after it. (i.e. Genie user manuel) Look in the table of contents under the troubleshooting section and follow the steps listed. The exact panel type should be searched for Genie...then there should be some model number.
Apr 04, 2013 | Home Security
Answer to riddle about 2 genies
Ask Genie #1 what Genie #2 would say, then do the opposite. You are in essence asking in one question of a truthful Genie what the untruthful Genie would do, or vice versa, so you must receive an untruthful answer.
Mar 23, 2013 | Cars & Trucks
Red safety beam flashing. Door still goes up and down. What to do
I don't know exactly what the cause of that is but here is a troubleshooting guide
Feb 25, 2013 | Genie Garage Door. SilentMax 1000 3/4 HP...
Garage door light will not turn on automatically when door is opened. Tried 't several new lights but that didn't work. Any ideas on troubleshooting?
This is either a light socket problem or a logic board issue. Unplug the unit and open the light cover. In the bottom of the socket there is a copper lead. Pull this up with needle nose plyers as the bulbs may not be making contact with the lead. Then try it out. If it does nothing either your socket is bad or the logic board is bad. You can test the socket with a circuit tester. If it is bad replace it, if it is good replace the logic board. You can get replacement parts at genie.com or overheaddoor.com. Thanks BB
Sep 14, 2010 | Genie Company IntelliCode GICT390-1BL...
My genie garage door opener opens with no problem but when closing it only goes down a few inches then goes back up. I have went through an hour of troubleshooting with genie techs but still cannot get it...
Most openers have a safety cut out to prevent the door hitting your car when closing ,check the door guides to see if the door jams or is twisted.Depending on the model check the drive chain for sticking links or binding.Failing all disconnect from door and run unit without door.This will narrow problem to door or closer.
HTH
Nov 02, 2009 | Kitchen Appliances - Others
Re: Sewing Genie Instruction Manual
one problem is confusion between the SEWING GENIE & the Singer brand sewing machine called the Genie. I believe most of these questions are about SEWING GENIE & most of the answers are about the Singer machine. =(
May 19, 2008 | As Seen On TV Sewing Genie Mechanical...
Building Materials Logo
54 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
