Question about Yamaha Audio Players & Recorders
Yamaha rx-v750 is stuck in zone 2 - Yamaha Audio Players & Recorders
  • 4 Answers
SOURCE: Zone 2 Vol Fix
Try this:
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Hope it helps. It worked for us.
Posted on Aug 04, 2008
  • 53 Answers
SOURCE: Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
Posted on Nov 07, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Posted on Dec 29, 2009
Testimonial: "great feedback. "
smarthome2
  • 1114 Answers
SOURCE: I just put new batteries
If you are referring to the Yamaha remote, slide the switch on the side of the remote to "Amp" then, using the "select" arrows up or down, toggle till you get to "Zone 2" or "zone 3" Once that's displayed on the LCD screen of the remote, press "system power" That should do it. If you still have a problem, post a reply and i will help you further
Posted on Jun 27, 2011
gopakumarg43
  • 74482 Answers
SOURCE: Yamaha RX-V663 zone 2 stopped
Hello
The power supply sectionand the relay control section should be checked. There is control transistors which activates the relay control. If this transistor has damaged, of it does not get any voltage, the relay will not click. In most cases, if the output transistors got shorted, the set will come by protection state. Here you reports that only relay is not working. Just open the set and check the voltages at the "collector" pin of the relay drive transistor. You have ot disassemble the whole circuit board as these transistors are not accessable without get the boads out. Actuallly this is a very skilled work and care should be taken in all respect. If you are not aware in elctronics, and haven't proper tools and a digital multimeter, soldering iron, you can do this work. Otherwise get it repaired by any experienced service technician. OK.
Posted on Sep 08, 2011
Any one know if the Yamaha RX-V750 is worth repairing if the left channel for both Speakers A and B is dead?
If you are using it as a theater receiver, I would replace it. The current versions are half the price, still built as strong, and are much more capable of operating today's video and audio needs. If you are using it for "Audio", it's still a toss up.. It's a 200 or so repair and the lineup starts at roughly 350 with more options. Hope this helps
Jan 18, 2010 | Yamaha RX-V750 Receiver
Dec 29, 2009 | Yamaha RX-V663 Receiver
Nov 06, 2009 | Yamaha RX-V550 Receiver
I have a Yamaha RX-V1400. Can no longer select ZONE 2
check the setup menu in the receiver to reset the outputs for zone use instead of 7.1 use
Oct 17, 2009 | Yamaha Audio Players & Recorders
Yamaha RX-V750 AV receiver power problem
i had the same problem, only none of the above worked until someone told be to replace the ceramic cap .022 630v c405 on the sub board, and after this mine has worked fine since
Mar 10, 2008 | Audio Players & Recorders
Zone 2 Vol Fix
Try this:
Jan 19, 2008 | Yamaha RX-V657 Receiver
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
