Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit d41 dishwasher
When i turn on the machine the cycle light comes on but nothing happens
  • 209 Answers
Try testing the door interlock, actually this is only a micro switch inside the door behind the plastic front panel, there could also be the possibility there is a broken wire behind the door skin just above the hinge part, take care when working on appliances do not force parts to remove them and always unplug at the mains hope i have helped, if so please rate me well
Posted on Sep 26, 2007
SOURCE:
Ist GREEN LIGHT FLASHES BUT WONT FILL WITH WATER
I also had this problem, it was the automatic anti-flood device, the upper spray arm water pie was leaking into base off unit which operated the anti-flood device.
Hope this is of some use to you and others
ipip32
Jul 20, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Will not start cycles
is it doing the initial pump out then filling with water and stopping b4 the wash cycle? if so it may be that the wash motor has failed(you may hear a buzzing) or the pcb is faulty. if the water does not fill into the base there may be a valve fault of a supply fault. any engineer worth his salt should be able to diagnose this fault on first visit and return with a part so dont expect multi visits.
Jul 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 dishwasher, switch it on to program,
if applaince does not start draining then there is a possible fault with the door locking assembly,and the appliance thinks the door is open and this will not allow the appliance to start
Jun 28, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Dec 21, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 slim line dishwasher
Pull the unit out and tip it carefully to one side. (put some rag down first to mop up the water) then stand the unit back up.
Make sure you can see the back of the unit. put some tissue paper behind the plastic pipe that runs up the back centre of the machine. Turn the unit on and put into cycle. after a few minutes carefully remove the paper if its wet (even a little) the chances are the star shaped lock nut inside is loose or the pipe is damaged. A replacement is readily available and should cost less than a tenner to buy. just make sure you order a new seal as well and get a 20-25mm jubilee clip to replace the one installed.
Apr 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D41 Slimline
HI THERE - I ALSO INHERITED A D41 - I HAVE JUST FOUND - SITE WHERE YOU CAN DOWN LOAD INSTRUCTION MANUAL FOR MANY INDESIT PRODUCTS - I NOW HAVE INSTRUCTION MANUAL FOR MY D41 NICELY PRINTED OUT - SEE www.indesitservice.co.uk hope this helps you too - Helen
Nov 14, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher
hello mate, i bought a brand new indesit d40. plumbed it in and the 1st light kept flashing, phoned the technical centre and they said its the anti flood mechanism kicking in and preventing it from working. although water was going in it was not going into the dishwasher but filling the base and the safety feature just shut it off. said to get back in touch with comet who i bought it off for a new one because its a manufacturing problem. put the new one in and theres no problem. wouldn't have a clue how to fix it myself though.
Apr 06, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
231 people viewed this question
Top Indesit Dishwashers Experts
Marvin
Marvin
Paul Bade
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
