Question about Saws
Toyang bandsaw 202-1
Need to find a blade and wondering it's worth
efs_perpends
  • 1996 Answers
SOURCE: I need a bandsaw blade for a Craftman 3 12 ( vint.
You'll need to find out the length of the blade in inches. If you have an old broken one, you can simply measure it. Then if you search online, you'll find a variety of sources that will weld/braze a custom length blade for you. (link here)
Otherwise, you might find a manual here. that gives the standard length for that machine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 08, 2009
  • 582 Answers
SOURCE: bandsaw blade keeps coming off the wheels. What
ALL BAND SAWS HAVE AN ADJUSTMENT FOR THE BLADE TRAVEL WHEN I WOULD REPLACE MINE I WOULD ROTATE THE TOP WHEEL BY HAND TO CHECK THE ALIGNMENTAND WATCH WEHICH WAY THE BLADE STARTS TO TRAVEL THERE SHOULD BE AN ADJUSTMENT ON THE TOP WHEEL THAT TILTS THE WHEEL IN OR OUT JUST A TINY TURN WILL MAKE A BIG CHANGE
Posted on Aug 22, 2009
SOURCE: hi i have a craftman bench 10 inch bandsaw that has blade drif
The problem could be one of two things. The tires could be worn or glazed with rosin. Try cleaning the tires with mineral spirits to remove the build-up. The other possibility is that the pulleys are out of alignment. To check this, put a straight edge across the face of the lower pulley and see if squares with the upper pulley, if it doesn't, loosen the set screw on the upper pulley and adjust accordingly
Posted on Jan 21, 2010
Where can I get a manual for a Toyang model TME 202-1
I am not familiar with this band saw. Do you know the size of this band saw? Is it 14" ? You can actually just use ( cross reference) another manual ,
Aug 11, 2014 | Saws
Bandsaw parts and blades
Check on bandsawparts.com and sawblade.com . I made several orders with them . I have a great time and service. Worth sharing.
May 31, 2013 | Saws
! have a metal cutting bandsaw from toolmac model 73- 532501 Where can i get spare blades
One question , what happened to your blade? Why do you need spare blades? Oh ,actually,t here are lots of sites that can supply some blades for your bandsaw. Give it a try visiting sawblade.com .
Nov 04, 2012 | Saws
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Top wheel part broke off
I suspect the part you need is 150086 "Upper Wheel Shaft". You can confirm this by checking the exploded diagram for your bandsaw which can be downloaded at http://content.wmhtoolgroup.com/manuals/708115K_man.pdf.
See page 25 for exploded diagram showing wheel shafts, bearings, etc..
It might be worth checking with JET about warranty since I believe that band saw has a 5 year warranty. You can check here for a service center near you.
Jan 10, 2010 | Jet 710115K Jwbs 14CS Deluxe 14 Inch 1 1/4...
Hi i have a craftman bench 10 inch bandsaw that has blade drif
Dec 08, 2009 | Craftsman Saws
Saws Logo
340 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
