Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I got liftmaster garage opener , when I hit the botten to open the door, the motor dosen't run but make noise , if any one had same problem before and can help me to know what is the problem
  • 3 Answers
Check the nylon gear to see if it is striped. do you see white shavings around the area?
Posted on Apr 27, 2009
Liftmaster Professional 1/2 HP spindle not turning
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor unit and will be obvious if it is bad. The part number is 41A2817 and is available from any door opener service company. The part will come with instructions.
Jun 10, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a Chamberlain LiftMaster Residential Garage Door Opener Chain Drive 2255. It no longer opens or closes. When you hit the button it makes a churning noise then stops. There is a code flashing on...
Remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and is probably stripped. The part number is 41A2817.
Sep 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
1/3 hp liftmaster professional.....wall button pushed.....makes running noise and light comes on.....no door movement
Remove the cover from the motor unit. I'm sure you will find white sawdust all over and the drive gear will be stripped. It is a white nylon gear just in front of the motor. The part number is 41A2817 and comes with instructions. It is available at any door opener service company.
Jun 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: garage door opener only runs for a foot or two and...
Check to make sure you don't have a broken door spring and also remove the cover from the motor unit and check the drive gear. It is a white nylon gear just in front of the motor and may be stripped.
May 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+: Door goes down and when it reaches the bottom, it ...
If the door hits the garage floor and then reverses to the open position you need to adjust the 'down limit' which is on the side of the motor unit. Turn this control in the opposite direction of the arrow printed on the cover. Some tweaking will probably be necessary.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Door stopped opening!?!?!?!
Remove the cover of the motor unit and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad.
Dec 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift master garage door opener. Motor makes noise when switch is hit likes its running but chain/sprocket doesn't move and the door is stuck open. Chain is on sprocket. Not sure if the motor is frozen? ...
I had the same problem. Took the cover off of the opener and found that the gears were stripped on the unit. Motor was fine. You can order gear replacement kit for the unit. They are a plastic type sprocket and worm gears. The kit comes with spindles and all necessary clips. You have to take the unit off the ceiling to replace the gears, but the process if very easy to do. Parts kit about $40 on line, much cheaper than a new door opener. Total process took less than 2 hours, including getting the unit down and back up again.
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
89 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
