Question about Kitchen Appliances - Others
Harman stove p68 wont work in room temp mode but works fine in stove temp mode
2 Suggested Answers
  • 744 Answers
SOURCE: Harman P68 pellet stove glass fuse blows after 1 minute.
You can do some troubleshooting by looking at the glass fuse after it has failed. If the element looks melted and there is no other discoloration, then the fuse probably blew as a result of an overload somewhere. If the fuse is burned black, then it's probably a short in the system.
You can meter the motors to see if they are shorted anywhere or open.
It sounds like you may be correct about the circuit board.
Posted on Jan 02, 2010
Lights but turns off in about a minute
It might have a built in thermostat that will light the heater when room temp falls below a certain temp. It should then relight and warm things back up. As long as the pilot stays lit it should work just fine.
Feb 08, 2014 | Emberglow Melbourne Oak 24 in. Vent-Free...
Replacing igniter on a harman p68
P68 only: Buy ignitor (about $100). Put on work clothes. Unplug stove. Clean stove. Take off back panels (onlt two corner screws come all the way out, most just loosen) and clean everything (including behind the wingnutted panel where the auger screw is). Notice where two wires go in thru the back to the ignitor, See how the excess wire is held up. You will need the excess so free it up so you have about 12 inches to play with. Go in front and expose the ignitor. Take out the 2 above screws holding it in. Pull it out (using the excess wire). With pliers straighten out the tabs holding the metal cover over the old ignitor. Attach the wires. Put the metal cover back on and twist the tabs. Gently pull the wires back until snug. Screw ignitor up where it was. Take care of excess wire in the back. Make sure gromet for the wires is in place. Put it all back together (check air intake pipe is in place (mine looked like it fell out some while I was cleaning). (first time post, wanted it flagged as a solution)
Dec 25, 2011 | Audio Players & Recorders
HEATER NOT WORKING PROPERLY (SOME HEAT BUT NOT HOT) COMPRESSOR NOT RUNNING WHEN IN HEAT MODE. A/C WORKS FINE.
No adequate heat due to wrong setting temp or your RV (Reversible valve) not working properly.
Set temp +5 than your room temp and mode in " Heat". And check click sound in reversible valve and also warm in sunction line.
If it's with heating element check power goes heater coil. If not check wiring.
Dec 27, 2010 | Heating & Cooling
Trying to hook up a RTH2310B thermostat to a wood pellet stove with only two wires.. How do I know where to connect them too?
Hey Brad432, this is what i did with the same RTH2310B thermostat and my harmon stove. You must have the heat sensor that plugs in the back of the stove to start with. Take your new wire from the stove to your thermostat, red to rh, white to one side of your sensor then other side of sensor to W on your thermostat. On your stove side set your room temp as high as it will go and let your programmable thermostat set the room temp. Works good for mine. Good Luck
Nov 01, 2010 | Honeywell Focus 6300B 5-2 Days...
Jan 02, 2010 | Kitchen Appliances - Others
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Kitchen Appliances - Others Logo
74 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
