Question about Juki MO-644D Mechanical Sewing Machine
Juki serger manual model 6704S - Juki MO-644D Mechanical Sewing Machine
SOURCE: I need a manual for a Juki MO-134 Serger
the person who is looking for the manual for Juki 134, I can make a copy for you. Cblair7639@aol.com
Posted on Oct 18, 2009
  • 108 Answers
SOURCE: where can i find free instruction manual for JUKI
try at www.ifixmachines.com
Posted on Feb 15, 2010
  • 1116 Answers
SOURCE: Need instructions for threading Juki MO 3314
Open the font of the serger and the instructions will be printed on the serger or on the door.
Raise the presser foot and set the tensions to zero when threading.
Turn the hand wheel so the upper looper (curved one) is at it's highest point and thread it first, and then the lower looper.
With some sergers you must thread in a certain sequence. This should be indicated in the instructions on the serger.
Set the tensions back to normal ( 4 - 6), lower the presser foot and run a length of stitching to see if the threads are knitted together as they should before you start serging your project.
Posted on Feb 19, 2010
  • 1116 Answers
SOURCE: good diagram showing how to thread a 4 thread Juki
You can download a free threading guide here - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_644_Threading_Diagram.htm
The same site also sells manuals.
Threading Tips:
Have the thread antenna at it's highest position.
Set the tensions to zero.
Have the presser foot up while threading.
When you thread a serger for the first time, or if you are having a threading problem, use a different color thread for each guide. This can quickly indicate where the problem lies.
Once the stitch is satisfactory, change to the color you prefer - but this way is the easiest - cut the thread near the thread cone and tie off with the new thread. With the tensions at zero, slowing run the serger until the new thread appears. You will need to stop as the knots approach the needles and thread them by hand.
Do the tie-off before running out of thread and this will save a lot of time and stress.
Posted on Mar 02, 2010
SOURCE: JUKI MO 134 SERGER
How to Thread Juki MO-134 Serger from watching lady at Lyles. Turn upper blade up. Push in first then turn up.It makes threading easier. Blue Thread upper looper first. Pull thread through tension knob. Don'tjust lay it there. (She thought that is what I must have done) Orange Thread lower looper next. Pull thread through tension knob as inthreading upper looper. Adjust lower looper so it is right nextto upper looper so that their points are almost together and directly belowsewing needles. Lower looper will be in front of upper looper (I believe). With tread from upper looper pulledback, slightly lift lower looper above upper looper and thread. I think this isright. Pull thread back with other thread. Tension is the key. Remember that. Yellow: Thread left needle first.Remember tension. Pull thread through curled wire on left side of needle arm. Green: Thread right needle. Rememberabout tension. Pull thread through curled wire on right side of needle arm. b> Note: Before sewing turn the wheel tomake sure the stitches are going together correctly.
Posted on Nov 18, 2010
JUKI MO-812 Class DD6 Serger Instruction Manual
check with a juki dealer about a manual
or check with sewvacdoctor.com
Mar 03, 2012 | Sewing Machines
Need a manual on a singer serger #TY501010460
I tried to find a manual for this model # and it didn't seem to be the correct one - but you can go to the Singer web site or the free manuals website to get one once you confirm your model #
Jul 30, 2011 | Sewing Machines
I want to adjust my serger yuki mo 2516n but i don't still have it's manual instructions
if you go to this page http://www.juki.co.jp/household_en/serger/index.html there are the current household sergers from Juki and a four page threading diagram for them showing the different stitch set ups.
If your serger is a domestic one too (the MO in front makes me think so) then you may find that the threading up is very similar on your model. Stitch length is usually a kob on the right marked from 0.5 to 4 and differential feed knob is usually there too, usually marked from -0.5 up to 1.5. Tension settings are usually around 5 but you adjust the looper tensions to suit the fabric and how wide you are trimming it with the blades.
You could contact Juki or their local distributor in your country and arrange to purchase manual for your model. http://www.juki.co.jp/household_en/dl/index.html this page gives a listing for countries.
it is also available on line to purchase as a black and white pdf file, http://www.sewusa.com/Sewing_Machine_Manuals/Juki_Manuals/Juki_Industrial_Sewing_Machine_Manuals/MO-2500_Instruction_Manual.htm for $8USD
Jun 20, 2011 | Sewing Machines
How to thread a juki serger sewing machine. i need a large diagram of how to do it. thank you
do you know what model Juki it is? Is it a serger or a sewing machine? Juki do industrial straight, serger and specialised machines such as coverstitch and blind hemmers as well as domestic sewing machines and sergers so there is a big range of machines.
There are manuals at this site for http://jukihome.com/products/mo644d.html various models of Juki Home sergers, but you will need to hunt through and find your model.
The manual is on the "features" tab for each model so just dig down a bit to locate the pdf file in there.
I hope this is what you were searching for.
Jun 03, 2011 | Juki Sewing Machines
I need a manual for my serger. It is a Juki
(pdf format)--manualsonline.com
sewusa.com
mastersewusa.com
sewingmachineplus.com
homeappliance.manualsonline.com
Jul 20, 2010 | Juki Sewing Machines
Looking for an online manual for my Juki serger MO-634DE
Herre is a link to the threading diagram: http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_MO_634_Threading_Diagram.htm
Oct 08, 2009 | Juki MO-644D Mechanical Sewing Machine
Threading illustrations too small
You might take a look on ebay item 160362974035
May 29, 2009 | Baby Lock Eclipse Serger
Need a manual for a baby lock serger model EA-605
Jan 16, 2009 | Baby Lock Eclipse Serger
Juki MO-644D Mechanical Sewing Machine Logo
21 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
