Question about AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner
Need replacement water pan for leak problem Model. MC43E
Found water in the pan under bottom of my 60 gal Rheem Marathon model CMR 75245 electric hotter tank. There is no other source of water goes in the pan. Tank is only 4 yrs old. Is the tank leaking?
Is it sitting in the pan or is it elevated over the pan? It is hard to see the leaking if it is sitting flat in the pan. Check all the connections, top and bottom. Wipe them dry and then run your hand over the connections and feel for water. Also check under the heating element covers for leaks. Good luck!
Dec 07, 2016 | Rheem Water Heaters
Model 1068630583. Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Kenmore Refrigerators
Why does my GE model number TBX1811 refrigerator leak from the back inside the fridge
Water leaking inside it
  1. Check the lines to your dispenser
If the lines to your dispenser are broken or damaged you will need to replace them.
  1. Damaged drain pan
If your drain pan has holes or cracks it will also need to be replaced.
  1. Clogged drain
If you experience any clogged drains, they must also be unclogged or replace. If you experience this at the ceiling of your unit it can be attributed to a clog in the freezer section. Remove the divider and let the insulation thaw out and dry.
Mar 28, 2015 | GE Refrigerators
My asko d1706 dishwasher doesnt let water in. As I
Base pan full of water means there is a water leak. So your machine has a flood detector (floater) and it prevents feeding further water into the machine to prevent the flooding. I think this is the reason. You have to fix the leak.
Just to make sure first clean the base pan water and try it. It will work until again water leaks and activate the floater (flood switch)
Sep 25, 2014 | Dishwashers
Water is leaking from under the refrigerator Model # GI7FXCX. What could be the cause
It could be one of three things. The door front water dispenser hose is cracked or broken. The freezer is defrosting and the base catch pan is not in place or you have a spill in the fridge you are not aware of. I will assume it is not the latter, so you need to pull the fridge out from the wall and check the area beneath it from an approx on the leak. Check the hoses for the water dispenser by running your fingers along them and if they are wet, you have found your leak. You need just replace the hose and it will solve your problem. If this is not the case, check the base pan for a hole. It is normal for some condensation to come out of your fridge, not a lot, but some. Check if the pan has a leak in it and you can replace if necessary. I would be real inclined to think the water dispenser is causing the problem.
By the way your model number is GI7FVCXWY
May 23, 2011 | Whirlpool Refrigerators
Have been on the computer all morning many diff sites getting a nervous breakdown want tine geat & shaft part for earthquake mini tiller all sites are impossible to use help help help
Select the model on this website and then the part. The link below is for MC43E Mini Cultivator http://www.getearthquake.com/foundations/store/partsblowup.asp?product=MC43E
Jul 19, 2010 | Ardisam Inc Earthquake Mini Cultivator
Refrigerator Leaking from underneath
OK I will help but I think if you could find the model number and on some they always seem to be worn off or hard to see, I'm trying to picture in my mind if you have a water and ice dispenser in a side by side or jut a freezer over the fresh food compartment. If you have no water and ice then something like a leak has happened to de condensate collector pan or the drain tube has missed the pan. Without water from another source something is wrong with the pan or the pipe leading to the pan. If you have water and Ice Maker it;s possible you have sprung a leak in the water lines leading to the dispenser near the floor and behind the kick plate. The water lines on those models enter the bottom hinge of the door.Best way to see what is happening with the condensate pan is unplug and pull refrigerator away from wall and remove cover over compressor and condenser area to examine the pan closely. See if you can locate that model number and I will return with some helpful links, Thanks, Sea Breeze
Jan 10, 2010 | Refrigerators
Maytag model m6p09s2a*b leaks water doesn't
Make sure it's mounted correctly..the back of the unit shopuld be slightly lower than the front or water can leak over the pan in the front.
Oct 10, 2009 | Maytag Portable Air Conditioner M6P09S2B
Water leaking into the drain pan
if the pan on the compressor on plug unit get a rag and sock up the water i beleave you doors staying open to long
Mar 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Coolant leaking from underneath car near oil pan.
THIS IS STRANGE, BECAUSE THE NEXT PAN BEHIND THE OIL PAN IS THE TRANSMISSION PAN. UNLESS MECURY HAS DEVELOPED SOME STRANGE SYSTEM THERE SHOULD BE NO WATER OR COOLANT ANYWHERE IN THAT LOCATION? IF THE PLASTIC PLUG IS LEAKING IT CAN BE FIXED BY REMOVING IT AND WRAPPING THE THREAD WITH TEFLON TAPE AND RE-INSERTING IT AND TIGHTEN IT. IT THE PAN ITSELF IS LEAKING, THERE ARE ONLY TWO THINGS HERE. ONE, YOU CAN RE-TIGHTEN THE BOLTS TO SEE IF THEY ARE LOOSE AND SEE IT THIS STOPS THE LEAKING. OR, IF THE LEAKING DOESN'T STOP, YOU NEED TO REPLACE THE PAN GASKET WITH A NEW ONE AND REFILL THE TRANSMISSION WITH NEW OIL. YOU MIGHT AS WELL CHANGE THE FILTER WHEN YOU HAVE THE PAN OFF, BECAUSE IT IS PROBABLY OVERDUE. I THINK YOU WILL FIND THIS LEAK IS A STICKY RED FLUID CALLED ATF OR AUTOMATIC TRANS. FLUID. THAT WILL NEED TO BE REPLACED. NEW FILTER, NEW GASKET RETORQUE THE BOLTS, IMPORTANT, DON'T WANT THAT THING FALLING OFF, NEW FLUID, YOUR BABY SHOULD PURR AND NOT WIZ ON THE FLOOR ANYMORE. NOT SURE HOW TO DO ALL THIS? BEAT FEET TO THE NEAREST PARTS STORE AND BUY OR ORDER THE CHILTON OR HAYNES MANUAL FOR 93GRAND MARQUIS AND YOU WILL HAVE PICTURES AND STORIES YOU WON'T BELIEVE! CAN'T GO WRONG! GOOD LUCK!
NEED HELP REPLY TO:ARCLIGHT1217
Nov 08, 2008 | 1993 Mercury Grand Marquis
AdobeAir Mobile Swamp Evaporative Air Cooler Air Conditioner Logo
41 people viewed this question
Top AdobeAir Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
Are you an AdobeAir Heating and Cooling Expert? Answer questions, earn points and help others
