Question about Pioneer CDJ-800MK2 Turntable
Not reading disc, motor is running though!
My cd deck is not reading any discs, the motor is turning but not reading. Is this a laser prob?
  • 515 Answers
Sounds like your traverse assembly is damaged, and might need to be replaced. Cost for part is roughly about $65, but I would not suggest self-repair, unless you have experience with such electronics.
Here is the part: Pioneer CDJ800MK2 Replacement Part
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Apr 30, 2009
Why does a 'no disc' message appear on dvd player even though disc is present?
Could be simply a dusty laser lens. Try a cleaning CD first.
After that, it could be that the laser assembly has low power output. Some decks have the range to increase the laser power, but it's only a temporary fix. The emissions are dying so the laser assembly will need to be replaced sooner of later.
Aug 29, 2014 | Technics Audio Players & Recorders
Unit won't play discs,orig or otherwise. Keeps flashing "no disc" although they are loaded.
If the deck in question wont read/play any disc, blank or pre-recorded, try cleaning the laser lenz.
Apr 04, 2014 | Philips CDR775 2-Disc CD Recorder
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
No Disc-alert. Will not play any DVD's. Will not run lens cleaner disc. disc's spin. thank you
Discs spinning after being loaded, that's a positive sign, but 'No READ' or 'No Disc' usually means the laser has failed or its output is too weak to read DVDs (DVD players tend to spin discs at a faster speed with a higher read rate than CD decks (obviously to read the video data as well as audio per disc, the optical/laser voltage rating is higher for DVD). So they are more likely to fail quicker than CD lasers but not always.
In short, since the unit is only a player, and may not be brand new or under any warranty, consider replacing it with a new unit or perhaps a DVD recorder (or even a Blu-Ray player - as they are becoming cheaper to buy now) - the cost of repairs/parts for this one would be higher than a new one and not economical, although you can always submit it to a service centre and get a quote (and a second opinion) on the likely cost(s) of parts/repairs involved. It won't be cheap, trust me.
Mar 21, 2011 | RCA DRC277 DVD Player
Ps3 not spinning disc, replaced spindle motor, did not fix. Please help
Hi there, this is because the actual laser needs replacing, not the disc spinner motor. With the PS3 the laser reads the disc data type, whether it be a DVD, game , audio cd or blu ray movie. It then spins the disc up to the required read speed. When the laser is faulty is cannot read the disc type so will not spin at all.
Hope this helps
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Not accepting cd's
I have the exact same car a 2005 Ford Focus ZX5 with a 6 disc MP3 player, when we first got the car the changer worked fine and would read all discs, after a few weeks it would kick out every disc and say that it was "bad disc", we tried buying just some office depot cleaning disc thinking it would clean the laser. This did nothing, tonight I got quite ambitious and removed the whole deck from the dash. You do this by carefully prying back the surrounding plate all the way around the heating controls and then unbolting the deck from the car. I unhooked the cabels that were running into and pulling it out. I then unscrewed all the small screws to the unit and took a look inside. As it turns out I wasn't able to find the laser eye as the changer had hidden it, so I screwed it back together and put it back in. Turned on the player and put in a disc and it played perfectly. So in the end basically unplugging it and plugging it back in did the trick. You may also have the same luck just unplugging the battery for about a minute and plugging it back rather than taking your dash apart. Hopefully that helps you since it's been 4 months since you posted this issue.
Mar 19, 2009 | Sony Car Audio & Video
Cdm 500 not reading disk 1
First, try the disc that plays OK in deck 2 in deck 1. This will eliminate the disc as the problem. If the disc won't play in deck 1, then the laser pick-up is on it's way out. There is no easy fix for this, it will require the attention of an engineer.
Dec 12, 2008 | Philips CDM-500 2-Disc CD Player
Deck A will not play/Deck B OK
Sounds like the CDR deck has an issue. When the disc comes out has it's position changed i.e has it been spun at all? Can you hear any motors moving? Does it work with any type of disc ( cd/cdr/cdrw)?
Feb 14, 2008 | KLH CDR2000 2-Disc CD Recorder
Recording
Willthe b deck playback a normal cd? Sounds like your record laser is gone. It's a philips laser and they are known for it.
Jan 23, 2008 | Koss CDR200 2-Disc CD Recorder
Stanton C500 Dual CD Player
hi, check that when the right side tray closes the screen must show up READ or DISC CHECK. the behaviour must be the same as the left side cd deck. if loading is faulty then the cd tray is out of alignment or sensing swithches are faulty. if disc is loading then u have a laser pickup problem or the laser ribbon cable is intermittent or the spindle motor is tired or the laser lens needs accurate cleaning. cheers.
Aug 05, 2007 | Stanton C.500 Dual CD Player
Pioneer CDJ-800MK2 Turntable Logo
487 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
