My tv takes like ten minutes untill it's turning on,why?
The image it's perfect everything it's ok except the fact that it's taking alot of time untill the image appears.please can you let me now about it?
thank you. When the TV is turned on it takes 5 minutes to finally come on. The on button flashes green on/off for several minutes, then the screen will flash on for a second, then off, and on again for several cycles before the green light goes off and the on button has to be pressed again to repeat the cycle. After several times doing this the tv finally comes on.
    Genius:
  • 1,039 Answers
Replace any swollen capacitors in power supply.
Posted on Apr 25, 2009
Why is my tv screen green when i turn it on can not get any chanels i have a toshib regza
Posted on Feb 11, 2010
Why wont my car stay started
Charge battery with charger to maintain then turn key to on position ,do not crank over . Leave in on position for ten minutes then turn to off and do the ten minute cycle to on position 2 more times then turn off then try to start
Jul 28, 2014 | 1999 GMC Envoy
IT TAKES A while to have screen on theTV
If I understand your (very brief) problem correctly, the problem is that when you turn on your TV or DVD player, it takes a while to show anything. If the time is less than a minute for a dvd player, or less than ten seconds for turning the TV on itself, then this actually isn't a problem. Modern TVs and various other tech often take several seconds to turn on, and that may be the only 'problem' you're experiencing. It's an unfortunate fact of modern life. Things take a little while to start up sometimes. If the time for the TV is in excess of about thirty seconds, or the time for a DVD/Bluray/whatever player is more than five minutes... Well, then it could be a problem, but I'm afraid I'd need more information than you've provided.
Oct 08, 2012 | Televison & Video
TV turns itself off??
Take a second look in the power supply where the power cord goes for bad caps----a few examples:
Good one on the left and puffed up one on the right
Extreme example of ones the arrows point to and notice all the perfectly flat tops on others
May 28, 2012 | Televison & Video
Sony Bravia No signal plus flickering image and
You know how to reset the tv to its factory setting, I think you are a technician. Second thing you can do is software update. Go to http://esupport.sony.com/US/perl/swu-list.pl?mdl=KDL42V4100&LOC=3#div_pos_30 . If it doesn’t work. Replace the Main board (UB board). Part # A-1547-086-A Cost approx $320.
Knowledge obtain from: Repair experience on same symptom.
Parts reference: Andrews electronics, 800 289 0300.
Apr 18, 2010 | Sony Bravia KDL-42V4100 42 in. LCD TV
I have a new LG HDTV. When first on the remote not responding.
Take the TV back.It should be under warranty.
LG/Zenith has had alot of problems with there TV's. Buy an extended warranty if you can. It will pay for itself.
Aug 02, 2009 | Directv HR22 500-Hours HD DVR
When taking photos in direct sun photo is all black. i have Nikon Collpix 4600 My camera turns on perfectly fine. Everything works great, except for the fact that the screen shows nothing. It is a black...
contact NIKON BAD CCD PROBLEM !
Get ir repaired free of charge just call them thousands face the same problem and all brands are repairing it free go call them
see the link for widespread Bad CCD problem dont worry if u are not on list but u have the same problem call them PLS RATE ME FIXYA for help !!
http://www.imaging-resource.com/badccds.html
Apr 12, 2009 | Nikon Coolpix S210 Digital Camera
Unable to veiw image through lens
I have the same problem with my flawless-up-until-today S2-IS. I read in another link the problem is related to moisture causing the iris to stick, requiring a forced reboot. This worked for me, but after putting away the camera for a few days the prblem returned and needed the trick again.
When you turn on the camera and are able to see menus but the image displays are dark, try the following:
1. Place the program selector to "Tv" setting
2. Press the self-timer selector (twice) until you see the timer icon on the screen
3. Press the shutter button to take a photo; the self-timer begins to beep a countdown
4. Open the battery cover BEFORE the timer runs out.
5. After a second, close the battery cover and the camera will power cycle automoatically.
6. The displays should return to normal.
You may have to repeat this a few times to get it to work. Good luck.
Jan 23, 2009 | Canon PowerShot S2 IS Digital Camera
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Sanyo 24" TV
as you say that tv works fine at the place of tv tech so it sounds me that you please tell electrician to check for ground connectionat your house. if it is ok then in future you will not any problem.
Sep 28, 2007 | Televison & Video
Televison & Video Logo
868 people viewed this question
Top Televison & Video Experts
