Question about Lucent Merlin Legend MLX-20L Phone
What does cont ring and bgm mean on the display?
What means of po cont on canon np 6650?
PO cont means Drum Potential Control,
If po cont set to 0, it means scanner system adjust the document darkness automatically but you may face many printing problems such like auomaically over dark, over light, heizzy, dull, etc etc.
if you want to trouble free printing, please set PO-Cont to 1
Aug 11, 2011 | Canon NP 6650II Copier
What does bgm off mean? One phone is not ringing on a hybrid system but the rest are. I can call out but cannot transfer, it is saying bgm off.
BackGround Music on an idle phone, if it's allowed, pressing 1 turns the BGM on and off.
Ringing comes from the ringer switch on the left side of the phone and system programming.
System programming is usually done from a display phone at extension 101 (or 11) and involves programs in the 400's for ringing (408-410 on a TA box).
You transfer a call in a couple of different ways, one is by pressing TRANSFER and dialing the extension, one is by putting the call on HOLD and calling them on the intercom to a specific line, and the 3rd is by just pressing the preprogrammed DSS button, fairly problematic in a phone that only has 12 buttons with lights.
The 7730 was first delivered with the TA series systems, but they are backward compatible with every KX-T series and forward compatible with even the latest Pana digital boxes of the TD and TDA/TDE/NCP series.
Carl
Apr 11, 2011 | Panasonic KX-T7730 Corded Phone
My BGM, back ground music used to work, now it does not. We use it only for music at our work stations. We press BGM for some music then toggle it off if necessary. It automatically shuts off if the...
Since a TD system BGM is just a single press "1" on an idle phone to turn on or off, I'm hard pressed to understand what you mean about BGM being a key. If you press "1" on a display phone and it says BGM On, and it doesn't work, go back to wherever the system cabinet is and look for the BGM port on the side of the phone system. It probably means the source is turned off or disconnected.
Carl
Aug 17, 2010 | Panasonic KX T7436 Corded Phone KX-T7436
What is bgm mode
BGM mode is the Back Ground Music mode.It means that the music is either playing or is paused in the background.
Jun 05, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
HOW DO YOU CONVERT NEC ASPIRE PHONES FROM FRENCH TO ENGLISH?
The keyset’s display provides a 3-line, 24 character per line alphanumeric
display that displays various information for the telephone
either while on a call or while idle. You can change the contrast of the
display as well as the language used when displaying the prompts.
1.On an idle telephone with no BGM,
or .
Pressing either volume key adjusts
the LCD display.
If BGM is enabled for the phone, in
order to change the contrast, it must
first be disabled (CALL + 825) or it will
adjust the speaker volume.
1. Press + + the language
number to be displayed (00-12).
0 = Japanese 1 = English
2 = German 3 = French
4 = Italian 5 = Spanish
6 = Dutch 7 = Portuguese
8 = Norwegian 9 = Danish
10 = Swedish 11 = Turkish
12 = Latin American Spanish
To change the
displayed language:
To adjust contrast:
58
Mar 14, 2010 | NEC DTU 8D-2 Corded Phone
How do i adjust display screen on nec aspire phone? Is too dim all of the sudden.
or .
the LCD display.
To change the
displayed language:
To adjust contrast:
58
Feb 24, 2010 | Lands Phones
DTerm80 phone, how to get language on display back to english
or .
the LCD display.
To change the
displayed language:
To adjust contrast:
58
Jul 28, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Can't display caller id info
Does CID work on ANY phone in the system? The reason I ask is because prior to issue 7, a Caller ID card had to be inserted into the trunk card. If yours is older, it may not have the card.
Carl
Aug 26, 2008 | Panasonic KX-T7453 Corded Phone
Trouble with the display
Hi Mary
Which system are you using?
If you are using panasonic kx td 1232 then just press the * key keeping the handset on hook.
If you are using a panasonic kx tda system then just press the transfer button keeping the handset onhook.
To change the date you will need to goin the program mode by pressing the Program button followed by *# 1234. then it will show on the display sys pgm no : enter 000 and press autodial or enter. Then you can change the date.
Aug 08, 2008 | Panasonic KX-T7453 Corded Phone
7453 Display
Without looking up details on versions, I think you may have an early D1232. Look at the plate on lower edge/front and see if there is a number in a circle. If there is no version number, the serial number will tell when the system was made.
Jul 07, 2008 | Panasonic KX-T7453 Corded Phone
Lucent Merlin Legend MLX-20L Phone Logo
127 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
