My sony walkman NWZ B133F is not connecting well to my laptop , however other flash usb's are connecting well , but when i connect the mp3 to desktop computer , it works well can anyone help me with that problem becouse i resently bought it (note:its 1GB flash mp3)
I had the same problem but i solved it. Follow the folliwing steps.
1- Download firmware nwz-b133f (firmware nwz-b130 V-1.01)
2- Download firmware nwz-b103 (firmware nwz-b100 V-1.3)
3- First execute firmware nwz-b100 , connect your walkman when the programm asks: please connect device. Then the program ask format your device you will loose all the data , click accept.
4- Don´t disconnect your device , wait until format and dataload are finished. This is necesary because firmware nwz-b130 doesn´t do the format.
5- Disconnect your walkman and you will see it doesn´t start (logical it ain´t his firmware)
6- Now execute firmware nwz-b130 , connect your walkman when the programm asks: please connect device. Don´t disconnect your walkman wait until program ends.
7- When finished disconnect your walkman the save way.
8- Ready like new.
Greetings Quicktronics here from Mexico.
Yo tenia este problema y esta solucionada. Sigue los siguientes pasos.
1- Baja firmware nwz-b133f (firmware nwz-b130 v-1.01)
2- Baja firmware nwz-b103 (firmware nwz-b100 v-1.3)
3- Primero ejecutar firmware nwz-b100 , conecta tu walkman
cuando pida conectar por favor el dispositivo luego pida formatear
el dispositivo vas a perder toda la informacion has click en
aceptar.
4- No desconectas tu walkman espere hasta que formatea
todo y carga todas su datos , este era necesario para el puro
formato porque el firmware nwz-b130 no lo hace.
5- Desconectas tu walkman y vas a ver que no enciende (logico no
es su firmware)
6- Ahora ejecutar firmware nwz-b130 , conecta tu walkman cuando pida conectar por favor el dispositivo , no desconectas tu
walkman espere hasta que carga todas su datos.
7- Cuando termina desconecta tu walkman de manera segura.
8- Listo como nuevo.
Downloading and installing driver from the website wont help much on this issue. It usually happens with the faulty usb port on the MP3 player or on the machine. Try connecting to another USB port on the machine. Also please check if the USB port on the machine is working fine
The Sony Walkman NWZ-B133F model does not require proprietary Sony software to transfer songs from PC, it supports USB transfer facility like direct "Drag and Drop" feature.
You need to check if your PC identifies the device as a connected USB device, since you have not specified which OS are you using on your machine.
Try turning the device on before connecting it to your computer, or try turning it off before you connect. maybe the usb cord is faulty, try a different cord.
I had the same problem. I had not had any problems for months and suddenly it wouldn't connect. I got on live chat w/ Sony (3 times) and finally got someone who seemed to know what they were doing. I have a Sony computer and they had to send me a link for a USB "patch". After downloading it, it fixed it.
I bought a new Sony NWZ-B133F/BCE Walkman. When I plugged it to the USB
the drivers got properly installed, but the player does not show as a
removable device or any other device in My Computer. just follow...be sure your player is connected to pc
go to my computer right click>>properties> IN HARDWARE TAB
select device manager>portable audio>right click select update
drivers>click next>tick the option let me choose driver for this
device>next choose usb mass storage driver from two options click
next....
AND U R DONE....
See if your players hold button is on and when you connect it to your pc, hardware update wizard comes up, in tat choose the second option(ie install from...(advanced) and click next and choose 'dont search i will choose the driver to install' and press next.... check show compatible hardware choose usb mass storage and there you go.....
dddd
