Question about RCA Lyra RD1072 MP3 Player
My Lyra RD1072 ... trouble with memory card
I've had my Mp3 for for a while now... and it's run out of space, so i got a new 1GB Memory Card. but when i go to add songs... it still says "there is no free space on 'removable disk G:'" How do i get the songs to go onto my memory card?
Thing is that the memory card is in a totally diffrent folder... you need to put the card into your mp3 then open both folders. download your songs... then voila extra mp3 space!! see for example my mp3 is hooked up to my E: drive but to get access to my memory card i have to open up the F: drive also!! :P
Posted on Oct 02, 2007
SOURCE:
I have a RCA Lyra RD1072 A where can I get a memory card, it appears someone took my out my MP3 player..
You want an SD card. Bought the same size and shape as a postage stamp with one corner cut off. Get this though; they make an SD-HC card now the exact size and shape. You can't use it. Must say "SD" only. You should be able to get 2GB for about $8 -$10.
Jan 24, 2009 | RCA Lyra RD1072 MP3 Player
Memory card limitation
It takes an SD card which is anything not labeled SDHC and up to 2 gigs.
Jan 21, 2009 | RCA Lyra RD1072 MP3 Player
Memory Card
a Standard SD card will work
Feb 20, 2008 | RCA Lyra RD1072 MP3 Player
Memory
I believe that it is 256MB as that is how much mine had when I owned one.
Also if you need more memory you can insert a SD card to expand its memory.
Feb 14, 2008 | RCA Lyra RD1072 MP3 Player
Memory card question
Did you put the memory card in while the device was off? If not, turn the unit off and back on again. It should be pretty straightforward, once you put the card in the player should recognize it.
Jan 10, 2008 | RCA Lyra RD1072 MP3 Player
512 MB SD CARD
Once you insert the memory card I believe it mixes the songs on the player's internal memory with the memory card's songs.
Jan 04, 2008 | RCA Lyra RD1072 MP3 Player
Playing off of the sd card
I guess that no sopport that size you most have use one sd of 512MB
Dec 27, 2007 | RCA Lyra RD1072 MP3 Player
Memory card music(I'm using a sd2gig
I know that model don´t sopport SD 2gb you have try with 512 mb
Dec 20, 2007 | RCA Lyra RD1072 MP3 Player
It should read the songs automatically. Once you have inserted the card with MP3 Format or WMA formatted songs it should read it.
Apr 17, 2007 | RCA Lyra RD1072 MP3 Player
Problem using Scan Disk memory card
I had the same problem, and that is what RCA answer me: "... Due to a unique FAT12/16 cluster size requirement, the supplied format utility that comes with the RD1021/RD1071/RD1075 MUST BE used on all SD/MMC cards before they will work in the RD1021/RD1071/RD1075. Once formatted, these cards will still be FAT compatible and should still work with other devices, i.e. RD1080. The format utility can be found under "Programs", "Lyra Personal Audio Player", "RD1021,RD1071,RD1075", "Format Media" once your software has been correctly installed from the included RCA CD-ROM. ..."
Jan 15, 2006 | RCA Lyra RD1072 MP3 Player
RCA Lyra RD1072 MP3 Player Logo
78 people viewed this question
Top RCA Audio Players & Recorders Experts
Ekse
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
