Question about Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper Fuser Roller
Error code SC440 - Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper Fuser Roller
My ricoh printer stoped printing and came up with an error code sc440-00
The Ricoh copier error code 440 / SC440 is a main motor lock error code.
If you are receiving this error it can mean:
Your Drive mechanism is overloaded
Your Motor driver board is bad
To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
If the problem persists you may need to contact a local service technician to take a look at your copier.
Aug 28, 2016 | Ricoh Office Equipment & Supplies
How to reset the error code sc440-02?
Remove your driver and reinstall the printer driver by using the CD or via the internet. It should work
Nov 16, 2015 | Office Equipment & Supplies
My ricoh printer stoped printing and came up with an error code sc440-01
Possible Drum motor, or sensor - you would do best getting a professional in to repair, as self repair on these will no doubt end in issues..
Aug 28, 2014 | Ricoh Aficio 2238C Color Copier Printer
Sc440 error code
Too much load on rive or main motor defective..................
Jan 30, 2013 | Ricoh Office Equipment & Supplies
I have a ricoh 1232C multifunction and it has just stopped working and gives an error code sc440 " Functional Problem with the copier "
The problem is Main motor error.
The problem can be two diffrent things.
1. Defective main motor
2. Too much load of the main motor drive
Oct 18, 2010 | Ricoh Aficio 1232C Color Copier
I have this error code on my ricoh aficio cl7200 : SC 440-02
On the CL7200, sc440-02 is a color drum motor error. This error could be caused by a bad color drum unit (any of the 3 colors) or the drum gear positioning sensor, but more often than not it is because of a drum motor that went bad. There is one motor that controls all three color drums -- when this motor goes bad, you get the sc440-02 error.
Apr 23, 2010 | Ricoh Aficio CL2000N Laser Printer
My ricoh printer is showinf an error of sc440-2
sc440 on the CL7000 is a drum motor error. sc440-2 is specific to the color drum motor. The problem is either the motor itself, the drum gear position sensor, or one or more of the color photoconductor units. The photoconductor units you can replace yourself if you have extras -- see if that will clear up the problem.
If they don't, you'll need to contact a service technician to inspect (and replace if need be) the motor and sensor.
Please rate this solution if it was helpful. Thanks!
Dec 13, 2009 | Ricoh Aficio CL7000 Laser Printer
Error code sc440
Black drum motor error. These machines are bad about the waste toner building up in the drum unit. You could try and take the auger out of the drum unit(very messy) and clean it out or try replacing the black pcu.
Mar 17, 2009 | Ricoh Aficio CL2000N Laser Printer
Paper jam leading to error code sc440-01
I think the code is a black pcu motor lock. Replacing the black pcu might fix it, but the black waste toner section could be backed up.
Jan 29, 2009 | Ricoh Aficio CL7200 Laser Printer
Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper Fuser Roller Logo
22 people viewed this question
Top Lanier Office Equipment & Supplies Experts
Adorjani Laszlo
Anthony Karuku
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
