Question about Car Audio & Video
Dash Removal in a 1998 Mitsubishi Galant
I want to remove an after market stereo in my Galant, and install an different one. How do I remove the dash panel around the stereo ?
    Problem Solver:
  • 8 Answers
Go to metraonline.com then look up the dashkit and go to product instructins
Posted on Apr 24, 2009
Fuse for 1995 galant dash clock location
Check fuses them if all good Google what things aren't working. Did you cut any wire into you. Shorted something try putting a long wire on the battery hot side then take long end of wire to a fuse on one side put the wire then see if the things are working if so is fuse good you have an open you will find it
Dec 11, 2016 | 1995 Mitsubishi Galant
How to remove the stereo on a 1996 mazda mpv
Mazda MPV Dash Trim Removal, Stereo Removal - Auto ...
? 3:38
https://www.youtube.com/watch?v=REoTeVM2S-o
Jul 1, 2013 - Uploaded by Robert DIY
Dash trim removal: 5 minutes. This video will show you how toremove the dash trim piece on the Mazda ...
[PDF]MAZDA 1996-UP MPV - Scosche
www.scosche.com/media/guides/ma381.pdf
164. 1996-UP MAZDA MPV. MINIVAN. RADIO REMOVAL USING SCOSCHE DT-1 TOOLS . FRONT DOOR PANEL. FRONT AND REAR DOOR 61/2" 3-HOLE.
DIY Mazda Car Radio and Speaker Removal, How to Remove
www.carstereoremoval.com/htm/stereoremovalMazda.htm
'96-99* Car Stereo Removal · Ford Stereo Removal Tools Stereo Removal Tools. How To Install and Remove Mazda MPV Van Car Radio and Speaker, '89-95*
Jan 31, 2016 | Mazda Cars & Trucks
Need mopar part# and location of fuel pump relay on 1998 mitsubishi galant ES sedan, 4 cylinder??
The fuel pump relay is located below the dash, in the center console area bolted to the vertical metal uprights that support the dash.
Depending on production date, the MFI and fuel pump relays may come together or separate. If together, the relay comes as a module consisting of both relays attached together on a metal bracket.
The relays are normally $27 each.
Dec 31, 2014 | 1998 Mitsubishi Galant
How to remove radio in a 1998 mitisubiti Montero sport
Most radio removal requires the dash display covering to be removed to access the bolts for the radio removal. Once that has been removed, you will probably see how they installed it at the factory and it will be pretty simple.
Oct 11, 2014 | 1998 Mitsubishi Montero Sport
Were is fule pump relay on 98 Mitsubishi galant
Mar 22, 2012 | 1998 Mitsubishi Galant
2002 Mitsubishi Gallant - installed after market stereo with wire nuts. Stereo works great, but the dash lights are out. Any Help?
pull the radio back out and remove the wire marked dimmer control on the aftermarket radio then replace fuse
Apr 24, 2011 | 2002 Mitsubishi Galant
I just installed a new stereo in my 2001 mitsubishi galant. Now my dash lights don't work along with the lights by my right arm that illuminate the parking, neutral, and driving states. A rear tail light...
Not to bash on you or anything, but alot of people try to save money and not buy the pigtail for the stereo that will plug into the cars harness and the radio. they start cutting wires and start haveing other problems. The stores should push more to purchase these pigtails. now days everything in your car is a computer. even your instrument panel is a computer. cut the wrong wire and let it short and you have problems. you may have to replace the instrument panel to fix your problem. you can have it checked at a shop
Jun 17, 2010 | 2001 Mitsubishi Galant
Installing after market CD player, I'm looking for info for 1988 ford ranger dash removal instruction or diagram. THANX
if you have 4 holes in radio face you need a tool to remove it might be well worth your money to take to a stereo shop takes them like 10 min.
Nov 09, 2009 | 1988 Ford Ranger
New radio installed - now dash lights don't work
Most factory stereos are wired to the dash dimmer switch. Usually if the dash lights go out after an after market stereo installation, it is because the wire that originally went to the factory stereo is not used for after market stereos. Double check the fuses and ensure the wire that controlled the lights on the factory stereo is not grounding out on something.
Nov 11, 2008 | 1998 Honda Passport
Car Audio & Video Logo
181 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
